Why did my motherboard catch fire? Also, what can be saved?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Why did my motherboard catch fire? Also, what can be saved?
    Who'se idea was it to make the USB and 1394 headers identical, even though getting it wrong blows the board up?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      marketing.
      sigpic
      (Insert witty quote here)
      • KeriJane
        Mac Enthusiast
        • Sep 2008
        • 681
        Probably Intel, who also made the wonderful front panel HD audio connector physically identical yet electrically incompatible with the old AC97 connector...
        All hail the mighty Intel....
        Can we go back to PowerPC yet?
        The More You Learn The Less You Know!
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          no because PowerPC is a proprietary slow piece of crap
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I guess I got lucky on the board you gave me... it had both... it also had both 3 usb headers and a 1394... at least they grouped them and color coded the headers.
            my beef with intel regardign said baord (a dp35dp) is that they ditched one of the 2 IDE ports, the floppy port, and the ps/2 ports. the IDE i understand, since the controller chip is a single port marvell... but the rest perplexes me... at least they gave me 6 SATA ports (5 SATA+ one internal eSATA) and 12 usb 2.0 ports (6 internal headers, 6 external ports). I guess they were using Macintosh design concepts (ironic I put it in a mac clone case).
            sigpic
            • zero10
              • Oct 2011
              • 39
              #26
              Originally posted by b700029
              That's not the USB header!
              Now it's pretty clear what happened - 12V to ground short.
              The other pictures I could find of this board show that area has almost no components, so even cutting the whole area out, it would probably still work (maybe no more audio out.)
              Your post had me panicked for a moment until I remembered there was nothing plugged into the front ports, not when it burned or at any time ever before, I never ever used them. The USB header doesn't connect anything to anything else unless a device is plugged in, so although I think you might be right and that cable is on the wrong header, it can't be a short caused by that. Or, in other words, I may be an idiot, but I think the failure is unrelated (I'm sure everybody says that....)
              Looking closer at the picture (the computer is located out of my house right now for... smell... reasons so I can't physically look at it right now), it does appear whatever failed flared on the back first, then the front melted after. I think that might be important.
              I have a new motherboard/cpu/ram on order and I will post an update with more pictures when I get this old board out and can take a proper look at it. New components should be here this week assuming NCIX isn't too backlogged with boxing day orders. I decided it wasn't worth throwing $80 in a new (unreturnable once tested) motherboard at this problem without knowing whether the other related (architecture-wise) components were any good. For an extra $160 I upgraded from my E6300 Core2Duo to an AMD Phenom II X6 1055T (2x1.86GHz --> 6x2.8GHz with better architecture) and from 2x2GB 800MHz ram to 2x4GB 1333MHz. This gives me the advantage of being able to switch the main OS over to Solaris and still run the linux stuff I need inside a virtual machine with acceptable performance.
              Thanks for all the input , and the offers for instructions / suggestions on fixing the board , but as much as the tinkerer in me REALLY wants to dig in and try fixing the board I really think fixing it was never an option given the extent of the damage.
              • zero10
                • Oct 2011
                • 39
                #27
                Oh dear, I just re-read the diagram you posted and I fear you might be right! Oh dear oh dear oh dear.... This just may be the dumbest mistake I have ever made with a computer. Quick, I need to get inside the internet and delete this entire thread before anybody can ever read it.
                If I understand right, it is irrelevant whether anything was ever plugged into the port since the USB port would be grounded where it was attached, and that would indeed ground the +12V line on the firewire circuitry.
                Firewire was disabled from within BIOS, but I doubt that actually powers down the firewire power circuitry.... that means it ran 850+ days with the firewire power shorted to ground, and it probably ran for ~250-300 days before that last reboot the same way too. If this is all correct, then I am now confused whether I should be happy that it ran so long like this, or furious that it didn't shutdown immediately when connected up this way...
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  either way, you will need to go on an expedition to ebay to hunt for a new board.
                  sigpic
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    #29
                    SO we can safely assume that this was user error, even tho ASUS is still a piece of shit.
                    My question is why did it short now and not then, when it was built and power on for the first time?
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      because it must have been a poor connection. either that, or it was a recent mistake.
                      sigpic
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Correct. The GND pins on the USB header connect to the case (which is grounded by the PSU, so plugging a USB header into the 1394 header would be like putting a wire between the +12 and the case (grounded). I think Ratdude747 has the only possible explanation as to why it didn't happen before.
