Ratdude's Main rig V3.5
 Re: Ratdude's Main rig V3.5
 kk, lotsa luck, wiseass. <--- Badcaps.net Founder <--- Badcaps.net Founder
 Badcaps.net Services:
 Motherboard Repair Services
 http://folding.stanford.edu/
 Team : 49813
 Join in!!
 Team StatsComment
 Team : 49813
 Join in!!
 Team StatsComment
 decided to furmark it... and when the GPU's got to 100C, I killed furmark.
 Uh oh...
 When I redid the heatsinks, I used this for the GPU die:
 http://www.radioshack.com/product/in...oductId=154389
 I take it that's not good enough... What is suggested to fix this?sigpic
 (Insert witty quote here)Comment
 Furmark pushes a GPU to it's absolute limits. What cooler is on the card? I use to have an 8600GT with the dinky stock cooler. Heated up like crazy. Put on a big ol' cooler and it never got over 40C after that.Last edited by 370forlife; 08-12-2013, 07:03 PM. Comment
 If you are talking about TIM, I use ArcticSilver Ceramique. Never had a problem.decided to furmark it... and when the GPU's got to 100C, I killed furmark.
 Uh oh...
 I take it that's not good enough... What is suggested to fix this?Comment
 Stock cooler for an 8600GTS (it's a bit bigger than a GT IIRC). My only worry about swapping is that if you look, there is only one slot of space between GPUs. Kinda tight.
 100% @ 90C or so.
 I heard ceramique was junk and AS5 was a better choice... but I'm open to ideas.sigpic
 AS5 is a bit old at this point but still excellent and it seems to have come down in price a tiny bit.
 The differences between all of the really good pastes including AS5 are like 1-3C so just find one you like an use it AS5 would be my recommendation that said. AS5 would be my recommendation that said.Comment
 Done some looking, not as sold on AS5... there's some 200 hour burn-in period on that stuff, and that's almost a deal breaker, as the tests I've read show it's not bad (but far from the best) when fresh.
 This stuff any good?
 http://www.newegg.com/Product/Produc...82E16835426020sigpic
 I don't know, looks like generic paste to me. If it was any good, it would list the specs on it.
 The gelid site lists it as 8.5W/mK which isn't anything special.
 Look for pastes that have better thermal conductivity, for example the Prolimatech pastes are advertised at 10.2w/mK
 http://www.newegg.com/Product/Produc...82E16835242024
 But then again, Tuniq TX-4 is recommended by a lot of sites as a good general paste and it's only rated as 6.3w/mK.
 It makes a lot of difference how thin the paste is applied and so on...Comment
 All TIMs have some burn-in period, whether from 5 minutes to 5 days. The microscopic gaps need time to get filled in at normal conditions. You should read some NASA or Mil-Standard Qualification data sheets for further understanding.Done some looking, not as sold on AS5... there's some 200 hour burn-in period on that stuff, and that's almost a deal breaker, as the tests I've read show it's not bad (but far from the best) when fresh.
 http://www.newegg.com/Product/Produc...82E16835426020Comment
 I always use AS5, and it seems to do great.
 As far as the furmark temps, I once did it to a passive 8500GT with a somewhat small heatsink (Thanks ASUS!). It maxed out at 105*C. You could just about cook eggs on it at that temp.Last edited by c_hegge; 08-13-2013, 12:27 AM.I love putting bad caps and flat batteries in fire and watching them explode!!
 Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
 sigpic
 I remember one company that had a warning on every model of paste they made saying that it must be reapplied every 12 months. I can't remember what brand that was now, and I don't see any that has that warning now.
 I never had good luck with Ceramique. It worked fine for a year, and then the temperatures started increasing. I'd rather not take the heatsink off that often.Comment
 Use whatever the OEMs (HP, Dell, eMachines/Acer/Gateway, Lenovo, Toshiba, etc) use because most people run their ten year old PCs and have never reapplied the TIM nor even know what the heck it is LOL...
 Alright, maybe I'm kidding, a little bit, maybe not?Comment
 I am using a computer right now that has Ceramique in use with a Athlon XP 2600+ used every day almost 24/7 for over a year now and no temp problems at all in that time. Do you clean out the dust bunnies often?I remember one company that had a warning on every model of paste they made saying that it must be reapplied every 12 months. I can't remember what brand that was now, and I don't see any that has that warning now.
 I'm not surprised if it's the run-of-the-mill white stuff!
 Unfortunately, the RadioShack stuff likes to fade away after some months of use.
 Took socket 462 heatsinks off more than once, IIRC, to see it disappeared from the Athlon!
 No such bull with Arctic Silver 5.Last edited by RJARRRPCGP; 08-14-2013, 01:24 PM.ASRock B550 PG Velocita
 Ryzen 9 "Vermeer" 5900X
 Arc A770 16 GB
 eVGA Supernova G3 750W
 Alienware AW3423DWF OLED
 "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
			by DobrowolHello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
 Steps i done and results:
 I exported a clean bios from update file via pfs extract.
 1. Build clean bios with clean ME, PMC, PCH in flash image tool.
 Result: Dead
 2. Build clean bios with no changes in ME, new PMC, PCH
 Result: Dead
 3. Build old bios with clean ME, new PMC, PCH
 Result: The same
							Channel: BIOS Requests ONLY!
			This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...09-12-2024, 03:28 PM
			by iotaaHi,
 You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
 I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
 For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
 The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
 This sound can be manually triggered by me if I'm inside the van, or played automatically...
			by sam_sam_samI have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
 I bought this from an eBay seller but unfortunately they only had one
 I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
 I bought three of from them to also make battery packs with this output power limit in mind
 I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
- Loading...
