What do you think the bottleneck is in my system?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So, this is the computer I'm using in my place away from home that I'll be using 5 days a week, I paid $225 for it, yeah what a steal...
    Core 2 Duo 1.86GHz/2M/1066
    3GB DDR2 RAM 667MHz (2GB+1GB)
    GeForce GTX 260 896MB
    Intel D946ZGIS Motherboard
    180GB Intel SSD 330 series
    Antec Earthwatts 500D
    I'm thinking that the CPU would be the biggest bottleneck, even though the RAM is pretty slow. I'm thinking of upgrading the CPU first?
    I've played some games on it and it can max TimeShift and FEAR 2, I just think it'd be smoother with a proc with more cache
  • Phaihn
    • Jan 2009
    • 842
    Re: What do you think the bottleneck is in my system?
    its most likely both the cpu and memory. i dont think its the cache my current setup has less cache and its pretty decent. more memory would make a big improvement. and a faster cpu wouldnt hurt ither.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • Phaihn
      • Jan 2009
      • 842
      you may be able to find a faster cpu on ebay for not too much money and depending on how manny dimms your motherboard uses you motherboard may max out at 4gb or 8gb.
      My Computer.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Yeah maybe memory then. Unfortunately this thing only supports up to 4GB of 667MHz RAM...it supports up to 2.66GHz/4M/1066 Core 2 Duo
        • Phaihn
          • Jan 2009
          • 842
          i used to have a not too different setup 4gbs would most likely make a huge difference. i have a 3ghz pentium 4 cpu 775 that i got out of a computer i was working on recently.
          My Computer.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Nice, P4's are still good computers as long as they have HT and some RAM to work with. I'll see if I can find a 2GB stick somewhere, there's probably one around here somewhere
            • Phaihn
              • Jan 2009
              • 842
              id say upgrade your memory first get a good set not some cheap stuff and i think your problem will go away.
              My Computer.
              • Phaihn
                • Jan 2009
                • 842
                not useing it the computer i took it out of didnt want to have a picture on screen after i spent $45 on parts for it. she ended up just buying a new one.
                My Computer.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Of course. Right now I have Kingston and Patriot in there. I'll look to replace the Patriot with another 2GB Kingston, my favorite RAM company!
                  • Phaihn
                    • Jan 2009
                    • 842
                    i prefer patriot but have kingston in my current setup and its the cheapest mem i can get atm.
                    My Computer.
                    • Phaihn
                      • Jan 2009
                      • 842
                      http://www.memoryexpress.com/Category/Memory
                      My Computer.
                      • Phaihn
                        • Jan 2009
                        • 842
                        you could get a 2.5ghz amd a3300 and motherboard for around $100
                        My Computer.
                        • Psygnosis
                          • Oct 2012
                          • 6
                          Have you considered one of the newer pentium Dual-cores like the g620?
                          The thing has 3 MB of cache and runs at 2.6, I believe.
                          Then again, are ya comfortable with replacing yer mobo with an 1155, and getting new memory (I believe you can get 'em all, including the G620 for about $140) for the sake of the new processor?
                          If not, AMD's a nice route to follow- I like the APU feature of the A3300, myself.
                          • JuniperSprouts
                            Solder Soldier
                            • Aug 2010
                            • 119
                            Bottleneck to do what? If you are gaming, the GPU & memory bandwidth, speed & timing are normally the first to be addressed. Have you tried overclocking your GPU with RivaTuner: http://www.guru3d.com/content_page/rivatuner.html
                            Your motherboard, as an Intel, is not very tweaker-friendly. A mobo upgrade will allow you to OC your CPU/RAM & tighten up your RAM timing (an underrated tweak). As mentioned, 4GB of matching, high-quality RAM can help. Check ebay, geeks.com, newegg, directron, and tigerdirect for a mobo & RAM. You could put a free/cheap 775 CPU (gilly1984 is giving one away in the FS/Trade forum) in your Intel mobo, along with your RAM (if you replace it), and sell that (here or on eBay) to pay for some->all of your upgrade.
                            Which model is the CPU? E4300? Which revision/stepping? You can use CPU-Z to check. Depending on your ambient temp, C2D's can offer truly remarkable overclocks.
                            • mariushm
                              • May 2011
                              • 3799
                              What's good in that setup : the SSD and the power supply.
                              The Intel MB should be stable, but probably has minimal overclocking capabilies.
                              The processor is OK, can be overclocked a bit, if the motherboard lets it.
                              The video card is a decent one, should be good for games made around 2008-2009.
                              I assume the mb is actually ZGIS, not GZIS : http://ark.intel.com/products/23503/...Board-D946GZIS
                              The page says the board supports a maximum of 667 Mhz on memory, so there's no point buying higher frequency memory (unless the page is wrong).
                              Looking at what processors it says it supports: http://processormatch.intel.com/Comp...dName=D946GZIS
                              ... there's not much you can upgrade it to.
                              Core 2 Duo E6700 (2.66 Ghz) and E6600 (2.4 Ghz) are the highest you can go to... not sure if it's really worth spending 30-40$ on eBay for these.
                              CPU Benchmark is pretty good at evaluating cpus based on their processing power, not combined with video cards and other factors :
                              http://cpubenchmark.net/cpu_list.php
                              Looking at E6700, it has 1644 points.. A Core 2 Duo 1.86 Ghz has about 1100 points. So it's about 40-50% better.
                              So the potential cpu upgrade could give you about... i would say... 10-20% performance improvement overall.
                              Would that be enough of an improvement to be worth spending 30-40$ on the CPU? I'm not sure.
