Safety cut-off?
  • stevo1210
    • Oct 2006
    • 4156
    Safety cut-off?
    Hello Everyone,
    I have an Asus P3V4X motherboard with a Pentium III 650MHz CPU, in which i am using to write this post at the moment.
    Just a short while ago I turned on this PC and then after about 3 seconds into the boot process (No Video Yet) my PC just turns off.... no warning.... nothing.
    I try to turn it back on.... but it didn't turn back on. I didn't smell anything burn or see anything burn at the time this happened.
    Then I waited a while.... removed all extras e.g HDD, CDROM, FDD. Then booted it again and it came up.... I also noticed that all my caps were Sanyo WG.
    Now i've plugged everything back in and it's running. But I'm wondering why that happened?
    Maybe my crap generic power supply was giving it too much 12V current so it turned off as a safety precaution maybe? The 12V line is now from 12.5V - 13V which is pretty high.
    Anyone got any ideas to what may have caused this sudden shut off?
    Thanks.
  • pentium
    • Mar 2006
    • 2778
    Re: Safety cut-off?
    It sounds like an overload to me.
    Did you install anything new?
    Find Nedry!
    Check the Vending machines!!
    • Rainbow
      • Aug 2005
      • 1375
      Re: Safety cut-off?
      If you get 13V and like your HDDs (and data), replace the PSU.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Safety cut-off?
        Well, I just installed a new HDD.... but that HDD was perfectly fine in another PC. I also added a network card.... And also, it just happened again?! For now, I'll try my best to see whats going on.
        [EDIT] I just checked it again and the ATX power connector was a little loose? could that have been the problem? [/EDIT]
        Thanks.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Safety cut-off?
          like when your hdd spins up?
          • WNG
            • Sep 2006
            • 354
            Re: Safety cut-off?
            I have the very same Asus board and cpu, except overclocked to 866 MHz.
            Very reliable board.
            Did your power switch jam? The de-bounce circuit could have kept it from restarting.
            Regarding voltage, don't just rely on the BIOS or AsusProbe outputs. Verify with a Digital voltmeter off a spare power plug while the system is running.
            If you have a cheapo PSU, it may not be able to handle the extra hardware you just added.
            Without system details, we can only suggest the obvious. And yeah, a loose power plug isn't good.
            “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
            We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
            • stevo1210
              • Oct 2006
              • 4156
              Re: Safety cut-off?
              Thanks Willwake,
              Yeah, when my HDD spins up. Then after that it just turns off and i cant get it back on.
              However, I have plugged the ATX connector in tighter and so far everything has been OK, but i'll keep an eye on it.
              This motherboard is one of the best I've had and nothing like this has ever happened before.
              • stevo1210
                • Oct 2006
                • 4156
                Re: Safety cut-off?
                Thanks WNG,
                How did you overclock it to 866MHz? I've tried to switch it to 866MHz in the BIOS before and by the time it loads Windows XP, the computer restarts itself. I'm not an overclocker so i don't know how to overclock this 650MHz chip properly.
                I've also checked my power switch and it isn't jammed at all.
                Here are my System details:
                *Intel (R) Pentium (R) III 650MHz CPU. (Slot 1, 100MHz FSB)
                *2X 128MB Crucial brand Memory Modules. (100MHz, CL2, SDRAM)
                *64MB NVIDIA MX4000 AGP 8X Graphics Card
                *Intel 10/100 PCI LAN
                *56K PCI Modem
                *LG 52X CD Burner
                *Mitsubishi Floppy Disk Drive
                *Western Digital WD200 20GB ATA-100 HArd Disk Drive
                and last but not least.
                *Generic ATX Case with a very cheap and so called 250W "Ming Tong" ATX Power supply.
                • WNG
                  • Sep 2006
                  • 354
                  Re: Safety cut-off?
                  Make sure the cpu and heatsink uses a true heatsink compound between them, and not any thermal 'tapes', or solid phase change transfer materials.
                  These other products causes the cpu to run too hot when overclocked.
                  Set your BIOS to "866 MHz"
                  cpu/memory divider is 1/1.
                  CPU Vcore is set to 1.75V
                  In the chipset config screen, set your RAM timing to SPD.
                  All other options are ENABLED.
                  That's it. I ran well under Win2k sp4, and now it's running Ubuntu Linux.
                  My board is flashed to beta BIOS 1006.003.
                  But it shouldn't be necessary since this version is for recognizing faster cpus.
                  Good luck!
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Re: Safety cut-off?
                    Will the stock/original heatsink work for overclocking?.... Or do I have to get one of those special heatsinks?
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      Re: Safety cut-off?
                      Sounds like the P/S thermal shutdown circuit (if it has one) tripped. Those circuits usually have built-in hysteresis so the circuit trips at X degrees, but remains latched until the sensed temperature falls to (X - 10) or (X - 20) degrees. Maybe that new HDD added just enough extra load to cause thermal shutdown.
                      PeteS in CA
                      • WNG
                        • Sep 2006
                        • 354
                        Re: Safety cut-off?
