Technogym Synchro Excite 7 cross trainer.is this the correct ic replacement ?
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    https://uk.rs-online.com/web/p/line-...ce-ics/0833535
    and does it even need it as nothing plugs in to those pins .
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: is this the correct ic replacement ?
    bigger pic
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      yeah probably right, does the board work with the broken one?
      Probably for some optional equipment, I still don't get how that could have broke except for mechanical damage?
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        board was working then i switched machine off and back on and no screen so took it apart and powered up then the magic smoke came out .
        its a technogym synchro excite 7 cross trainer .
        this was after i put new caps into power supply but it still wouldnt come until i started taking panel apart then i screwed it back down and still working .. maybe i did short something or that ic was failing already .
        do you think i should remove the chip and see if it then works ?
          • 31277
          74ACT244 high speed buffer - did you connect that cable upside-down or offset by a pin?
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            nothing there to plug into those pins .
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              still wondering if its a good idea to remove the ic chip and see if it powers up ok without it ?
              its just i haven't a clue as to what its there for and cant find any manuals for this exact console .
              its just that the machine is ten miles away and will need to bring the panel back here to work on it so the miles will soon clock up .
                • 31277
                Re: Technogym Synchro Excite 7 cross trainer.is this the correct ic replacement ?
                cant you take the hot air station and tweezers to the machine?
                you wont do damage running it without the chip - at worse the touchscreen wont run right.
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  there have been developments .i removed the chip and powered it up but it was tripping then a pop and spark and more smoke .. a cap left the board c61.. i then took a look at 5.0v and 3.3v points marked on the board . 3.3v ok 5v at 9.6v so it then was then apparent why that ic blew up .
                  took a good look at the board and a buck controller ic had been pushed so its pins were bent . removed it and straightened the traces on the board the best i could .now searching for another max1761 converter . hoping to find one on an old laptop board .
                  • petehall347
                    • Jan 2015
                    • 4448
                    • United Kingdom
                    c61 ..thinking 10uf ?
                    and bent controller .. tried straightening its legs but one fell off like they do .
                    am hoping nothing else got cooked .
                    • petehall347
                      • Jan 2015
                      • 4448
                      • United Kingdom
                      hoping i got these pads straight enough for the max1761 i did lose one but looks easy enough to bend the corner pin onto where i scraped it back a bit .
                      • petehall347
                        • Jan 2015
                        • 4448
                        • United Kingdom
                        i am wondering if it would be ok to replace the blown c61 with a regular 10uf cap ? at least whilst testing .
                        i still cant find that max1761 chip yet at the right price .
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          ok more thing developing .or rather i am finding more shorted things ... at least 1 dual fet and one single one . replacements on the way for all parts needed up to know .
                          there is something a bit odd by the inverter connection .. single fet 8 pin p channel has been changed before and rather badly it is shorted and a trace has been cut ..will add photos shortly ..
                          • petehall347
                            • Jan 2015
                            • 4448
                            • United Kingdom
                            am wondering about powering this thing up to test when new parts fitted . it looks like it should have 12v and 5v lines .i dont have a bench supply as yet but do have plenty of pc supplies . with these being switch mode supplies the variac isnt much use .
                            am thinking resistors and fuses but dont have a clue what its supposed to draw on each line ..any suggestions would be gratefully received . its just when things pop and crack and the smoke releases it pisses me off big style .
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              i forgot to mention the shorted fet by the inverter is a IRF7406 .
                              the others are by the damaged max1761 and are IRF7319. one might be ok but measured 5 ohms at one point i presume my meter switched it on so changing it anyway .
                              its the cut trace and the fet bothers me as i dont know if part is correct one or if cut trace is from factory or a bodge .
                              • petehall347
                                • Jan 2015
                                • 4448
                                • United Kingdom
                                will be ready to power this up soon ... what wattage bulbs should i use to limit the current enough from a pc power supply ?
                                • petehall347
                                  • Jan 2015
                                  • 4448
                                  • United Kingdom
                                  ok after some sweating and wasting a chip that cost 6 quid because of my bad soldering . its maybe back in business ..
                                  • petehall347
                                    • Jan 2015
                                    • 4448
                                    • United Kingdom
                                    more problems now .tried it back on the machine and the touch screen is not working and it reboots itself about every 30 seconds so must be more damage .. i don't really know how to diagnose it as no service manual for it .
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                    • reformatt
                                      Macbook Air M2 A2681 Kernel panics after screen replacement
                                      by reformatt
                                      Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                      It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                      07-31-2025, 08:37 PM
                                    • the_rem
                                      Unknown transformer : how to find a good replacement part ?
                                      by the_rem
                                      Hello guys,
                                      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                      04-23-2025, 01:48 AM
                                    • nicktasios
                                      Macintosh Quadra 840AV PSU
                                      by nicktasios
                                      I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                      12-22-2024, 05:07 AM
                                    • boosti45
                                      Macbook pro logic board replacement parts quesion
                                      by boosti45
                                      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                      08-21-2024, 05:23 AM
