Understanding bus values
  • Shodan486
    • Nov 2009
    • 203
    Hi all!
    This time I won't be burdening you with questions of experience and so, but pure theory is on on the hand right now.
    I have difficulties understanding the bandwidth speed of FSB and HT, Wikipedia is cloudy too, so that I want to point out (and be verified) certain things.
    I'm worried about the real speed, meaning MegaTransfers per Second (MT/s). By my knowledge, I say FSB (as in PIII) is calculated like this, for instance:
    FSB of 100MHz x 1 x 8 = 800MB/s
    Where 100MHz is the clock of the bus, 1 is the cycle length (I guess it may be compared to burst mode in DRAM technologies), 8 is the 8bytes of a 64bit width of the bus. This is clear to me, let's move on with the core2 extreme:
    FSB of 400MHz x 4 x 8 = 12800MB/s
    The very same as above, only increased values. Now let's move to the problem. Problem with HyperTransport 1.0 (1.1) to be specific.
    FSB of 200MHz x 4 x 2 = 1600MB/s
    Yes I know all of the FSB should be base clock or BCLK, but here's the thing: 200 is the clock, 4 is the HT1.0 multiplier and 2 is the DDR ability of the HT. I'm using MBs deliberately as the market does (with AMD it did so) instead of MT/s, because right now I'm confused - where in that pattern is the bus bit-width value? Since the hypertransport has a 16bit connections, I should add one more ''x 2'' to it, thus getting the correct values, no?
    Then it would be total fo 3200MB/s (or MT/s). Then why the advetisemens always shows 1600MTs or 2000MTs if the HT multiplier is 5, not 4000MTs?
    Need to know if I'm correct, also just wondering if these results (3200 & 4000) are uni-directional or bi-directional.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • Philly Cheese Steak
    • Mar 2011
    • 114
    Re: Understanding bus values
    HT will change its speed at its own pace hence your not able to know the "set speed".
    linkhttp://en.wikipedia.org/wiki/HyperTransport
    and quote
    HyperTransport also facilitates power management as it is compliant with the Advanced Configuration and Power Interface specification. This means that changes in processor sleep states (C states) can signal changes in device states (D states), e.g. powering off disks when the CPU goes to sleep. HyperTransport 3.0 added further capabilities to allow a centralized power management controller to implement power management policies.
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
    • toygreen88
      • Mar 2011
      thank you for sharing.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        why are we trying to apply hypertransport to core2? I think HT is only on AMD's side till the later core-ix series chips
        or are we? wait, your question seems somewhat confusing
        • Scenic
          o.O
          • Sep 2007
          • 2642
          ^indeed
          intel's "quad pumped" marketing crap is another factor btw..
          CPUs with "800MHz" FSB are actually running on 200 "real" MHz.
          - 400FSB -> 100MHz
          - 533FSB -> 133MHz
          - 800FSB -> 200MHz (kinda makes me wonder why there's no 166MHz/667FSB Oo)
          - 1066FSB -> 266MHz
          - 1333FSB -> 333MHz
          - 1600FSB -> 400MHz
          ^this stuff started with the Pentium 4 and kinda ended with the Core 2 CPUs
          • proxneo
            Recapping Sony ICF-SW55 - verifying cap values
            by proxneo
            Dear reader
            I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
            At the moment, I have selected replacements based on the following list of values:
            3 x 470uF 10VDC
            3 x 4.7uF 35VDC
            4 x 47uF 50VDC
            8 x 22uF 6.3 VDC
            1 x 220uF 6.3VDC
            5 x 100uF 6.3VDC
            Which...
            06-21-2023, 12:38 AM
          • TuanTongbadcaps
            Change CPU multiplier through BIOS editing
            by TuanTongbadcaps
            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
            07-22-2024, 07:57 PM
          • rashidjafar
            Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
            by rashidjafar
            I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
            Values for :-
            PC43 : Capacitor [3x1.5mm]
            PL7 : Inductor [2x1mm]
            PC39 : Capacitor [1x0.5mm]
            Any ideas would be appreciated.
            I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
            08-07-2025, 05:10 PM
          • Kobok
            Different (lower) resistor values on PCB?
            by Kobok
            Dear Alls,
            For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
            09-19-2022, 07:30 AM
          • skdsp
            Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
            by skdsp
            I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
            Attached is the photo.
            Thank you!
            09-27-2025, 09:05 PM
