CPU or BIOS problem
  • Jane
    • Aug 2010
    • 188
    CPU or BIOS problem
    If a computer main board does not start ( no POST) and ALL voltages( coming from PSU are correct) then, I think, the reason can be one of these:
    1.Faulty CPU
    2.Faulty BIOS
    3.Faulty PCB
    Note: By the computer main board I mean a main board itself( no hard disk or similar connected)
    Is there any way how to find out which the reason ,for the failure from those named above, it is?
    What measuring devices should I use and what pins to measure?
  • gilly1984
    • Jun 2012
    • 751
    Re: CPU or BIOS problem
    Faulty Ram too.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      could be faulty cmos too. take the battery out and put it back in
      if its integrated video, try an external video card too
      how do you know the voltages from the PSU are correct? are you using one of those PSU readers. Those dont' always work, cause it doesn't put any stress on the PSU, sometimes it takes a certain amount of stress on the PSU for the voltages to become unstable, which is why I always keep a solid working PSU around for testing purposes
      I would try a single stick of different ram first
      • brethin
        • Dec 2008
        • 1907
        1.Faulty CPU
        2.Faulty BIOS
        3.Faulty PCB
        I would say #4 Faulty Mainboard
        • severach
          • Aug 2007
          • 1055
          Some boards will not power on or POST without a CMOS battery. Don't forget incompatible RAM, incompatible CPU, damaged traces.
          sig files are for morons
          • larrymoencurly
            • Oct 2004
            • 960
            I've seen 2 motherboards that needed the CMOS battery to boot, one an ancient Socket 7, the other a Socket AM2 or 478.
            I've had motherboards knock out their BIOSes, but boot block recovery always let me see something, at least if I used a separate video card, and I could usually recover by flashing from a floppy disk or USB stick. One exception was an MSI motherboard that would not load in the BIOS from the USB stick (the only recovery method it supported) and kept asking for the file that was on the stick. With that one, I had to use SPMPGM2 and flash from the parallel printer port of another computer. MSI offers 3 methods for flashing the BIOS but recommends not using the 2 methods it recommends most.
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              check powersupply ......
              one case.... bad psu, low voltage to startup the mainboard
              imo, cpu rarely fails....
              best if you can list out the pc information, like mainboard made, model, cpu, etc.
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • AquaMan Ua
                Problem with PANASONIC CF53 laptop after changing BIOS settings
                by AquaMan Ua
                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                05-17-2025, 09:40 AM
              • JDC
                by JDC
                ONN 100012588
                Long answer:
                07-15-2022, 07:39 AM
