Windows FLP
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Windows FLP
    I'm trying to restore a decrepit Gateway Solo 2150.
    Specs:
    Celeron Mendocino 433MHZ
    160MB SDRAM, PC100 (maxed out)
    ATI Rage graphics
    I tried XP SP3 on it but that ran like a Yugo towing a 5th wheel.
    I also tried W2k but wireless issues with my cards ran me in. For some reason Linksh!t's utility wouldn't let me do WPA2, nor would Broadcom's utility. However, under XP, running linksh!t's driver straight via "zero" ran wpa2 just fine.
    It seems like Windows FLP may be the safest bet.
    Questions:
    1. Is the "zero" utility part of windows FLP? Or Is just as big of a fail as W2K?
    2. How does one acquire Windows FLP? I think it might have been a VLK only release.
    Normally I'd linux it but the hotkeys don't play well with linux. Also, I have yet to find a linux GUI for older systems that I actually like (I've tried a bunch).
    sigpic
    (Insert witty quote here)
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Windows FLP
    I don't know if you're gonna have much luck with that. Does the board support P3's? That would help. I had the 533MHz version of that Celeron and nothing higher than Windows 98 SE would run smooth on it, and that was with 128MB RAM.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Windows FLP
      It ran win2k just fine. Keep in mind that is a laptop with an (IIRC) BGA cpu.
      sigpic
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: Windows FLP
        I looked into WinFLP but just like vanilla XP support for it ends in April 2014
        You might be interested in Windows Embedded POSReady 2009
        It comes with support until April 2019...
        • moddolicous
          • Jul 2006
          • 18
          Re: Windows FLP
          Have you thought of using Nlite on your Windows XP install cd?
          http://www.nliteos.com/
          Just take out what you don't need from the cd (services, apps, random files, etc) repack it and install. I've used it on a couple computers, but none were as slow as yours. Its worth a shot
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Windows FLP
            I've thought of that... My install .iso actually was nlited (Sp0 Pro disc + Sp3 + 3ware 9500 driver, for use with pre-sp2 OEM COA's). It didn't sound too appealings since I wasn't sure what to chop.
            Oh, and the fact FLP is losing support: Does the fact that I tried W2k say anything?
            I'll look into the POS2009.
            sigpic
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: Windows FLP
              Yea I know, but it was very hard to find a source for FLP
              Since Posready2009 is still for sale you can even find the evaluation ISO on MS website...
              http://www.microsoft.com/en-us/downl....aspx?id=11196
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: Windows FLP
                I'll think about it. What "traditional windows" drivers does it take?
                sigpic
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Re: Windows FLP
                  Think of it as Windows XP SP3, because that is pretty much what it is with some minor tweaks
                  They took the installer that Vista & Win7 uses, so no text mode setup.
                  I wrote more about it on MDL if you follow the link in the thread "I need Windows 8" that I linked above
                  • moddolicous
                    • Jul 2006
                    • 18
                    Re: Windows FLP
                    Its really not that bad. There are a couple things that you don't need that are pretty straight forward (foreign languages, random weird drivers, etc). You could easily slim it down a couple hundred mbs. As far as deleting unnecessary services, there are a couple websites that give explanations of what the services accomplish.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: Windows FLP
                      Oh I read the link. If it works, I'll try to find a way around the pesky 120 day eval window.
                      sigpic
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Re: Windows FLP
                        I fixed it:
                        I tried XP SP3 on it but that ran like a Metro towing a riding lawnmower.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: Windows FLP
                          Question: On POS2009 What's the login name? Administrator? The registered person's name? Something else I forgot I entered?
                          sigpic
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Re: Windows FLP
                            It's "Administrator" and the password you entered during install
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: Windows FLP
                              Thanks!
                              Runs well... My only complaint is the lack of games (like minesweeper, solitare, freecell, pinball). Being an embedded OS I understand why they got chopped...
                              sigpic
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                Re: Windows FLP
                                i didnt thing anyone played those anymore.
                                some of my regulars play the solitair still.
                                Thanks!
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Re: Windows FLP
                                  Under Xp, oh yeah!
                                  Frequent player over here.
                                  Posting this from that laptop. It seems the Lack of RAM is the bottle neck. Runs decently... better than I thought it would.
                                  My dad's Thinkpad T22 would run well on this as well. It's a pIII 900mhz, 512mb RAM. It has sucko s3 graphics though...
                                  Curious, In what format does MS license this? If I could get like a 3 installs pack for not too much $ the house would be set (two laptops + one of my old desktops)
                                  sigpic
                                  • KeriJane
                                    Mac Enthusiast
                                    • Sep 2008
                                    • 681
                                    Re: Windows FLP
                                    I fixed it:
                                    For perspective:
                                    I tried towing a 20' camper with my TWO CYLINDER Trabant back when it had one melted piston and it ran like Windows ANYTHING!
                                    The More You Learn The Less You Know!
                                    • lti
                                      • May 2011
                                      • 2547
                                      Re: Windows FLP
                                      Is that really the maximum? My Solo 2500 supports 288MB.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Re: Windows FLP
                                        Yeah. 32MB internal plus a 128MB expansion SDRAM.
                                        sigpic
