Lian-Li cases?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Lian-Li cases?
    ah, that system.
    very cool. also jealous that you were able to score it that cheap NOS with $20 in 2001 money... some people seem to have luck...
    Quoted For Truth.
    • stevo1210
      • Oct 2006
      • 4156
      Re: Lian-Li cases?
      Well... here's my $80 Lian-Li case.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Lian-Li cases?
        Well it looks like $80 worth of case.
        I like that it's silver.
        Beige is awful and black shows dust in like 10 minutes.
        Mann-Made Global Warming.
        - Dr Seuss
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: Lian-Li cases?
          Nice score!
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Re: Lian-Li cases?
            Very nice I bet that would cool this pc well.
            My pc
            CPU : AMD PHENOM II x4 @ 3.5Ghz
            MB : ASUS M4A89TD PRO USB3
            RAM : Kingston ValueRAM 16gb DDR3
            PSU : Cooler Master 850W Silent Pro
            GPU : ATI Radeon HD 6850
            • aidynphoenix
              • Jan 2012
              • 34
              #26
              Re: Lian-Li cases?
              here is my case.
              http://*************/photo/my-images/638/sany2096.jpg/
              http://*************/photo/my-images/28/sany2097.jpg/
              http://*************/photo/my-images/40/sany2095.jpg/
              • c_hegge
                • Sep 2009
                • 5219
                Re: Lian-Li cases?
                I've built a couple of PCs in Lian Li Aluminium cases. They are very good.
                I'm jealous of your score, Stevo
                • stevo1210
                  • Oct 2006
                  • 4156
                  Re: Lian-Li cases?
                  for $80, if you have the $$$ and don't want to OC, take it. as long as the ATX standard is used, it will be a case to reuse.
                  Well, I won't be over clocking... that's for sure. LOL
                  I didn't mention this earlier... but upon buying the case, I managed to pick up an AMD Athlon 64 X2 3800+ CPU along with an Asus M2A-VM HDMI motherboard (full box and manual etc.) for $17... basically $15 for the CPU and $2 for the board. The seller said that the board and CPU work fine... BUT... it would freeze after the memory check. Upon inspection the whole memory section the board was littered with bad KZG caps. So... after coming home at 2AM, I sat there and recapped that board with Panny FJ caps. She's all up and running now in the Lian-Li case.
                  Sub $150 dual core office computer build in my terms.
                    Re: Lian-Li cases?
                    I have a very nice Lian Li case given to me by a friend... more like a computer came complete with a motherboard & graphics card (9800 GT) just needed a PSU and HDD. Seems to be aluminium of some kind and very sturdy build. Got something like 8 fans in it... overkill.
                    • stevo1210
                      • Oct 2006
                      • 4156
                      Re: Lian-Li cases?
                      Obviously a thread would not be complete without final pictures...
                      Everything up and running now. I'll get some more RAM tomorrow morning. 1GB is NOT cutting it for Windows 7.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        Re: Lian-Li cases?
                        IMHO, it would have been a lot prettier if you put the optical drive one bay up and used the silver backplate cover...
                        just an opinion.
                        sigpic
                        (Insert witty quote here)
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Re: Lian-Li cases?
                          just an opinion.
                          I tried that at first actually but my DVD drive kept getting jammed as it opened and especially when it was trying to close. I'll source out a silver DVD drive when I have some time.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: Lian-Li cases?
                            the doors to my g4 clone case had the same issue.... a little modding and sanding (smoothing where it was catching) was all it needed.
                            sigpic
                            • eccerr0r
                              It's 2025: do you know where your 5¼" floppy drives are?
                              by eccerr0r
                              Oh wow.
                              As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                              Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                              Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                              Weird. Seems the PC drive is having trouble clamping...
                              07-07-2025, 12:49 AM
                              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                              Securing a good thermal interface between...
                              10-07-2024, 04:35 AM
                            • Topcat
                              Need to find a 34-Pin Motherboard Floppy Header
                              by Topcat
                              Looking for some floppy headers.....searching the usual sources (digikey/mouser/etc) until my eyes bled, I couldn't seem to find such a beast. Yes, the silly 34 pin floppy header for a PC motherboard....
                              Why? Well, I was given a bunch of Optiplex 330's, which are useless systems these days....and despite what some have said, they do not respond well to the E5450 c0 stepping LGA771 Xeon mod, tried several, it never worked. They're in a standard BTX case, so I tossed some $5 Optiplex 380 boards in them I picked up on ebay, which will run ANY 5400-series Xeon with hard mods + firmware........
                              06-25-2020, 10:50 AM
                            • Satdude
                              Retro laptop floppy drive not working
                              by Satdude
                              Hi, I have a laptop with a Citizen W1D, an infamous drive in the retro computing hobby. They almost always have bad belts, such was the case with this one. However, after replacing the belt, the drive seeks and spins the disk, but the laptop still gives a "No bootable disk" error. Does anyone have any idea what could be wrong? The heads are clean and are able to move.
                              05-24-2024, 02:32 PM
                            • rodd
                              Thermaltake TR2 750W -fixed 5v stby now +5v reads low and no 12v
                              by rodd
                              Dear all,
                              I am trying to repair the ATX power supply.
                              First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
                              Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
                              Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
                              I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
                              In despair I removed the low voltage diodes which were all mounted on the same heatsink...
                              08-11-2023, 12:58 PM
