Older OS Newer PC
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Older OS Newer PC
    I've been wanting to put Xp on another drive thinking that it would fly on this PC. Its a four core AMD VISION with eight gigs of RAM. Well Xp Home will not install on this thing. It says it will cause damage to the PC. This sucks! Next I up was VISTA. That was a failure too. My VISTA is and upgrade not a full version. Since there is no working copy of Xp on the drive that I was using it also failed to install. Now I'm right back on windows Seven Home Premium. Rat Dude please fix the caps in the title of this post.
    Mark Twain
    John Paul Jones
    Rod Serling
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Older OS NEwer PC
    Make sure you have the SATA controller in IDE mode. that should take care of that.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • RJARRRPCGP
      • Jul 2004
      • 6304
      If you get a BSOD with text saying that it shut down to prevent damage, that's just generic BSOD text and if it has error code 0x0000007B, it means missing or wrong/bad AHCI driver.
      XP don't have AHCI support out of the box unlike Vista and higher!
      Thus, you must install XP in PATA-emulation mode, which in the BIOS, is often known as "IDE".
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Thanks Guys. I'll try that another day. Today I'm going to try a "Coldie" or two and see if they still make me sick. Chemo and/or the Cancer screwed up my beer drinking for sure. Maybe I should just smoke pot. I will not be doing that because I don't even like the stuff and I think that it is still illegal here unless you have a Doctors card for it.
        PotThe Laws
        Mark Twain
        John Paul Jones
        Rod Serling
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          Some people have tried to get it on the ballot here, but the AG keeps kicking it back saying the language isn't right. I think he's stalling but what do I know.
          sigpicThe Sky Is Falling
          • lti
            • May 2011
            • 2557
            There might be AHCI drivers for XP from HP or AMD. You will need to find a floppy drive or make a Windows installation CD containing the drivers.
            Also, Windows 7 won't like having the SATA controller switched to IDE mode. I think you can remove the SATA controller drivers before switching to IDE mode and Windows will install generic drivers after rebooting. Of course, reinstalling Windows will also fix it.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Or Nvidia/VIA/whoever made the controller.
              sigpic
              (Insert witty quote here)
              • c_hegge
                • Sep 2009
                • 5219
                If it's an AMD Vision, then it's an APU (Socket FM1/2). VIA and nVidia don't make chipsets for those.
                I fixed the title too.
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Re: Older OS Newer PC
                  Win Seven has nothing to do with this. The Win 7 OS is on my main drive which is not hooked up while I'm doing this Xp thing. I have another drive for the Xp. Its a Seagate Barracuda, 7200rpm, 80 Gbytes, Sata drive. Dang I'm a mess this morning. I didn't go out for a beer because of this headache I've had for days. I took a dose of fiorinal with codeine to kill off my baby migraine. It worked but now I feel toasted.
                  http://www.rxlist.com/fiorinal-with-codeine-drug.htm
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • Elysarian
                    • Mar 2013
                    • 200
                    I seem to recall a way around the upgrade thing on Vista... something along the lines of installing it in demo mode (without putting a key in) then reinstalling with the same media as an "upgrade" and using the upgrade key.
                    Details here:
                    http://www.zdnet.com/blog/bott/vista...pgrade-key/196
                    • japlytic
                      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                      by japlytic
                      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                      Tried (only with keyboard/mouse connected):
                      • BIOS + database update
                      • Using latest Windows 11 image built with official image creation tool
                      • Previous setup version for Windows 11 installer
                      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                      06-19-2025, 04:59 PM
                    • 24gsm
                      MacBook Pro A1708 install macos fail
                      by 24gsm
                      hi to all
                      i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                      after enter to recovery and format hdd 1to .
                      after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                      can help please
                      Serial Number: FVFXP0U0HV2J
                      Config Code: HV2J
                      Find My Mac: OFF
                      04-16-2025, 03:57 AM
                    • duwane
                      A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                      by duwane
                      Hi All.
                      Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                      The issue:
                      Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                      10-26-2022, 07:02 AM
                    • TrumanHW
                      MacOS: R|W Programmers like CH341x BINs..?
                      by TrumanHW
                      For years I tried figuring out how to R|W BINs from my CH341x programmer.
                      From FTDI's pkg, Apps specifically claiming they work, I failed for ~8 years.
                      I'd expect many here figured it out (easily), but in case not ...
                      It's one of the few forms of "how-to" remuneration I can GIVE BACK.
                      This group is both GENEROUS & literally BRILLIANT / GENIUS!!!
                      This may be the easiest means to copy-paste:
                      Code:
                      SERIAL -to- USB - CH341 ROM (MacOS):
                      Install xcode:				xcode-select --install
                      Relocate
                      04-08-2022, 02:33 PM
                    • acedogblast
                      Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
                      by acedogblast
                      I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
                      11-16-2024, 10:19 PM
