Windows XP End of Life Approaching
Re: Windows XP End of Life Approaching
The phone number is the same, regardless of the product. As for the whole XP EOL thing, I don't really have too much of a problem with downgrading to 7. I can quite easily work my way around either OS. In fact, two of the four PCs we have here are running 7, and I'll probably upgrade the other two when I feel like shelling out for more licenses.Last edited by c_hegge; 11-10-2013, 11:43 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
How does one save all the existing updates post a service pack in case one needs to reinstall them (and hove no net access, or in this case no MS support)? Make our own "Service pack 4"?
I still have one XP box (dual boot) that I may care about (but that machine pretty much is dilapidated), perhaps I should fresh install it one last time before MS does away with it.Comment
I have some legacy software where the company that made it EOL'd back in the Xp heydays and it wont run on vista or 7/8 so this will affect it. but that's it.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
I think it's good with an Emu 10K1-based sound card and the kxProject drivers!
No crashes that I know about.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
You have to download them and slipstream them into an image if you want them all pre-installed for a reload. I do hope they make it easy for us and do one final 'rollup' update with everything since SP3 rolled into one.How does one save all the existing updates post a service pack in case one needs to reinstall them (and hove no net access, or in this case no MS support)? Make our own "Service pack 4"?
I still have one XP box (dual boot) that I may care about (but that machine pretty much is dilapidated), perhaps I should fresh install it one last time before MS does away with it.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Just remember everyone you can just make a virtual image of your drive and then run it in a VM on a new computer for legacy software. I been doing that for years or speciality software. Plus if something goes wrong i just revert the image.Comment
Microsoft should offer the SP4 before ringing the End of Life Bell.
If they do not do that, they not worth any respect.Comment
I couldn't agree more, funny thing is that even M$ didn't support XP64 (perhaps a way to draw us into Vista and 7 64bit) I had a microsoft fingerprint reader from a client and the 64bit driver is still coming.....Comment
We had about 75 XP machines left at work (out of a total of around ~225). I think we're down to about 12 now. We deployed 45 new HP AiO PCs with Windows 8 (parent company's standard), plus a few Opti 745's with Win7 pro, and some laptops with Win7/8. I'm not sad to see the XP machines go, as they were all P4/Celeron machines. The GX60/260/270/280 machines are getting harder and harder to keep running.
Our new standard is a complete computer cycle every 4 years, at 25% per year. Buying 4 year warranties means that I will never be without support (for as long as we stick to the plan).
This is nice to see:
I've been supporting these exact machines for the last 11 years. Originally as a student in HS, when I installed an entire building full of GX260's. After I graduated, I started working where I'm at now, and we bought a bunch of them as the school was cycling them out. I've continued to string them along with recaps for the last 6 years... Some of these have my handwriting on them from when I was still in school, because even then we were replacing motherboards by the dozen.Ludicrous gibs!
Arc A770 16 GB
Arc A770 16 GB
wait, will support for my ipaq end too?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
There is an unofficial fix (for vista and later)...
http://teknogods.com:8081/phpbb/view...php?f=3&t=8653
That's what I use on my main rig... I have a microsoft keyboard with fingerprint reader; it runs 7 x64. IIRC it doesn't work for XP64 though. As long as you follow the directions exactly, it works perfectly... and it also works for microsoft stand-alone readers too (the keyboard has the same HW attached via an internal USB hub).sigpic
(Insert witty quote here)Comment
There is also a handy open source application called WSUS Offline Update. http://www.wsusoffline.net/
You can download all the updates from various versions of Windows and Office for offline storage. It also has the ability to create an ISO image with all the updates on it along with an installation script which will install all the updates automatically, in the right order and can be set to automatically resume installing updates when Windows requires a restart to 'finish' installing an update.
Slipstreaming is still a nicer solution though.
Unlikely...why would any company spend money to develop something on a platform that they are just about to pull the pin on.Comment
To understand things correctly, MS website says:
"It means you should take action. After April 8, 2014, there will be no new security updates, non-security hotfixes, free or paid assisted support options or online technical content updates."
As far as i understand, if i install Wxp from an older CD, i will still be able to acquire updates over ms update that were released before end of life? And it says that there will not be any security updates, and non-security hotfixes, which means that security related hotfixes will be released? It doesn't say anything about changes in activation though.
If i am right, it is more of a marketing trick to force people to buy 7 and 8. Am I?Comment
What I think, is that the code writers will patch and update old OS's until new hardware makes it so obsolete it needs to be rewritten from scratch. Then they will come out with Windows 7 and then 8 and whatever comes next. It seems to be that way. When 98 was obsoleted, I tried to update my old system with XP but it wouldn't operate on it. I had to get a four core processor and new mother board. The good news is I have since updated to 7 and it is working pretty good. My new computer will have 7 on it from the start.sigpicThe Sky Is Falling
Customer service... Why do car companies make parts for cars not in production?
By Sp4, it would be a lumping of all updates made for xp (including sp3 which includes all SP's previous)... not that hard to make. that way it could be DL'd once .sigpic
by japlyticIn a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
Tried (only with keyboard/mouse connected):- BIOS + database update
- Using latest Windows 11 image built with official image creation tool
- Previous setup version for Windows 11 installer
- Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
- TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
- Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
06-19-2025, 04:59 PM -
This specification for the HP ProBook 450 G6 + Windows Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Windows boardview and 450 G6 + Windows schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 12:20 PM
Hello Guys,
got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
when i install windows 10 it goes trough until the restart and at "getting devices ready" it... -
This specification for the Acer Nitro Acer Nitro 5 AN515-56 15.6 inch Gaming Laptop - (Intel Core i5-11300H, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-56 15.6 inch Gaming Laptop - (Intel Core i5-11300H, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-56 15.6 inch Gaming Laptop - (Intel Core i5-11300H, 8GB, 512GB SSD, NVIDIA RTX 3050, Full...09-07-2024, 01:30 AM
This specification for the Acer Predator Acer Predator Helios 300 PH315-54 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD and 1TB HDD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Predator Helios 300 PH315-54 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD and 1TB HDD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Predator Helios 300 PH315-54 15.6 inch Gaming Laptop...09-07-2024, 01:30 AM
- Loading...
