Gigabyte recalls x79 based motherboards
  • mariushm
    • May 2011
    • 3799
    Apparently the VRM mosfets are underrated and blow up when people overclock:
    http://www.techpowerup.com/157543/Gi...herboards.html
    Last week, a Taiwanese overclocker putting his OC workbench through an relatively laxed OC stress test saw its Gigabyte X79 UD3 motherboard go bust. Its CPU VRM couldn't cope with the stress, and blew a MOSFET.
    [...] The issue was found to be widespread, among three of its main socket LGA2011 products, the GA-X79-UD3, GA-X79-UD5, and G1.Assassin 2.
    Apparently, the issue is caused by a cocktail of bad firmware to complement the board's PWM circuitry, and bad quality PWM components. As an immediate remedy, Gigabyte issued a BIOS update for the affected products. This BIOS, however, will cripple the board's overclocking abilities. The new BIOS will throttle CPU when subjected to extreme stress, to save the VRM. The BIOS remedy is only for those who opt to keep their boards, or don't subject the board to extreme tuning.
    The other remedy, is to return the board to Gigabyte, for a free replacement when the "right" boards are available. Gigabyte also announced a general recall of the GA-X79-UD3, GA-X79-UD5, and G1.Assassin 2, from the market.
    The board releasing the magic smoke: http://www.youtube.com/watch?feature...4QWHjpc#t=223s
  • c_hegge
    • Sep 2009
    • 5219
    Re: Gigabyte recalls x79 based motherboards
    That must be the first design issue Gigabyte hes had with an Ultra Durable motherboard (other than the sandy bridge chipset recall, which was actually Intel's fault).
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      At least they admit it, unlike asus.
      • b700029
        Banned
        • Sep 2010
        • 640
        Looks like an IRFH8330 blew up:
        https://cdn.badcaps-static.com/pdfs/...670600d98c.pdf
        Although you can see in the video that it took a few minutes before it happened, and there was no airflow around the heatsinks so I wouldn't blame it entirely on Gigabyte but also on insufficient cooling. Usually the CPU fan would provide airflow to cool the VRM too, but in this case they're left to cool passively. Maybe Gigabyte did not design those heatsinks to be used like that.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I'm surprised at this....never knew any company to honor warranties/recall parts when the system is intentionally being run out of spec (overclocked), which is typically a warranty killer.
          That would be like Chevy recalling the Camaro because a certain crowd was blowing the engines drag racing them....
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • mockingbird
            • Dec 2008
            • 5484
            [QUOTE=b700029;205882]Looks like an IRFH8330 blew up:
            [url]
            Someone mentioned this on the Xtremesystems forum and someone replied that these motherboards are designed for passive cooling for the VRM, even WITH overclocking which brings me to my next point:
            I disagree. When Gigabyte started advertising their motherboards specifically for overclocking, it opened a whole new door of liability for them.
            I once had a technician deny me a warranty on a budget Asus board that crashed with garbled video output on the integrated graphics every so often (In retrospect, it was probably the KZG - I didn't know about KZG at the time) on the basis that I was replicating the crash with an ancient version of 3D Mark. He claimed that the board "Wasn't designed for 3D". I think I still have his replies saved in the RMA report somewhere.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Ohh absolutely....if they're advertising them that way, and they are going poof like that, yea....it opens the door....still kind of bizarre. I know if I were their legal staff, there would be lots of waivers and disclaimers attached with such a board..... haha
              Team : 49813
              Join in!!
              Team Stats
              • weirdlookinguy
                • Sep 2007
                • 1638
                Honestly my respect for Gigabyte just went up alot. The ASUS way would have been to shove the issue under the door, regardless of how the board was marketed.
                That and my LGA775 EP45-UD3P of two years has been a flawless, rock-solid motherboard. I know which manufacturer will be getting my money next time I buy a board.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I do see some unshielded mosfets on those models, but they're not the vrm's
                  I would figure as many phases they put in vrms now a days, this would not be an issue. I remember old systems using one to two phases, but these have 8 phases or so, each phase with solid caps, and what looks like two filters (not sure if they're ferrite, or iron), are they cheapening so much on each phase components?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    gigabyte went up in my book, as they were on my bad list (after lying about the chipset of my dualie board). at least they have improved since then.
                    sigpic
                    (Insert witty quote here)
                    • acstech
                      GrumpyModerator
                      • Jul 2007
                      • 1432
                      You're not the only one. At least Gigabyte is trying to do the right thing here. I know if there's a system that I build for someone, that I find out about a known issue, I'll go fix it before it becomes a problem, or as soon as I find out about it. It's good to see a manufacturer that has the same theory.
                      A man convinced against his will is of the same opinion still.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Same for my board, which is even older + OC'ed (EP35C-DS3R)
                          It even supports 8GB DDR3 even though it says 4GB DDR3 max. everywhere lol
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Asked this a while back but no one answered with anything definitive.
                            Is there a way just from the model number to know if a GA board is one of the 'Durable' product lines?
                            - Dr Seuss
                            • DynaxSC
                              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                              by DynaxSC
                              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                              General test conditions:
                              - Tested with Core i5 6500 and Core I7 6700K - no difference
                              - Default BIOS settings, but tried also altering several memory setting - does not change anything
                              What is wrong:
                              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                              03-21-2025, 06:23 PM
                              Thermal pad thickness for various laptop GPU / Graphics Cards
                              ASUS Dual RTX 2070 OC 8GB
                              ASUS ROG STRIX RTX 3080 OC
                              ASUS ROG STRIX RTX 3090
                              ASUS TUF Gaming RTX 3080 OC Edition
                              ASUS TUF GTX 1660 S-O6G GAMING
                              EVGA RTX 3060 Ti XC GAMING 8GB
                              EVGA RTX 3060 XC GAMING 12GB GDDR6
                              EVGA RTX 3080 FTW3 ULTRA GAMING
                              EVGA RTX 3080 TI FTW3 ULTRA GAMING
                              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                              Gainward RTX 2080 Phoenix GS Specs
                              Gainward RTX 3070 Phoenix 8GB
                              Gainward RTX 3080 Ti Phoenix
                              GIGABYTE AORUS RTX 3080 MASTER 10G
                              02-09-2024, 08:08 AM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                            • nikovmiroslav
                              Gigabyte A5 X1 Need Bios
                              by nikovmiroslav
                              Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                              Gigabyte A5 X1
                              From motherboard:
                              S/N: 1TNH55ER1350895
                              P/N: 6-77-NH55ERQY-D02-2CGB
                              On sticker from the back of the laptop:
                              S/N: SN21351J000657...
                              08-24-2025, 09:15 AM
                              Gigabyte Notebook Specification for Upgrade or Repair
                              This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                              09-07-2024, 07:19 AM
