Netlimiter
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Netlimiter
    http://www.netlimiter.com/
    this is a very nice piece of software which is used to limit the transfer rate for each program which is using the internet by specifying an upload or download limit. Why is that useful? well some programs tend to swamp the internet connection.
    In this case i am downloading fedora isos with Opera so i set a download limit and browse the net comfortably while my download is taking place. Actually i have found that opera is the no.1 download client and thats all i use it for. You can even stop the download and close opera and then happily resume again another day.
    Also netlimiter is useful to see what is going on and you can catch some spyware or even be suprised how much traffic one program is making. Some people were suprised to see that skype making a lot of traffic when idle. Why is that? well skype is a p2p application and can use your computer on occasion to allow people behind very restrictive firewalls to talk to each other........with netlimiter you can limit the skype traffic when you are not making calls if you wanted to stop that practice...
    you might ask why does the screen capture show a speed of 65351 when I have limited opera to 60000? well actually the transfer rate seems to bounce around in the software so i think it is averaging 60000.
    you can also change the units of the transfer speed (now its in KB) and also do stuff like see the applications with their full names.
    This software is proving very useful to me. Highly recommended.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Netlimiter
    Well it`s powerfull, i agree, but latency...... you can`t play FPS games like CSS and Scype etc. Ok, last time i have had it installed, it was my old Athlon XP box, duno how it works on dualcore and faster proc`s. Best thing would be, if there would be a server, wich could deliver real time information abouth other users traffic and mannage all the trafic on the client´S directly to not clog the dsl line.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Netlimiter
      actually the skype forums show a lot of skype users use this prog.
      i agree it would be great to have a server or perhaps even an advanced router doing this.
      still its a nice easy solution and great cos i can now browse and download at the same time.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Re: Netlimiter
        ok Will, post the link to the crack....... 28-day eval version.....
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Netlimiter
          crack? who me?
          • gonzo0815
            • Feb 2006
            • 1600
            Re: Netlimiter
            Yep, as mentioned above, i used it only on my Athlon xp rig (2000MHZ) and W2k. Iam realy shure, that it is a CPU hungry thing if Scype and CSS are running simultanely (yep, Scype alone is a burden to any CPU alone).
            Furthermore i have tested this for abouth one or two years, duno if it has been improved in the meantime.
            • Fizzycapola
              • Oct 2006
              • 423
              Re: Netlimiter
              Sounds good, I already have firewalls which I even paid for lol, I wonder if the lite version would be a good choice for limiting other users on my network, does it have a stealth mode? I'd really like to install it without them knowing, otherwise they'd just uninstall it.
              Rubycon Rubycon Rubycon
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                Re: Netlimiter
                doesnt seem to have a stealth option. really you want to look into installing a firewall box between the switch and the router. there is probably some free linux based one which has that feature. i know it is possible to do this with the cisco router$. keywords would be : traffic shaping, bandwidth management
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  Re: Netlimiter
                  netlimiter seems to have a problem with local gigabit lan connections (via workgroup to another xp pc or also to a samba share) locks up explorer etc. not very good at all. i still need the limiting function for big downloads so if anybody has a better solution then please advise.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Re: Netlimiter
                    I prefer a good external firewall to handle stuff like traffic shaping
                    I use IPCOP myself, I however do not use it's traffic shaping abilities, I just config my applications properly and all is well... (for my usage cenarios)
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Re: Netlimiter
                      I have configured the QOS feature in my Linksys wrt54g running linux based dd-wrt v24.
                      I can`t complain abouth it, it is working w/o any problems. But shure, the download behaivior is with DSl always a problem, as it is only indirect controlable via the ACK packets.
                      When the router is queuing up the incomming packets, then they are already received....
                      Any way, i can easily playng CSS, Scyping etc. and downloading stuff without the ping penalty.
                      Upstreamcontroling is very accurate, i even could limited the bandwidht per MAC or port or set the prioity.
                      • iulik17d
                        Intel Arc A380 videocard power limit remove - BIOS needed
                        by iulik17d
                        Hello everyone!
                        The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                        The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                        01-10-2025, 02:33 PM
                      • mariukonie
                        i7 2860QM how to raise power limit?
                        by mariukonie
                        Hi.
                        I've just upgraded from i5 2340m TDM 35W to i7 2860QM TDM 45W. All is working fine except during stress test the clock multiplier stays capped at x28 which is 2.8MHz and power draw stays around 35W so it seems the motherboard is limiting power draw. On various websites it reads it should go to 3.3MHz on all 8 cores stressed.
                        What is the best way to go about raising power limit.
                        a) Bios upgrade/unlock?
                        b) Hardware/shunt mod?
                        c) Reduce the CPUs voltage somehow?
                        Sony Vaio VPCEH2H1E
                        BIOS Insyde Version R0200Z9 date 19/04/2012
                        Can anyone help with...
                        07-07-2025, 12:52 PM
                      • chris89
                        Which BIOS Editor will Identify the cTDP & thermal limit of AMD A12-9720P & AMD A8-7410 & AMD A4-6210?
                        by chris89
                        09-10-2024, 09:35 PM
                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                        Narrow VDC applications where the system power source is
                        either the battery pack or the regulated output of the charger.
                        This makes the max voltage to the system equal to the max
                        battery voltage instead of the max adapter voltage. Operating
                        at lower system voltage can improve...
                        11-05-2024, 04:43 PM
                      • petehall347
                        need some help to limit current after repair
                        by petehall347
                        ok i know its sort of a double post but also has its own merits . its something i can never work out .
                        thinking of using light bulbs on the power supply outs 12v and 5v but don't know which lamps to use . i know all about limiting mains supply with light bulbs but obviously no use with switching supply .
                        i have been working on a console . i did ask a few times but it seems my thread has gone cold for some reason .
                        https://www.badcaps.net/forum/showthread.php?t=104579
                        03-30-2022, 04:24 PM
