hard drive spin up problems
  • pentium
    • Mar 2006
    • 2778
    Re: hard drive spin up problems
    The drives have not crashed. They just have mild corruption that prevents a complete boot.
    how the hell do you call a drive with bad blocks "working great"
    I run hard drives into the ground. Any drive with less than 20 bad blocks (or one bad sector sometimes) I use until the drive finally gives the ghost. You would scream if you saw the things I do to keep drives running.
    Anyways, case closed. Problem resolved.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • starfury1
      • May 2006
      • 1256
      H All
      Ok Dood I am with you...just thought you might have missed it
      But think I actually missed your point re TC.....
      Cheers
      You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        I hope you don't keep mission-critical data on those drives, its just asking for disaster. I cycle drives out regularly, even if they work fine. If I even suspect a failure, they're pulled immediately and replaced. Remember, a hard drive is a mechanical device with moving parts that wear in a very unpredictable manner. Two identical drives, one may last 10 years, the other may last 10 days, it's impossible to predict. Never rely solely on a single hard disk, always have a plan in the event of failure, and of course, keep backups religiously. Bad sectors are commonly caused when the surface of the platter becomes worn and unreadable, this obviously causes data corruption. Never use a drive with bad sectors, the drive will only get worse, and so will your data corruption problem.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • gdement
          • Jan 2007
          • 690
          I'd be interested to see a well researched chart showing hard drive failure frequencies as a function of age. I don't have much of a sample size myself, but it seems to me I've had just as many failures from new lemon drives as I get with old ones. Once they've been around a while I tend to trust them more. It almost seems like the chances of failure in any given year are about the same, and maybe higher in the early going. I'd be hesitant to replace a good working drive with a new one.
          I don't know a lot about hard drive manufacturing, but from what I've read I get the impression that they're not very consistent. Different parts are used, different circuit boards get used, different firmwares, etc. The firmware parameters are calibrated to whatever works on that particular unit. In other words, these things are a crapshoot even for the manufacturer.
          [edit:
          https://cdn.badcaps-static.com/pdfs/...6165f4f647.pdf
          Just found an article about this. Haven't read it though.
          • gdement
            • Jan 2007
            • 690
            After reading some of that article, it looks like they found that hard drive failures do increase steadily from year to year. Oh well, I still don't trust new drives.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              I have some SCSI hdd's (Fujitsu) that have been in operation for 5 years, showing no signs of failure. They will be cycled out soon, simply because of their age. SCSI hdd's seem to be built a bit better, as they seem to fail a lot less... From my personal experiences, the average server life of an ATA/SATA is about 1.5~2 years before failing or becoming problematic, whereas the SCSI's I use will last 3 times that long, and end up being replaced because of age or size limitations rather than failure. I've used Fujitsu SCSI hdd's since the late 90's, and I can honestly say I've never had one fail. I've had plenty of IBM, quantum, and seagate SCSI's bite the dust while on duty, as well as countless crappy ATA's. Like mentioned above, it's a crapshoot with hdd's anymore, quality doesn't seem to be anyone's top priority these days, which is why I always preach good backups and failsafe strategies to prevent data loss. You just never know when the head is going to grind itself into the platter, destroying everything.
              Team : 49813
              Join in!!
              Team Stats
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #27
                Google released a doc on the reliability of their harddrives (incause you did not know they use normal computers as server, not real server hardware...)
                So this is data from IDE/SATA harddrives, and the data is of allot of drives!
                • bgavin
                  • Jan 2007
                  • 1355
                  #28
                  I have my business clients on a 3-year rotation for drives. After joining this board, I now have them on the same 3-year rotation for power supplies.
                  Data loss from hardware failure is the same as data loss from abject stupidity. I have a former client (read: I fired him) that is so damn arrogant he had no security system in his medical office, and refused to take backups home. The bad guys broke in with a crowbar and made off with his shiny new Dell, so they could steal all the social security and driver's license numbers found in most medical systems.
                  Not only did he lose his entire practice, he also lost years' of work in the creation of custom medical forms used in his practice. His wife is cutting him zero slack on this one, as she and I both warned him repeatedly.
                  Some folks have hardware failures, others are just plain stupid.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    Wow, now that's an idiot!!! Don't think I'd want him cutting on me!! lol
                    Team : 49813
                    Join in!!
                    Team Stats
                    • pentium
                      • Mar 2006
                      • 2778
                      Seagate has never failed me, neither has Western Digital.
                      Maxtor, Fujitsu and IBM have had their rare failure.
                      Quantum, kalok (why bother?), and toshiba Ipod drives Have a bad rep in my books.
                      I'm still attempting to figure out why almost all my quantum drives died within the same month from crashing, spin-up failure and bad sectors.
                      Find Nedry!
                      • federalhouse
                        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                        by federalhouse
                        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                        **Background:**
                        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                        **What I've Tried So Far:**
                        1. I accessed
                        08-01-2024, 07:03 PM
                      • tmcw
                        PC case - Hard drive rails
                        by tmcw
                        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                        Now, the case is a CiT Gaming Case, and...
                        05-22-2022, 12:04 PM
                      • madura2010
                        DAY11AM6E0 hard disk drive and optical disk drive not detected
                        by madura2010
                        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                        i checked the connectivity of ribbon=good communication with hard and motherboard
                        changed hard disk and checked=3f0 error persist
                        sata power=+5v available
                        Then checked data capacitors=all good
                        Then checked data lines path connectivity to pch=all good
                        reflashed...
                        03-12-2023, 09:09 AM
                      • ash91
                        Hp pavilion 15 not detect hard drive
                        by ash91
                        Hello gentelmen .... this is my first post and sorry for my bad english,
                        so my proplem is my laptop keep losing hard drive even if i but the
                        hard disk in the cady (the box that can replace the dvd rom with hard disk)
                        when i turn the laptop on the massage that said no boot media found pop on
                        the hard disk is fine and to be sure i try another hard
                        i also update my bios to the last update
                        the 5 volt is present on the hard connector on the motherboard
                        the dvd rom work fine when i but a windows dvd in it
                        also when i boot from flash...
                        06-07-2023, 01:45 PM
                      • canadaboy25
                        Hard drive wont spin up unless connected by usb
                        by canadaboy25
                        Hey guys, I've got what I feel is a bit of a strange problem. I have a 1TB Toshiba sata hard drive that will not spin up when connected to a pc diectly with a sata cable. I've tried it in several different PC's and nothing happens. The drive does not spin up or make any noise at all and the pc doesn't detect it.
                        However, it will work absolutely fine when connected to a computer through a usb to sata converter.
                        The converter is actually the board that came from a seagate portable hard drive with a dead drive. Since it was a 2.5" drive and ran off usb, there was...
                        11-10-2018, 06:25 PM
