.FD BIOS file for AN515-56
  • elmoori
    • Sep 2025
    I’m trying to recover my Acer Nitro 5 AN515-56, which currently has a corrupted BIOS and won’t boot. I’ve searched Acer’s website and all I can find is the official BIOS update .exe file.
    Inside that .exe, I managed to extract a file called abobios.bin, but there is no .FD file available — the one needed for Acer Crisis Recovery.
    I’m looking for someone who has the original .FD BIOS file for this exact model, or any guidance on how to extract it safely from the official update.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12339
    abobios.bin is a bios.
    • elmoori
      • Sep 2025
      I tried doing a bios crisis recovery (FN+ESC+POWER) with a usb that only had abobios.bin and nothing happened. Fans max speed and black screen for over 20minutes (USB activity LED solid not blinking).
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • pcwhiz24
        Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
        by pcwhiz24
        Model: Lenovo IdeaPad 3 14ADA05 81W0
        S/N: PF2BZS7D
        I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
        I already have a CH341A programmer...
        04-07-2025, 07:10 PM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
