Chipped Athlon CPU: is it risky?
  • incapacitance
    • Jan 2006
    • 29
    I just got an Athlon Tbird from ebay, and I was disappointed to see that the lower right corner of the die is chipped. I've read reports from people who have used chipped CPUs that usually worked but occasionally exhibited problems. I'd like a CPU that works 100% of the time, not 99% of the time. I haven't tried to install it yet (waiting to get back my board). Would you guys be comfortable running it in your system? I'm thinking about asking the seller for a refund. Here's a picture of it:
  • Rainbow
    • Aug 2005
    • 1372
    Re: Chipped Athlon CPU: is it risky?
    It will be probably OK. I have a Duron 700 for testing that's much more damaged (I've bought it like that too...) than your Athlon and it works without any problems.
    • MD Willington
      • Sep 2004
      • 702
      My Duron 950 looked the same, worked fine... even overclocked a little too.
      You can do the same test the RMA procedure outlines if you are really scared of it...
      Test cpu for RMA
      MD
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • Newbie2
        • Sep 2005
        • 885
        That doesn't look bad. I'm pretty sure that thing will still run fine. The PDF that MD has, incapacitance's chip doesn't look anything like what AMD has in their PDF.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          that chipped corner wont likely hurt it.
          as long as the die was not cracked its ok.
          seen lots of those chipped corners worse than that still working.
          • HaiPa
            Hp Pavilion 15-EH Athlon DAG7HBMB8G0 Rev.G
            by HaiPa
            Hello guys,
            As title says, does anyone have a clean bios for the motherboard in the title, from the sticker it should be the Athlon one.
            I will attach my own bios if anyone can do a Clean on my bios, thanks ...
            01-18-2024, 11:22 AM
          • Anonmis
            Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
            by Anonmis
            Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
            The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
            12-01-2023, 04:31 PM
          • eccerr0r
            <taps> So long, Pentium III, Athlon XP, and older...
            by eccerr0r
            Well, looks like they did it.
            Rust, the "secure" language used for firefox and librsvg, no longer work on AthlonXP, Athlon, Pentium III (Katmai and older), Pentium II, and anything older. Because of rust's decision to call "i686" at least a Pentium 4 (with SSE2), these older machines have been left out to pasture. Not sure how hard it is to remove SSE2 instructions from rust's instruction scheduler and still produce a working binary...
            I've been depending on these old machines to keep on working as they still share the same instruction set...or...
            02-09-2021, 01:01 AM
          • TechGeek
            Repurposing a 2004 Athlon 64 system in 2021
            by TechGeek
            Fast Internet connection highly recommended to view this thread.
            So earlier this month, I decided to install some new firewall software on my firewall system (an Advantech UNO-3072LA from 2008) and get a proper firewall solution going instead of the hacky Shorewall... thing that I had running. I picked IPFire because it was basically the last Linux-based solution left that would still boot on x86. Equipped with an Intel Atom N270 CPU, it's stuck on 32-bit software, and is a huge limitation, especially considering that it has dual GbE NICs. In the process of configuring...
            01-27-2021, 06:27 AM
          • AJ847.63e
            820-01598 Intersil 9240 chipped?
            by AJ847.63e
            Trying to fix up a 820-01598 I bought and it looks like the isl has a few small chips in the surface of it. They look just superficial but wanted to confirm whether it would need replacing or not. The bigger one is on the right hand edge and the other two are on the sides. I was told to reflow the chip as we suspected it was the fault of pPbus missing there are no shorts to be found and may of created these chips when tapping it with the tweezers during the reflow.
            Image:
            Sorry image does not seem to be imbedding so here’s the link: https://ibb...
            08-28-2021, 06:47 AM
