Used hard drives
  • Shocker
    Banned
    • Dec 2011
    • 635
    Used hard drives
    Do you re-use them??? Say what you think about them. I honestly don't see the point of buying a 3TB drive for an office system, and think of the environment.
    32
    Yes
    0%
    29
    No
    0%
    3
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Used hard drives
    absolutely!
    i look at smart,run a full write and read test,and if ok i use them.
    if its been running a long time with nothing scary in smart it will probably outlast its usefullness.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      For my own computers, I often use new hard drives. But for computers I sell and some of my computers I use I re-use used disks.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Yes, I re-use hard drives. If for a customer, I limit to a 30 day warranty, or remainder of factory, whichever is longer.
        My testing procedure is - Check SMART, read scan test, 3x write 0's test. This also ensures that all the previous data on the drive is gone.
        Ludicrous gibs!
        • NormanSaxon86
          • Mar 2012
          • 64
          Yea it is a good Idea if your computer can support a new drive I would add one. Open you tower case and look for the ribbon cable that connects to you harddrive that is already on you computer. If you have another harddrive plug on that ribbon you can install a new harddrive quick and easy. All you need to do is set jumps to your slave harddrive and you are ready to plug in.
          You might even look into making a custom portable harddrive with your spare.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            If they come up clean after a full check-out, sure I reuse them...but typically not for mission critical stuff if they're really old or have an extreme amount of hours on them. Any drive that has relocated sectors is relegated to use in crap systems, which are cheap and sold as-is.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Shocker
              Banned
              • Dec 2011
              • 635
              By the way, what is the smallest hard drive you'd consider useful??? I'd go for 40GB.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                I've used some 20gb drives for some d530's I reconditioned. Holds the OS and any useful programs that a machine of that era would effectively run (WinXP, MS Office, Outlook, basic photo editing stuff, etc...), with room to spare. They're great internet browsing and email machines.
                Team : 49813
                Join in!!
                Team Stats
                • brethin
                  • Dec 2008
                  • 1907
                  I test them and if they pass without issues I use them on non critical builds. As for size the smallest I have used recentlly was a 6.4GB to run WinXP, Telenet, FPT etc.
                  Oh that reminds me if anyone has any 3.5" SATA drives they want to unload I am in need of them, no size too small, Im looking for around 12 drives.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Smallest I consider useful is 80GB. Anything smaller just goes straight to the metal recyclers.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      are Australians that much richer or are electronics just cheaper down there?
                      sigpic
                      (Insert witty quote here)
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        While 40GB is the smallest I'd feel confident putting in someone else's system I don't get rid of the smaller drives unless they're D.E.A.D.
                        Note also that I try to avoid using drives with ball bearing spindle motors whenever possible due to the noise. I'd take a 40GB FDB over an 80GB BB any day.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          No, to both
                          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I agree under 80gb is pretty useless. Not counting my 64GB ssd and the 40GB drives in the $100 Linux boxes we sell at work...
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              You can't have it both ways.....either under 80gb is useless or its not....which is it? When it comes to capacity, the means are irrelevant (whether its SSD or a spinner).
                              Team : 49813
                              Join in!!
                              Team Stats
                              • c_hegge
                                • Sep 2009
                                • 5219
                                No, it's just that 40GB is too small, and no one around here has a clue how to use a second HDD.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  I see.
                                  40gb/20gb is good for internet boxes. esp. for a pallet of machines with the hdds stripped and crushed.
                                  sigpic
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    Yes, but no one uses their PCs purely for the net around here. Most people have enough photos and videos to fill 40GB drives up. I know of a few people who fill their 1TB HDDs up.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      i would also reuse them as long as they test good
                                      slightly of topic but whats the best free or paid software you guys are using to test used drives with cheers
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        i save any hdd that is good.
                                        lots of oddball industrial stuff that rejects newer high capacity drives even with the limit jumpers set.
                                        bad ones get stripped for magnets and scrapped unless its something useful for the board and parts for a data recovery job.
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • ChaosLegionnaire
                                          what to do with faulty hard drives?
                                          by ChaosLegionnaire
                                          i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
                                          i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me...
                                          11-25-2021, 02:42 AM
                                        • NeedsPractice
                                          Best Overall Amazing Back Up Setup? 1K-4K Budget! Software + Hardware? Help!
                                          by NeedsPractice
                                          I remember a lot of people before when my hard drive failed told me that I could do a couple of amazing things with backing up data. What stuck out is two things...
                                          1. Software that will backup your data live via a cloud solution or over the internet without having a corporate cloud product.
                                          2. Get a storage tower with hard drives and load them up.
                                          What I mean is there software out there that you can install on your computer. You tell it which data you want backed up. Lets say your main PC with (2) hard drives and (8) hard drives connected to it via a tower....
                                          06-23-2023, 05:26 PM