                        Although I have an OEM cpu with aftermarket HSF, the retail stock one is fine.
                        If you have the retail cpu, remove the heatsink and remove the thermal tape and substitute with something like Arctic Alumina or Silver compound.
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Re: Safety cut-off?
                          Thanks WNG, I got it working now without Windows XP restarting. I'm not familiar with overclocking but.... if I leave it overclocked like this, will the CPU become slower at a lower clock speed or suffer something similar to "Sudden Northwood Death Syndrome"? At the moment I havent changed the Core Voltage yet.... it is still on 1.65V and also, i am still using the stock cooling equipment.
                          At least the PC can boot now.... I think that the loose ATX connector was the culprit of the mysterious cut-off?
                          • linuxguru
                            • Apr 2005
                            • 1564
                            Re: Safety cut-off?
                            Possibly bad caps in the PSU, maybe on the +12v rail. That would account for both the overvoltage as well as the shutdown on HDD spin-up.
                            • WNG
                              • Sep 2006
                              • 354
                              Re: Safety cut-off?
                              No, the cpu won't suffer the so-called SNDS. The Coppermine core is a .18 while the Northwood is .13. Sounds like those guys pushed their luck with too much Vcore.
                              Coppermine Vcore range is 1.65-18V.
                              Running at stock, what is your temp reading in BIOS?
                              Just curious.
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: Safety cut-off? Failed Overclock?
                                After overclocking it up to 866MHz, I got a few blue screens and the CPU temperature was only around 55 degrees celcius in the Asus PC probe (maybe that was too hot for a Pentium III?)
                                The Blue screen says:
                                MACHINE_CHECK_EXCEPTION
                                TECHNICAL INFORMATION:
                                *** STOP: 0x0000009C (0x00000001, 0X8054DA70, 0XF2000000, 0X00000115)
                                Beginning dump of physical memory
                                Physical memory dump complete.
                                What happened? Do I have to give up overclocking now and buy a new processor instead?
                                Thanks.
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  Re: Safety cut-off?
                                  Just curious.
                                  Wait.... My CPU isn't a coppermine.... it is a Katmai. Maybe coppermines are better at the overclock?
                                  • WNG
                                    • Sep 2006
                                    • 354
                                    Re: Safety cut-off?
                                    If the 650 won't hold stable at 1.8V, then your cpu isn't able to overclock to 866.
                                    55 degrees C is higher than mine, I get around 43-50C. Might be running a bit too hot.
                                    You don't necessarily have to give up. Before I properly compounded the heatsink. My 650 couldn't handle 133 FSB. So, I ran it at 124MHz with a 31 MHz PCI clock very stable.
                                    You can attempt that until you get the chance to inspect the heatsink. See if XP will run stable on it.
                                    • WNG
                                      • Sep 2006
                                      • 354
                                      Re: Safety cut-off?
                                      AHHH! That explains things.
                                      Katmai cores are tough to overclock that high. You can't get 866.
                                      The best you can hope to do is 10 MHz over 100.
                                      Try small incremental steps.
                                      Sorry, but I don't remember the voltage range of Katmai's. I know they start at 2.0V.
                                      Oh well.
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        Re: Safety cut-off?
                                        There's no 650MHz Katmai. The fastest one is 600MHz.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • notallbad
                                          Rockworth breaker burning out motor
                                          by notallbad
                                          Got given this breaker to fix, armature had failed so replaced and the same thing happened.
                                          Its a 240v heavy duty breaker as opposed to site 110v.
                                          The 1st armature was bought from aliexpress and advertised as 240v but burnt out within 2 minutes light use taking the 13amp fuse with it and the 2nd bought from ebay (german seller) started to get very hot and begin to smoke so hopefully saved it by shutting it off quick at the first sign of smoke but have now tested the x2 safety cap and its not reading 0.22uf, much lower.
                                          Theres very little to it really on the...
                                          08-16-2024, 04:46 AM
                                        • fadi90
                                          PILZ PNOZ X4 Safety Relay
                                          by fadi90
                                          I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                                          The module is set to dual-channel mode with manual start. In this mode:
                                          • Y36-Y37 and Y1-Y2 are bridged.
                                          • 24VDC is applied across A1-A2.
                                          • It monitors two emergency circuits (S11→S12 and S11→S52).
                                          • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                                          06-07-2025, 01:21 AM
                                        • ktmmotocross
                                          Dell G15 5511 LA-K455P - new gpu fan burn SIO pwm sig. in SIO MEC1515
                                          by ktmmotocross
                                          Hello. Have this Dell G15 5511 la-k455p that new gpu fan burn and left pwm sig from sio with 10 ohms.
                                          I read that this sio MEC1515 must be programmed, but someone says dont. My Vertyanov seems dont have this model in it.
                                          Laptop works and can be tricked by split pwm, but i dont want to do this stuff this way.
                                          So anyone really knows if it must be programmed?
                                          09-16-2025, 07:11 AM
