Do you think there still is any market room for computers with LGA775 processors? Such as a Pentium or Celeron dualcore. I haven't seen many with a C2D or C2Q for a while. So, what do you think?
LGA775 CPU's...
Re: LGA775 CPU's...
775 is becoming a thing of the past.....like every socket before it. My first experience with a ZIF socket was the socket 3.......before that, it was cramming and praying you didn't rip the legs off the chips... -
Re: LGA775 CPU's...
LGA 1155 seems to have problems with the pins frying because of poor contact. (Shame on you Intel.)
IIRC, you will see posts about that at Overclockers.com.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: LGA775 CPU's...
Yah, I kinda thought that too, TC. But many businesses that do spreadsheets still like the old 775, because its cheap and straightforward. In fact, NeweggBusiness.com still has 775 workstations
EDIT: businesses that do bland stuff like spreadsheets and letters, etc.Comment
Re: LGA775 CPU's...
LGA775 is going to be a thing of the past, just like Socket 478 when LGA775 first came out. LGA775 was still the socket of choice in budget builds up until around now with the Wolfdale Celerons and Pentiums, because the only budget CPU for the short-lived LGA1156 (one of the two sockets that was supposed to replace LGA775) was the Pentium G9650, which wasn't too popular.
Now that LGA1155 has some pretty potent Sandy Bridge Celerons and Pentiums that outperform the old budget Intel Wolfdale LGA775 processors, I believe that LGA1155 will soon take over from LGA775 on the budget side of things. Also, it will be interesting how the upcoming Ivy Bridge processors are, on LGA1155.Last edited by Newbie2; 03-01-2012, 04:05 PM.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bitComment
Re: LGA775 CPU's...
As a budget biuld I ALWAYS use 1155. s775 boards and CPUs aren't even available here now.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Re: LGA775 CPU's...
In the used market, PGA478 is still alive....I still see socket 7 and socket 370 boards to recap on a regular basis... It just depends on the need.Comment
Re: LGA775 CPU's...
embedded?
for embedded, 386 DOS boxes are still used... I went to a elecronics plant as a college field trip and the pick and place machine on the oldest line (used for small runs) was dos based, likely 386 or 486 based. maybe even 286 or older... at that plant, anything from win 98 to win 7 was typical...sigpic
(Insert witty quote here)Comment
Re: LGA775 CPU's...
Still rockin with a pair of LGA775's here: E8500 and Celeron 430.
Interestingly enough here in my part of the world LGA775 are still featured as brand new budget builds and not used budget builds. It's mostly Celerons and Pentium Dual Cores though rarely the C2D E7xxx series.
LGA775 Mobos also still have high availability here. But it's mostly the g41 or g31 based. None of the P45 or P35 anymore.
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1Comment
by ugamazingI have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%... -
Hi guys!
I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
I have attached the Dump of my machine.
S/N: SRW2K4J
Reg Model: DCTR...-
09-27-2024, 02:43 AM -
by vossileSo I picked up this TV for free from somebody who had given up. No picture. The previous owner said that he could not get it to work, but he had supposedly tested all the PCBs in another TV (55" version as I heard during our talk - I have no idea if this is possible maybe a pro can clarify for me). I found some bent/crossed contact on the top LVDS cable from the T-Con to the Mainboard and corrected them best I could. Measurement seem to confirm that I have continuity from the MB to the T-Con on those lines (I have to admit it's a tad difficult).
To be sure, I did inspect all the flat...3 Photos -
The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
The bq24745 features dynamic power management...-
Channel: Common Parts Library - Datasheets
10-23-2024, 02:50 AM -
by ducky29Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
Thanks in advance.09-23-2024, 03:56 PM - Loading...