                              Best thing would be to do a motherboard + cpu + ram upgrade:
                              60$ : http://www.newegg.com/Product/Produc...82E16813157292
                              ASRock 880GM-LE FX AM3+ AMD 880G Micro ATX AMD Motherboard
                              Relatively new chipset, with lots of features. There are cheaper boards, from about 45$, but then it's only socket AM3, so you're restricted at what cpus you can use
                              75$ : http://www.newegg.com/Product/Produc...82E16819103886
                              AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
                              This x3 450 has 2750 points, probably 3 times as fast as your current cpu, 2-2.5x times better than your max cpu upgrade, and if you're lucky you can unlock the fourth core and have a quad core cpu.
                              A 4 GB DDR3 is another 12-15$... so overall you're looking at around 150$.
                              ps. And being ddr3 memory running at 1333-1866 mhz will also matter, not just the processor. will improve transfers to and from the video card. It will make some games run better just because the memory has faster transfer speeds.
                              • Logistics
                                • Apr 2007
                                • 721
                                Are you positive what the memory is running at? Are both the 2GB set and the 1GB set the same speed memory? Do you have them installed in the slots correctly to behave in dual-channel the way they are meant to?
                                I don't know how Core 2 Duo's behave because I've never owned a dual-core, but I know on my P4 640 when I turned off HT it ran everything way better. Got rid of the pausing that made watching HD movies in VLC unwatchable. (still has slight pauses, but they are quick and not a constant 10+ second pause)
                                Do multi-core cpu's use HT? Try turning it off?
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Core 2 doesn't have HT.
                                  sigpic
                                  (Insert witty quote here)
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    The GTX 260 is a pretty powerful card. I would OC it but it's factory overclocked and even increasing the clock by 4MHz causes it to freeze. It's an E6300. I haven't checked in the BIOS to see what I can do there yet, I'll have to check it out.
                                    It actually is a GZIS Yeah I checked the Passmark scores and upgrading it isn't really worth it. I guess for now I'll just have to deal with it Thanks for the long reply!!!!
                                    Yeah they're running at 667. Both the sticks are 800MHz so they just down clocked. Turning off HT gave you a big increase? Were you using XP? Cause I know Windows 7 can utilize HT better than XP can. No, none of the Core 2 Duo's or Core 2 Quad's have HT.
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      So, I did a little experiment and was really surprised by it...I threw in a Pentium D 940 3.4GHz/4M/800 and it plays games better now. It's cooled well too, under full load it gets to 55C. I thought the Core 2 would be better though....also in WEI, after putting in the PD, the RAM score went up
                                      • mariushm
                                        • May 2011
                                        • 3799
                                        You're probably playing single threaded games... that D940 is two cores at higher frequency, core 2 duo is dual core, less frequency... if the game won't use both cores, it doesn't matter that it's overall better.
                                        • shovenose
                                          What’s the bottleneck with x58?
                                          by shovenose
                                          Posted on another forum about lame performance, can’t even manage 60fps at 1080p on GTA V with my bf’s computer.
                                          It’s a Dell XPS desktop with an i7-930 and GTX980 4GB GPU.
                                          Initially it was running 3x 2GB memory modules in the wrong slots so it was running single channel.
                                          I replaced that with 3x 4GB running in triple channel configuration. I thought for sure that would solve it.
                                          Nope. A bit better but still no good. According to stats neither GPU nor CPU are anywhere close to 100% and even according to task manager none of...
                                          09-22-2022, 02:18 PM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                        • JdogTheGreatOne
                                          Does anybody have a BIOS dump for a Toshiba Satellite L350 (PSLD8C-00J00W)
                                          by JdogTheGreatOne
                                          I'd be so happy, I searched everywhere for it and the dynabooks (formerly the toshiba laptop division) website gives a 404 and so does a website called Softpedia that seemed to have the newest bios file(Ver. 2.20), but it's not on the server. I've emailed the company but I wanna get this fixed fast so I'd love a BIOS update as I think that might be the bottleneck in getting this laptop to boot into any os properly. I believe the mb revision is 3.5 but I'm not actually completely sure what that means so take that with a grain of salt I guess.
                                          03-08-2023, 02:01 AM
                                        • capwizard
                                          Blendtec smoother 13 repair.
                                          by capwizard
                                          Blendtec Smoother 13, He said " no power, it cast $2000, from Starbuck Coffee, Boss gave to him, free, see if it can be fix!"
                                          PS: I plug in, it does has display!
                                          Commercial Blendtec ICB3 - Button ReProgram/Program Tutorial
                                          https://www.youtube.com/watch?v=Cl5jr-VcDlY...
                                          01-30-2017, 01:34 PM
                                        • 13mh13
                                          Dell Inspiron 5100 (2003) with RAM issues (voltage, PSU suspect ??)
                                          by 13mh13
                                          Here's my device:
                                          LAPTOP: Dell Inspiron 5100 (2003) 2.4Ghz p4, dual-boot: Windows XP pro, sp1 + LinuxMint ( LM 17.1 MATE ), with 128GB ssd, 512mb ddr sodimm.
                                          The 5100 runs fine, even after 19 years of daily, gentle use, "always on", and on adapter power only.
                                          HOWEVER, over the past 5-6 years there has been a restart-up issue (after power down or power loss --- I leave all my PCs/laps in daily use in ALWAYS-ON condition, even going months w/o re-boots, but the inevitable always happens) .
                                          Seconds to few mins after pressing the power button to restart...
                                          06-06-2022, 08:44 PM
