Different (lower) resistor values on PCB?
  • Kobok
    • Aug 2022
    • 6
    • Magyarország
    Dear Alls,
    For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103 10k in hand, but 3.5k on the PCB, 183 18k in hand, but 8.25k and 9.27 on the PCB.
    Is it normal? Or do other parts need to check/replace?
    OTHER
    2202 resistor shows increasing values when I measure on the PCB (starts from 4.1k upto 20.1k. In all cases the board is power off, of course.
    Any tip, lesson to learn? Because of the strange values I do not want to switch the board onto 230V.
  • petehall347
    • Jan 2015
    • 4450
    Re: Different (lower) resistor values on PCB?
    so you discovered you cant reliably test resistor values in circuit because other things change the results . the reading increasing in value is a capacitor charging up ..swap your probes over and it will drop rather than go up .
    • Kobok
      • Aug 2022
      • 6
      • Magyarország
      Thank you! So if I understand well, the phenomena is normal in both cases, isn't it? If the resistor shows normal values out-of-circuit measures, will work as must after soldering.
      • Kobok
        • Aug 2022
        • 6
        • Magyarország
        One more question: some diodes show the similar phenomena above, which is weird for me. In hand the diode shows polarity if I check with a multimeter (value in case of right polarity and nothing vice versa) BUT if I solder in the multimeter measure minimal value in both polarity direction. Is it acceptable or I have to seek a bad element somewhere in the circuit?
        • petehall347
          • Jan 2015
          • 4450
          all depends on the circuit and what is affecting the reading .
          • Kobok
            • Aug 2022
            • 6
            • Magyarország
            So might it be a "normal" phenomena or a/some false other elements? If some error, what should I look for in the circuit? Any suggestion?
            • Maggiore
              GIGABYTE AORUS 15 X5LF mb GA-X5L Values ​​of knocked down resistors.
              by Maggiore
              mb GA-X5L
              Good day to all, I need help with the values of the knocked down resistors.
              04-02-2025, 06:15 AM
            • Oinkypig
              Eluktronics Max 17 1st gen rtx 2070 resistor pcb repair
              by Oinkypig
              The laptop blank screen and system crashes, and I need the resistors back in working order so that a repair clinic can diagnose the underlying issue its been having, the unresolved issue of black screen ntoskrnl, tdr_video_failure.
              They're 0402 and I couldn't take them out without frying one of them. It began with one resistor and then i screwed up. Now I cant find a mobile rtx 2070 schematic and the 0402 resistors arent labeled. Looking for the knowledgeble on the subject. Resistors r102,r40,and r34 from a eluktronics max 17 9750h+rtx 2070 That needs repairing.
              When i pulled r102...
              09-03-2023, 12:57 AM
            • hummel
              MSI R9 390 Gaming 8GB - short on +MVDD
              by hummel
              Please note I am a noob and all the actions described below are based on the experience gathered on the internet, mainly YT
              MSI R9 390 Gaming 8GB - motherboard model MS-V308 v2.3.
              The card has a short circuit on the entire + MVDD line, starting from the Q703 element ending with the MVREFD outputs under the GPU, but I will describe from the beginning what I did:
              1. At the very start, I measured the resistances on the main power lines, coils and checked the 0 ohm resistors. Everywhere ok, hundreds/thousands of ohms on each, well except...
              10-05-2021, 03:20 AM
            • Petr0x
              Bosch 12V and 18V chargers modification
              by Petr0x
              Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
              You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
              Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
              05-24-2024, 01:00 PM
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
