PC shuts down abruptly in the first few minutes of working, help pls!!!!
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    I've been repairing PC's for a few years and haven't come across this problem so far and I'm out of options. The PC would just shut down randomly and abruptly sometimes after a few seconds and sometimes after a few minutes of working and sometimes it won't power up at all just a fans spinning a little during the first second. Normal troubleshooting procedure, checked memory, gpu, HDD, battery and dvd writer in another pc and all is good, checked for bad caps and all seem ok. replaced the PSU with a known good one. Last thing to check was the cpu temps. First time I checked them BIOS showed me temps in the 30C range, pretty good but problem still persists. So I think what the heck and I reseat the CPU and replace thermal compound and behold, the PC worked like a charm. Gave back the PC to the customer and after a few days I get a call back from the customer complaining on the same symptoms. So I take back the PC and again same thing. I reseated the CPU and the heatsink again and I noticed that the motherboard was bent a little from the force of the heatsink was putting on the motherboard so I decided to run the damn thing with the heatsink seated but not secured and woila, PC boots and runs properly. I slowly and with great care secured the heatsink once again. Started stress testing the cpu with Prime 95. The thing ran with temps in the 30-40C range for about 10 hours. All is well I think... Gave the PC back yesterday and ONCE AGAIN, customer calls and here I am with this damn thing sitting next to me. Same symptoms and in desperate need of your help. I have no ESR meter to check the caps. No spare motherboard or cpu to test these things and no new ideas. PC specs are as follows.
    MB: Asus M2N
    CPU: Athlon 3800+ 64 x2
    Ram: Kingston 2GB DDR2 800
    GPU: Inno3D 7300GT
    HDD: Seagate (don't know the model) 320GB
    I'm at the end of my nerves guys pls help.
    Guns don't solve problems. I'll take 12
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: PC shuts down abruptly in the first few minutes of working, help pls!!!!
    go over there!
    do a memtest86+
    • c_hegge
      • Sep 2009
      • 5219
      nVidia chipset - There's your problem
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        Yeah it does sound like some physical problem if stress on the board with\without CPU cooler attached properly makes a difference.
        Could be bad solder balls on the chipset, could be something else.
        -David VanHorn
        • Evil Lurker
          Warranty Voider
          • Feb 2011
          • 454
          Flakey board, classic Nvidia chipset issues.
          I would recommend replacing it with something else before investing any more time and trouble into it.
          • Koda
            • Aug 2011
            • 317
            • Macedonia
            Well no longer my problem, the customer got angry and took his PC back this morning. I refunded him and he went on to another tech. and hour later called me to rub it in my face that the PC has been repaired and by the words of the other tech the CPU wasn't placed correctly in the socket His words : "the pins of the cpu weren't completely inserted in the socket" (don't know if that's even possible) . Knowing that I placed the CPU correctly because I always triple check when I'm messing with the CPU I was a bit offended but I also know that this new repair won't last very long and he and his new tech will be in a world of trouble with this demonic PC So at least I get a little satisfaction. btw the temps of the motherboard were ok for an nVidia chipset. checked that too. The motherboard could have needed a reflow but not my problem anymore. This guy is my first ever unsatisfied customer but what the hell.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5095
              • New Zealand
              I don't think overheating is the problem with these chipsets (or any), I believe it's more likely bad solder balls between BGA package and PCB or internally to the chip package itself.
              -David VanHorn
              • c_hegge
                • Sep 2009
                • 5219
                Well, ASUS boards often end in unhappy customers for us too.
                • Koda
                  • Aug 2011
                  • 317
                  • Macedonia
                  Originally posted by Uranium-235
                  go over there!
                  do a memtest86+
                  Did a memtest the first two times just to be sure. Nothing wrong, the PC would still show the same symptoms with 3 other known good sticks of memory.
                  Yes most probably its the chipset BGA needing reflow I'm the only one in my town that's doing BGA reflow and hell probably end up replacing the motherboard and paying a hell of a lot more then if he would just be patient and waited a day or two more.
                  I didn't think of the BGA chipset cause the motherboard would work fine for prolonged periods of time after I did the repair. But probably reflowing would have been my next step. Oh well what the heck.
                  • swammyw
                    predator helios 300 shuts down under heavy 3d load, temps are fine
                    by swammyw
                    Hi i need help troubleshooting predator helios 300 mboard: LA-F991P
                    gtx1060 6gb
                    laptop shuts down when benchmarking UNIGINE 3d after 2 minutes
                    and temps are normal when monitoring while running, when laptop shuts down it makes bios reset process when turned back on (i have to take battery out otherwise it wont start) otherwise it seems to work fine, rtc battery shows 2.8v
                    i updated bios ,tried whitout battery ,whitout rtc battery, with another charger but it did not help with problem, anyone had similiar problem? thanks
                    12-08-2022, 06:46 PM
                  • z32KRAzY
                    Alienware 15 R3 Motherboard Issues Help Plz!
                    by z32KRAzY
                    Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
                    Laptop specifics:
                    Model : Alienware 15 R3
                    CPU : i7 6820HK
                    GPU : Nvidia GTX 1080 Max Q
                    RAM : 16GB PC4-19200 (8GB x 2)
                    STOR : 256GB M.2 SSD + 1TB HDD
                    Motherboard : Compal LA-D753P Rev 1.0
                    Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
                    08-07-2022, 06:08 AM
                  • harp
                    Metod for removing glued heatsink from fragile component
                    by harp
                    I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                    06-23-2025, 02:01 PM
                  • Ven
                    Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                    by Ven
                    I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                    The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                    I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                    If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                    07-08-2024, 09:32 AM
                  • riko 656
                    Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                    by riko 656
                    I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                    Laptop Model:
                    • Model: Lenovo Legion Slim 5 16APH8
                    • GPU: NVIDIA GeForce RTX 4070
                    • Main BIOS chip size: 32MB
                    • VBIOS chip size: 16MB
                    Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                    What I Have Tried So Far:
                    1. I
                    11-04-2025, 05:14 AM
