Turning on motherboard by grounding the green wire
  • larrymoencurly
    • Oct 2004
    • 960
    Can grounding the green PSU wire while its connected to a motherboard ever damage a motherboard? I've made a few motherboards show signs of life by doing that, and two of them even managed to show the BIOS boot screen (but couldn't make them turn on the usual way).
    A friend of mine had a Socket 754 Nforce3 (MCP250) motherboard suddenly shut down on him, and it wouldn't turn on when its power switch jumpers were shorted together. So I hooked it up to a known good PSU (300W Delta with all Rubycons and Nichicons) and grounded its green Power-On through a 200 ohm resistor. That made the CPU fan turn on and stay on, but there were no beeps or video (no built-in video; used AGP and PCI video cards). Also the Nforce3 chip got hot enough to make the circuit board reach 110C on the bottom side (not measured until probably 3 seconds after turn-on). The CPU, video card, and memory work fine in another motherboard. Nothing looks discolored. I've tried pressing on the Nforce3 chip while trying to turn on the motherboard through its power switch pins, but nothing happens.
    I don't think it's a matter of bad caps because he recapped it a few years ago with all Nichicons, and his soldering looks good under magnification.
  • gilly1984
    • Jun 2012
    • 751
    Re: Turning on motherboard by grounding the green wire
    110c seems very high.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Check the caps are the right way round - if it is an asus or asrock board I believe the markings are not as usual. The white line on the cap does not go on the black semicircle side.
      • larrymoencurly
        • Oct 2004
        • 960
        It's an ECS and had been recapped a couple of years ago, apparently very well. I didn't check the MOSFETs while the mobo sort of ran, but I didn't find any gate-channel shorts.
        I have a feeling the problem is the common Nvidia chipset failure:
        http://www.theinquirer.net/inquirer/...hips-defective
        • lti
          • May 2011
          • 2548
          If the chip gets that hot, it's fried. That chipset was made long before the defective chip issue.
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • jimjoe123
            LCD TV Green/Pink screen problem
            by jimjoe123
            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
            Then each time...
            02-23-2020, 01:29 AM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
