Ratdude's Main rig V3.5
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Ratdude's Main rig V3.5
    I actually really like how that one turned out - it looks pretty good inside and out!
    Only thing?
    FYI, I did check the windows performance index... it's rated at 6.2, which for a rig this old, is pretty awesome IMHO. I've had no performance issues aero-wise, so I think it may be biased towards newer HW (probably to increase sales of new hardware).
    Why this conspiracy bull$h!t? 6.2 is a quite good score for the system you've got. Sure, I get 8.1 to 8.2 on every aspect of the score but I'm running a much never high-end system so it doesn't even compare.
    Only odd thing about your system is the card reader is a glossy black everythign else is matte black. lol
    • mariushm
      • May 2011
      • 3799
      #122
      I get 5.9 ... simply because I use a 400 GB 7200rpm as main drive.
      The performance index is bullshit... it tops at 7.9 on my windows, 7.7 for the fx-8320 and 7.9 for memory, everything else except the drives at 7.5
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by mariushm
        Looks nice... my only nitpick would be the use of those plastic things used to tie cables together.
        I hate those, I like to use velcro.
        Zip ties?
        Having a FIRST robotics background, it's only natural that I use zip ties and wire buttons (stick on zip tie cleats). Seriously, within that community, instead of duct tape jokes, we have zip tie jokes.
        I use velcro for laptop cable storage (if you look in the 2nd pic you can see some on couple cables formerly used with my laptop). even there, I use zip ties to keep the velcro frome going to the wrong part of the cable.
        For places where I may undo things, I used some kwick-connect straps... one for the SATA RAID bundle, one for the upper part of the mobo/GPU power umbilical. everywhere else, only things that I likely won't need to separate get the ties...
        My beef with velcro is that it peels open too much... zip ties (for low-stress wires at least) is a "set it and forget it" kind of thing.
        edit- Yeah, I know the shades of black don't match on any of the drives. Shit happens.
        sigpic
        (Insert witty quote here)
        • gg1978
          • Dec 2004
          • 431
          Good to see you have it up and running I think you might want to put the DIMM's in the black slots only to start with, then add them to the blues if you add more memory in the future. I didn't see anything specific about DIMM population though in the manual, so maybe you have it right.. I'd verify it's running in dual channel mode using cpu-z or another app like that..
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Looks like it's impossible to get more than 5.9 on a single HDD. Must be in RAID.
            (Probably RAID0 required.)
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              AFAIK They're in all the "1" positions. I'll recheck my manual.
              Edit- yes, I am. I have one in each A1/B1 position. It did show as being single channel in CPU-Z though... the manual says NOTHING about after A1 what order to fill them in. IIRC B1 is the next for dual channel, not A2, right?
              sigpic
              • gg1978
                • Dec 2004
                • 431
                pretty sure you want to populate A1 and A2 of each CPU first.. then at least you could see if it changes to dual channel mode. I was running it with all 8 DIMM's populated with identical reg ECC dimm's, so i never ran in any other than dual channel.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  When I'm home next, I'll try that.
                  I thought it meant "channel A, channel B". That's how intel boards are laid out at least...
                  sigpic
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    10k plus drives might get higher, not sure though.
                    RD - Looks good man, nice and neat. Good job!
                    • Elysarian
                      • Mar 2013
                      • 200
                      • United Kingdom
                      #130
                      I've never seen Windows performance index get above 5.9 with a single mechanical drive, my SSD scores 7.3 (lowest score on my system, when I can afford a second one I'll see if it's any better!)...
                      Never looked at what a RAID array scores, only RAID set-ups I have are in my server boxes.
                      • theokretes
                        • Jul 2013
                        • 49
                        I happen to own both a 15K SAS drive (rebranded IBM eServer) and a corsair neutron.
                        The 15K SAS ousts the SSD in multiple random read/writes. The problem with SSDs is that they are only good at either writing or reading ONE thing at a time.
                        My stupid daughtercard LSI logic controller went haywire (no more 15K SAS), so I went SSD for the time being. I think I'll just get a proper adaptec PCIe controller.
                        --> keep in mind though, the 15K SAS drive sounds like a cement grinder on steroids (it's a fresh fairly new drive too, they're just inherently noisy). So if you don't like that type of sound, SSD is definitely the way to go for quiet computing.
                        (if anyone wants a sound sample I can gladly provide that).
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Correct. Moved them, we're dual channel now.
                          sigpic
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I have two Intel 520 Series 120GB SSDs in RAID0 on my computer which basically gives me a gig of throughput Gets an 8.2 in WEI. Everything else (CPU, Graphics, RAM, etc) get 8.1 which is funny.
                            • lti
                              • May 2011
                              • 2548
                              How do you get such high scores? I thought 7.9 was the highest possible score.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Here's a WEI printout:
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Topcat did a Novabench run on his current setup awile back:
                                  Originally posted by Topcat
                                  Well,not sure how believeable this program is....its saying I have P3's, even after some patch they said it needed.....but here's the result after installing and running without a reboot. I had 2 browser windows up and outlook.
                                  Specs....note what it says the processors are
                                  ...and the results...
                                  From what I'm reading about this, the video card is the biggest killer of my overall score....
                                  Too bad it wasn't the previous system, as it used the same board and all.
                                  Here's what I got:
                                  sigpic
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    He uses Windows 8 and that goes up to 9.9
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      9.9? Why can't Microsoft just give a score out of 10 like everyone else?
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        That's a good point. Who knows?!?!
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16956
                                          Here's what I got:
                                          Those novabench results were not on the opteron system, they are the results of my current office machine, which is a dual quadcore xeon. I never did novabench the opti box before I dismantled it....I guess I should have.
                                          <--- Badcaps.net Founder
                                          Badcaps.net Services:
                                          Motherboard Repair Services
                                          http://folding.stanford.edu/
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • Dobrowol
                                            Dell Latitude 3520 help with bios build/repair
                                            by Dobrowol
                                            Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                                            Steps i done and results:
                                            I exported a clean bios from update file via pfs extract.
                                            1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                                            Result: Dead
                                            2. Build clean bios with no changes in ME, new PMC, PCH
                                            Result: Dead
                                            3. Build old bios with clean ME, new PMC, PCH
                                            Result: The same
                                            09-22-2023, 02:43 AM
                                            ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                                            This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                                            09-12-2024, 03:28 PM
                                          • iotaa
                                            How to build this little device please for my campervan security
                                            by iotaa
                                            You will probably find this funny, and it is, but it's also a project I'd like to take seriously.
                                            I have a campervan and I'd like to avoid thieves to break in it when I am inside it or not.
                                            For this purpose I imagined a simple device that can play a sound based on a vibration detection (in case of intrusion attempt) or by pushing a button manually.
                                            The sound wil be a growling dog, which will deter any thief, thinking there is a big dog inside the van
                                            This sound can be manually triggered by me if I'm inside the van, or played automatically...
                                            09-18-2022, 09:52 PM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