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          JP fears fire! Put that thing in the bin now!
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • b700029
                            Banned
                            • Sep 2010
                            • 640
                            #33
                            I think it was always shorted, but the polyfuse limited the current so it just acted like a heater. The sustained heat eventually caused the fuse to fail by thermal runaway. According to the standard FW can provide up to 45W of power.
                            You don't need to fix it, just cut that part out because there's no critical circuitry in that area and you don't need it
                              You're lucky it didn't burn the battery. Those are extremely flammable and might have done more damage.
                              • KeriJane
                                Mac Enthusiast
                                • Sep 2008
                                • 681
                                But the Mars Rovers and many satellites are PowerPC!
                                I'm pretty sure WALL-E might be PPC also.
                                If it's good enough for space vehicles shouldn't it be good enough for the rest of us?
                                • zero10
                                  • Oct 2011
                                  • 39
                                  #36
                                  I think you are right on the "why now?" bit, there have been no recent changes, heck, the case hadn't been opened in 852 days, and I doubt a poor connection, everything is clean in there and those connectors fit quite well. Can I really just cut that part of the board off? The system did power off before I got there so I think something else must have gone with it, but that would make one hell of a story if it can be saved, quite the battle scar.
                                  • b700029
                                    Banned
                                    • Sep 2010
                                    • 640
                                    #37
                                    Your PSU has short-circuit/overpower protection, so it would shut down.
                                    Looking at intact pictures of your board it seems there's nothing there besides the header and probably the fuse above it, but better to scrub the area of soot and post a cleaner picture.
                                    • toastygoodness
                                      • Jul 2005
                                      • 813
                                      I liked powerpc as well. RISC architectures are more fun.
                                      • Junk Parts
                                        Court Jester
                                        • Jun 2006
                                        • 8953
                                        WALL-E was clearly and advanced AI unit. Someplace on his body there had to be an " Intel Inside" sticker. He also could have been powered by AMD. Its hard to read WALL-E. What ever his systems were based on he did get the girl in the end.
                                        Mark Twain
                                        John Paul Jones
                                        Rod Serling
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          well, the hubble telescope is powered by an INTEL 486 DX.
                                          most space probes use embedded type cpus... the 486 an386 were still inproduction until 2006 (386) and 2007 (486). why? embedded aerospace use. why? its what the designs call for and it is tried and true.
                                          space probe cpus thus are oriented the same way as desktop cpus. there, where every milliamp matters, and reliablilty is a must, you pick the cpu that does the job, no less, no more.
                                          likewise, probes using PPC were designed because thats what the designers felt was bust.... whatever the reason may have been.
                                          Having had experience, freescale cpus (ppc based) are quite common in embedded applications... the biggest advantage tot he lower speed embedded models is low heat, low power usage, and programmablilty. for exaple, the NI cRIOs I were programming when I was on a robotics team were based on a 400mhz frescale cpu.
                                          sigpic
                                          • glovecaps
                                            by glovecaps
                                            11-25-2024, 04:23 PM
                                          • Docus
                                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                            by Docus
                                            Hi everyone 😀,
                                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                                            06-10-2025, 04:24 PM
                                          • paulocoob
                                            HP 250 G8 Motherboard GPT52 LA-K201P CPU fire
                                            by paulocoob
                                            Hello forum friends.
                                            I want to ask for help diagnosing this GPT52 LA-k201p HP 250 G8 card (without dedicated GPU).
                                            The motherboard turns on and consumption is 2.2A (CPU fire)
                                            All voltages seem OK.
                                            The coil resistances are these
                                            [FONT="<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Lucida Sans Unicode</font></font>"]PL302 = 3.2kΩ
                                            PL301 = 30.1kΩ
                                            PLB2 = 10.1MΩ
                                            PLZ1 = 22Ω
                                            PLZ2 = 22Ω
                                            PLG1 = 77Ω
                                            PLM1 = 5Ω[/FONT]
                                            Could...
                                            11-13-2023, 07:54 AM
                                          • Archimedes
                                            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                            by Archimedes
                                            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                            Fans are spinning. Blindly could install windows11 and got the device manager...
                                            07-30-2024, 05:14 PM
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
