Editing PDF files
  • digge
    • Apr 2006
    • 296
    Editing PDF files
    Hi
    I've hit a brick wall with this one thing i want to do with a PDF file. I have a PDF file that has a form in it and loads of input fields that one can fill out and then print the document.
    The problem is that there is a picture in the document that i want to remove. Every software i try either cant handle input fields altogether and therefore they just disappear. The other scenario is that they can handle input fields in that they show them and you can edit them, but once you remove the picture and save the file all the input fields are gone.
    Any suggestions on a software that can do what i want? Even tried to delete the stream data using a text editor but that just lead to a corrupted file.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Editing PDF files
    libreoffice writer?
    sigpic
    (Insert witty quote here)
    • digge
      • Apr 2006
      • 296
      It wont handle the input fields, so just a static page unfortunately, at least didnt work with the version i had.
      • popeye
        • May 2011
        • 155
        snipping tool
        • digge
          • Apr 2006
          • 296
          Originally posted by popeye
          snipping tool
          I might have misunderstood how that program works, but looks like a screenshot tool? And if that is the case it would only give me a static page still with no input fields.
          I want the output to be exactly like the original but without the image.
          • b700029
            Banned
            • Sep 2010
            • 640
            Have you tried CAD-KAS PDF Editor? It lets you edit the "source code" of the pages directly so you can remove the references to the picture. The input fields will stay. (The UI is a little... weird and takes a bit of getting used to, but it works.)
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              I use PDF-XChange Viewer at work, it's quite good and the freeware version offers a surprising number of features.
              I choose the "MSI Network Installer (64 bit)" because it removes some of the crud that the EXE installers come with, atleast used to come with...
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Have you tried Foxit PDF Editor? That works for me.
                A working TV? How boring!
                • digge
                  • Apr 2006
                  • 296
                  Tried both PDF-XChange Viewer and Foxit PDF Editor before posting, no luck. CAD-KAS however did work kinda, tried the trial version, however it left a watermark on it since its the trial version ofc :/
                  Was hoping to be able to do this without buying software for editing just one single document.
                  • Toasty
                    • Jul 2007
                    • 4171
                    Acrobat Pro? Try a portable version of 7 or 8...
                    *cough* t o r r e n t *cough*
                    veritas odium parit
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      CAD-KAS used to be freeware if I remember correctly.
                      You could also try removing watermark and saving with another PDF editor
                      • digge
                        • Apr 2006
                        • 296
                        Problem with that is that all others i tried will remove the input fields, think adobe made some trickery to make sure third party apps will have a hard time figuring out how that is done, cadkas probably figured it out though.
                        • popeye
                          • May 2011
                          • 155
                          Hi digge
                          If you have this pdf on a site what I would normally do is use acrobat to download it as pdf to my desktop then try to edit it that way. Hope this helps.
                          Tony
                          • Gianni
                            • Jul 2008
                            • 681
                            • Italy
                            Sorry to bump this old thread, also because I have not the solution, but I want to suggest a good free tool I use a lot with PDF file:
                            With Free PDF Tools you can do a lot of thing, especially to remove on some PDF document the restriction like "printing not allowed" etc...
                            Ciao
                            Gianni
                            "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                            H. J. Brown
                            • digge
                              • Apr 2006
                              • 296
                              Ciao
                              Gianni
                              Thanks for the tip, but too late, i ended up buying cadkas, company i work for paid for it.
                              Looks like the software you are suggesting might actually do it as well, but as the job is done im too lazy to try it out, but hopefully it helps someone else.
                              • Forest79
                                by Forest79
                                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                07-23-2023, 07:39 AM
                              • iZakre
                                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                by iZakre
                                Hello everybody!
                                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                The thing is that I had installed TeamViewer and could log into the computer...
                                02-19-2023, 02:27 PM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                Yesterday, 05:12 AM
                              • hazem3636
                                need Bios Bin file Dell server 220
                                by hazem3636
                                hi everyone
                                i need dump file for dell server r220
                                i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                if anyone has this method please need his supporting .
                                all the best
                                EXE file is attched and Original Bin file from the Bios Chip is attached also
                                and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                11-05-2022, 06:20 AM
                              • Sebastian Codrean
                                BIOS file for ASUS F542UN laptop
                                by Sebastian Codrean
                                Hello to all of you! I need help with a BIOS file.
                                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                02-20-2025, 10:25 AM
