Increase the capacitance?
  • IMM
    • May 2013
    If this is covered elsewhere in the forum I apologise - I didn't see it.
    I have a board and some of the nichicon HZ's to replace the rotten chemicons.
    I have an Asus P4P-800VM - in which I installed some crap caps I had around to make it run - I'm posting with it here.
    My question is with regard to increasing the capacitance value total on the VCore stuff.
    The mb itself has 10 footprints on the PCB for this, but the mfg only populated 6 of them with 1500uF values.
    It's possible that the designer had 1000uF's in mind when he laid it out??
    Has anyone had much experience with increasing the total value by using the vacant footprints?
    Is it wise?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Increase the capacitance?
    i usually fill the open spots.
    i am not a bean counter and my clients want reliability and durability not cheap.
    never had a problem and the extras share the ripple.longer life and cleaner supply voltages.
    • IMM
      • May 2013
      Thanks for the experience.
      My only real concern was the 'sequencing' of various aspects of the board arriving at working V's on powerup.
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        All Vin caps and all Vout caps are in parallel, no problem.
        That's a nice board, at least when it's running well.
        Asus was cheap, as usual, leaving out caps on that one. Those are much better when they have all their caps, especially with a Prescott.
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • LLLlllou
          • May 2011
          • 201
          Same here, the engineers wanted them there for a reason. I always fill the empty spots. Never had a problem.
          • redwire
            • Dec 2010
            • 3912
            Engineers will have a total capacitance in their design, it's just money saving that leaves some parts unpopulated. Or the CPU uses less current than expected. Usually a "cost improvement" project looks at what the minimum number of caps is required and Production goes with that.
            I would put them all in, it means less stress to each one.
