Gigabyte recalls x79 based motherboards
  • mariushm
    • May 2011
    • 3799
    Apparently the VRM mosfets are underrated and blow up when people overclock:
    http://www.techpowerup.com/157543/Gi...herboards.html
    Last week, a Taiwanese overclocker putting his OC workbench through an relatively laxed OC stress test saw its Gigabyte X79 UD3 motherboard go bust. Its CPU VRM couldn't cope with the stress, and blew a MOSFET.
    [...] The issue was found to be widespread, among three of its main socket LGA2011 products, the GA-X79-UD3, GA-X79-UD5, and G1.Assassin 2.
    Apparently, the issue is caused by a cocktail of bad firmware to complement the board's PWM circuitry, and bad quality PWM components. As an immediate remedy, Gigabyte issued a BIOS update for the affected products. This BIOS, however, will cripple the board's overclocking abilities. The new BIOS will throttle CPU when subjected to extreme stress, to save the VRM. The BIOS remedy is only for those who opt to keep their boards, or don't subject the board to extreme tuning.
    The other remedy, is to return the board to Gigabyte, for a free replacement when the "right" boards are available. Gigabyte also announced a general recall of the GA-X79-UD3, GA-X79-UD5, and G1.Assassin 2, from the market.
    The board releasing the magic smoke: http://www.youtube.com/watch?feature...4QWHjpc#t=223s
  • c_hegge
    • Sep 2009
    • 5219
    Re: Gigabyte recalls x79 based motherboards
    That must be the first design issue Gigabyte hes had with an Ultra Durable motherboard (other than the sandy bridge chipset recall, which was actually Intel's fault).
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      At least they admit it, unlike asus.
      • b700029
        Banned
        • Sep 2010
        • 640
        Looks like an IRFH8330 blew up:
        https://cdn.badcaps-static.com/pdfs/...670600d98c.pdf
        Although you can see in the video that it took a few minutes before it happened, and there was no airflow around the heatsinks so I wouldn't blame it entirely on Gigabyte but also on insufficient cooling. Usually the CPU fan would provide airflow to cool the VRM too, but in this case they're left to cool passively. Maybe Gigabyte did not design those heatsinks to be used like that.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I'm surprised at this....never knew any company to honor warranties/recall parts when the system is intentionally being run out of spec (overclocked), which is typically a warranty killer.
          That would be like Chevy recalling the Camaro because a certain crowd was blowing the engines drag racing them....
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • mockingbird
            • Dec 2008
            • 5484
            [QUOTE=b700029;205882]Looks like an IRFH8330 blew up:
            [url]
            Someone mentioned this on the Xtremesystems forum and someone replied that these motherboards are designed for passive cooling for the VRM, even WITH overclocking which brings me to my next point:
            I disagree. When Gigabyte started advertising their motherboards specifically for overclocking, it opened a whole new door of liability for them.
            I once had a technician deny me a warranty on a budget Asus board that crashed with garbled video output on the integrated graphics every so often (In retrospect, it was probably the KZG - I didn't know about KZG at the time) on the basis that I was replicating the crash with an ancient version of 3D Mark. He claimed that the board "Wasn't designed for 3D". I think I still have his replies saved in the RMA report somewhere.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Ohh absolutely....if they're advertising them that way, and they are going poof like that, yea....it opens the door....still kind of bizarre. I know if I were their legal staff, there would be lots of waivers and disclaimers attached with such a board..... haha
              Team : 49813
              Join in!!
              Team Stats
              • weirdlookinguy
                • Sep 2007
                • 1638
                Honestly my respect for Gigabyte just went up alot. The ASUS way would have been to shove the issue under the door, regardless of how the board was marketed.
                That and my LGA775 EP45-UD3P of two years has been a flawless, rock-solid motherboard. I know which manufacturer will be getting my money next time I buy a board.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  I do see some unshielded mosfets on those models, but they're not the vrm's
                  I would figure as many phases they put in vrms now a days, this would not be an issue. I remember old systems using one to two phases, but these have 8 phases or so, each phase with solid caps, and what looks like two filters (not sure if they're ferrite, or iron), are they cheapening so much on each phase components?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    gigabyte went up in my book, as they were on my bad list (after lying about the chipset of my dualie board). at least they have improved since then.
                    sigpic
                    (Insert witty quote here)
                    • acstech
                      GrumpyModerator
                      • Jul 2007
                      • 1432
                      You're not the only one. At least Gigabyte is trying to do the right thing here. I know if there's a system that I build for someone, that I find out about a known issue, I'll go fix it before it becomes a problem, or as soon as I find out about it. It's good to see a manufacturer that has the same theory.
                      A man convinced against his will is of the same opinion still.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Same for my board, which is even older + OC'ed (EP35C-DS3R)
                          It even supports 8GB DDR3 even though it says 4GB DDR3 max. everywhere lol
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Asked this a while back but no one answered with anything definitive.
                            Is there a way just from the model number to know if a GA board is one of the 'Durable' product lines?
                            - Dr Seuss
