Dell uses quality caps?
  • LilKevin715
    • Apr 2006
    • 22
    I got a old Dell Dimension 8100 in from a friend for servicing. The system would power on for a minute max and then turn off. I'd figure I would take a look inside and look for the usual suspects of failure (CPU fan, bad caps, etc.). Upon opening the case I was pleasantly suprised to find that all the caps were quality japanese caps.
    Caps on the mobo are Rubycon JXA, Oscon polymers, UCC polymers, and Sanyo's
    Inside the PSU were UCC KY, Nichicon, Rubycon YXG
    Was this system lucky in getting quality caps due to its age? How are the more recent Dell systems?
  • LilKevin715
    • Apr 2006
    • 22
    Re: Dell uses quality caps?
    Oh yea forgot about the booting problem as first described. For some odd reason someone decided that a sleeve-bearing fan would be better than a ball-bearing fan inside a hot PSU.... Needless to say I'm suprised that the thermal protection saved the PSU. The cheapo sleeve bearing fan was replaced with a quality sunon dual ball bearing fan.
    • Fatal0E
      • Jan 2004
      • 252
      Dell uses quality caps, they just got caught by surprise with the bad Nichicons.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        with dell its a crapshoot.lowest bidder wins the contract.
        most dell psu i see now are full of ost.and i see plenty of bad ones.you got lucky.
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          The P/S is from the Delta subsidiary, Newton Power. Whose P/S uses the OST?
          PeteS in CA
          • Fatal0E
            • Jan 2004
            • 252
            I wasnt thinking about the power supply. But I have opened some up to see blown caps, don't recall brand, will look next time. The Dimension 4600 seems to be the popular one at the moment to have a dead ps.
            • yanz
              • Nov 2004
              • 910
              i have a 120W delta psu with a dead delta fan (sleeve bearing). caps are taicon pw and rubycon yxg.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                most dell psu i see with bad ost are hipro.
                • yanz
                  • Nov 2004
                  • 910
                  What PSU does dell use now for their desktop?
