Replacement Laptop Battery Suggestions?
  • bigbeark
    • Jan 2010
    • 661
    I have IBM T41 and Dell D830 Laptops. The IBM has no battery, the Dell is not recognizing the battery.
    I suspect the wise idea is to buy a genuine replacement if you can find one, but it may be more than the T41 is worth.
    What are the pros and cons of replacement batteries? I see a price range of $25 to $75 or higher on Ebay.
    For now, I just use these occasionally, with the power adapter. If I gift them to someone, they should probably have a battery.
    All suggestions welcome.
  • twbranch
    Mad Nerd
    • Oct 2012
    • 153
    Re: Replacement Laptop Battery Suggestions?
    The dell batteries are rebuildable (<spelling). I am not so sure that is the problem. It maybe internal circuitry to the laptop that allows the battery to be recongnized. Someone on here will probably know that answer.
      I know that some of the IBM and Dell use ID chip in the batteries (just like Dell has ID chip in the AC adapter), I have customers that brought in laptop with new batteries (non-oem) that will not charge or computers go into shutdown. I put in OEM batt and everything works again.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I'd personally find worn out OEM batteries and have them rebuilt. That way you get brand new cells (not NOS, NOS isn't a good thing for LiON cells) AND an OEM ID chip.
        sigpic
        (Insert witty quote here)
        • twbranch
          Mad Nerd
          • Oct 2012
          • 153
          yea the rebuilt battery will have better cells that last a lot longer. may cost a bit but well worth it in the long run.
          • jetadm123
            • 2169
            I guess that forces you to purchase OEM batteries from them at their outrageous prices. At least until the third-party manufacturers figure out a way to copy their ID chip.
            • delaware74b
              • Apr 2009
              • 628
              For the IBM, I would recommend the following battery for $55USD + shipping. New battery pack with Sanyo cells. Good company, no problems.
              http://www.level8technology.com/ibm-...41-battery-610
              They also have one for the Dell, but it's on backorder with estimated arrival in 1-2 weeks. $85.50USD + shipping. they also have a high-capacity one for $99USD in stock.
              http://www.level8technology.com/dell...0-battery-2595
              Stupidity should be a crime, especially for drivers. I have NO patience for them.
              • twbranch
                Mad Nerd
                • Oct 2012
                • 153
                Not necessarily. I have rebuilt many of those packs. As long as you don't damage the chip and connect it back the way it was connected before you will be fine. I have never had a problem with that. I am sure the aftermarket dudes that are refurbishing batteries are doing this, but some may be building them without the chip. Just make sure the company you buy from is reputable and you will be fine. Batteries Plus have them but are kind of high if you ask me and I am not sure what kind of cells are them. Just do some shoping. Level 8 seems to have good prices.
                • bigbeark
                  • Jan 2010
                  • 661
                  Thanks for all the suggestions.
                  This Dell D830 is not detecting the battery. I used smartmontools, it shows the battery temperature, but not it's charge status. When I disconnect the power cord, the machine stops instantly.
                  My wife's Dell failed similarly. Dell service told her it WASN'T the battery, the motherboard would need replacement, only $350.
                  I guess the obvious thing is to find someone with a good battery and try it before buying a replacement.
                  Any experiences to share?
                  • serious_electron
                    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                    by serious_electron
                    Hello Everyone!
                    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                    06-28-2025, 02:57 PM
                  • ahmarzo
                    Acer TMX314-51 laptop battery problem
                    by ahmarzo
                    I have acer laptop tmx314-51 with part no 6050A3020501.
                    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                    The schematic is not available...
                    04-11-2025, 09:14 AM
                    12-31-2023, 06:04 AM
                  • doboka98
                    Satellite C55-A-142 Laptop boots only without battery
                    by doboka98
                    Hello! I am fixing a Toshiba Satellite C55-A-142 (model no PSCG8E).
                    It came with an old battery. Laptop was rebooting every 5 sec with black screen, not even entering BIOS. If battery was removed it worked perfectly only on charger. I thought it's a shorted battery so I ordered a new one.
                    Now with the new one it wont even reboot, but the red battery light is blinking on the laptop. Pressing the power button does nothing. Laptop still works with battery removed.
                    So to summarize:
                    1. there is no short
                    2. Laptop starts only with battery disconnected....
                    10-26-2023, 07:09 AM
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    09-14-2023, 11:10 PM
