Which BIOS Editor will Identify the cTDP & thermal limit of AMD A12-9720P & AMD A8-7410 & AMD A4-6210?
  • chris89
    • Jan 2015
    • 69
    • United states
  • iulik17d
    Intel Arc A380 videocard power limit remove - BIOS needed
    by iulik17d
    Hello everyone!
    The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
    The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
    01-10-2025, 02:33 PM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
  • hypermk735
    Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB)
    by hypermk735
    Sharing the latest version of Lenovo Golden Key I found to change DMI information such as serial number, MTM, UUID. Run the U1 application and create a bootable USB. It may show an older version upon making the usb. Restart the program and it will update the USB to the next version available. For some reason the updater program does not upgrade all the way to the newest version, only incrementally until it reaches the latest. So do this, Open the u1.exe run the update, close the program, open and run again, close it and repeat until you get to the latest version 3.5.60....
    04-09-2024, 06:39 AM
  • Traptor
    MSI RX 470 ARMOR 4GB with limited frequency
    by Traptor
    Hi folks,
    I have got an MSI RX 470 ARMOR 4GB GPU with a problem and I dont know where can I start repair and if it is worth it.
    The card erlier life is unknown.
    The problem is that: when I start gpu test (Furmark Heaven Benchmark) no problem - no artifacts or something - but after a little time and then the pc is rebooting.
    I tested the gpu with tserver:
    The test with maxmimum memory frequency is OK
    ./agt -mem=1650
    ./tserver -boardtest=memfa
    But, if I increase the engine frequency I have got error. Whit this parameters the...
    11-18-2023, 02:25 AM
  • mnciks11
    Guys can we have a hex editor app so that we will be able to modify bios
    by mnciks11
    Can we have a hex editor, please anyone who can assist im tired of downloading new bios files instead of editing them and remove a password
    12-25-2020, 08:09 AM
