PILZ PNOZ X4 Safety Relay
  • fadi90
    • Jun 2025
    • Lebanon
    I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
    The module is set to dual-channel mode with manual start. In this mode:
    • Y36-Y37 and Y1-Y2 are bridged.
    • 24VDC is applied across A1-A2.
    • It monitors two emergency circuits (S11→S12 and S11→S52).
    • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34) should close.
    In my case, although 24V is present on S52, the CH1 LED doesn't turn on, and the contacts don't close. It's behaving as if S52 isn't getting power, even though it is.
    I compared it with a working X4 safety relay and found that one of the internal relays isn't receiving a ground signal.
    I switched some elements between both working and nonworking boards, nothing changed.
    I'll provide a photo of the faulty board here, more in a google drive folder. Any help identifying possible causes or failure points would be appreciated.
    Thanks in advance!
  • Per Hansson
    • Jul 2005
    • 5897
    • Sweden
    I would not repair a safety relay: if it fails and someone dies/gets injured and your where the last one working on it that would turn into a lawsuit.
    Safety relays are cheap, just replace it with a new one.
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
    • CuriousJohn
      Burco boiler power problem
      by CuriousJohn
      Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
      Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
      This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
      12-22-2024, 10:25 AM
    • jm1234
      9V relay temperature 40C
      by jm1234
      Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
      I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
      05-09-2024, 03:03 AM
    • hartleyhare5
      Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
      by hartleyhare5
      Post body:
      I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
      Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
      03-26-2026, 03:47 AM
