Auxiliary Power Supply question
  • Mustang
    • Dec 2003
    • 203
    I have an old cheap ps that that I converted into an aux unit to power periferals (hd's cdrom and case fans) on a server board. The conversion went ok but the 12v rails seem too low. It averages 11.29v. The 5v rails are fine at 5.34v. Is there an easy way to increase the voltage on the 12v rail? Maybe a pot or a different rated resistor?
  • Mustang
    • Dec 2003
    • 203
    Re: Auxiliary Power Supply question
    There's a 370 ohm resistor connecting the 12v rail to ground. Would changing this affect the voltage? If so, can a pot be run on this connection to adjust voltage or do I need to look elseware?
    • AK0R
      • Mar 2005
      • 204
      Most power supplies regulate based on a combination of the 5V and 12V outputs. Therefore, if you have no load on the 5V side, it stays above 5V, and the power supply regulates the 12V side down to try to get the overall regulation to a point where it's happy. The fact that the 12V side is loaded only makes the problem worse. Try loading the 5V line, and I bet you'll see the 12V line come up. Also, what kind and rating of PSU, what caps does it have, and what are their condition?
      • Mustang
        • Dec 2003
        • 203
        Thanks for the reply AKOR. You're right it was checked under a no load condition. I'll check it with a load and get voltages. All caps 470uf and up were replaced with panasonic FM's. The 12v side is only a 1000uf 16v. I do have 1500 and 3300 16v caps but not sure if they would be overkill or possibly cause problems elseware. 5v side is 1000uf 10v. PS was overated at 450w but 200w seems appropriate.
        • Mustang
          • Dec 2003
          • 203
          With 2 hd's and a cdrom the voltage increased to 11.55v. Then I added 3 fans to simulate the actual load this this unit will be under. Voltages are now 11.53v and 5.24v. This within tolerance for the drives? Perhaps run the fans at 5v and just add a few more. They'd spin slower and quieter and load up the 5v rail.
          • Chris1992
            • Apr 2005
            • 561
            11.53 and 5.24 are well within spec (10% tolerance).
            The great capacitor showdown!
            • Newbie2
              • Sep 2005
              • 885
              Yep, those voltages are within spec. Now what manufacturer made that PSU Mustang?
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • AK0R
                • Mar 2005
                • 204
                Is there only a single cap and no inductor on each output? If so, you should be able to put in the highest capacitance cap that will fit in each location without any trouble. The problems come if there is a series inductor. Then you have to worry about the output inductor and filter capacitor(s) forming an L-C network that is resonant at or near the switching frequency.
                • Mustang
                  • Dec 2003
                  • 203
                  It's a pretty good size toroid inductor. 4 sets of legs with 2 sets +5v, 1 set +12v and 1 the -12v.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    No +3.3V O/P? That's approaching ancient. Re using larger caps, both the LC and the ESR of the capacitor are important in the stability of the regulator's control loop. And in the kind of P/S that "doesn't have" an O/P inductor, in that topology, "flyback", the transformer primary functions as the "O/P" inductor.
                    PeteS in CA
                    • Mustang
                      • Dec 2003
                      • 203
                      Here's the modified unit. Since it's only using the 12v and 5v lines, I guess there's no worries about the lack of an inductor on the 3.3v side. The ATX, P4 connectors and all 3.3v lines were removed as not needed. An input filter was added, primary side caps were changed from 470 to 680uf as well as the higher value secondary side caps. Finally, a ball bearing fan to cool the unit. I think it'll work well enough as intended.
                      • zepper
                        • Mar 2006
                        • 13
                        What you need to do is load the 5V side. The 12V side will have significant load with a number of drives, but the electronics don't take much in the way of 5V - try to get the total load on the 5V side up to 5 Amps or so - better to get it up to 20% of rated if possible.
                        "He who dares not offend cannot be honest." Thomas Paine.
                        • tiresias
                          • Feb 2006
                          • 489
                          Yes, from what I can read it's a case of crossloading sending the 12V line out of spec. I've seen much worse actually with certain of the very cheap, but current, Fortron ATX300 units, in which a highly overclocked K7 machine (with +5v as CPU VRM input) could result in the 12V rail soaring as high as a potentially destructive 13V.
                          There isn't that much though nowdays in terms of modern hardware that draw much current from the 5v - apart from motherboards and PCI cards of course, but he's powering those with his "main PSU" already.
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            I have seen exactly the same issue with an very cheap FSP350THN-P OEM unit. IMHO a very decent unit otherwise. This psu comes with an 24pin ATX main conector and an 130w 5v & 3.3v rail combined power.
                            I used it testwise in an socket A board, drawing the most power from 5v rail for a couple of days. Iwas glad, that my old Maxtor 6Y120L0 had not been blown up at that high voltage (they are prone for that....).
                            In generall, i never mind those problems, as i may be used that unit out of spec. But i have expected, that the overvoltage protection should kick in a little earlier. I locked at the datasheet, and AFAIk they stated a probably daedly high voltage of about 14v as the point, where the protectin will shut off.
                            • 999999999
                              • Sep 2006
                              • 774
                              You can add a load to the 5V side, OR you can hack the feedback circuit.
                              The feedback circuit's reading of the 5V rail is causing the 12V to be too low, if you cause it to think 5V is too low, it raises 12V without the extra real load or heat from more loading. Key is to not keep any equipment hooked up while testing so nothing is subjected to trial voltages.
                              Generally you'd put resistance inline or after a resistor and before the controller, a pull-down resistor to ground. Not having your schematic or unit for measurements I can't suggest a value resistor to use.
                              Also, 13V is not "potentially destructive". Parts using 12V are far more tolerant to an extra volt than something running off 3.3 or 5V would be, after all it's only 8% higher than the ideal value, though it'll make any fans which were somewhat loud, noisier still.
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
                              • SarcasticOP
                                General question about MacBook power rails for repair.
                                by SarcasticOP
                                I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                • PPBUS_G3H (12.6V-12.8V)
                                  • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                • PP3V42_G3H (3.42V)
                                  • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                • PPVRTC_G3H (3.3V)
                                  • This
                                12-12-2024, 05:50 PM
                              • CMCM
                                Russound CA4 Power Supply Repair
                                by CMCM
                                Hello Everybody,
                                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                The outputs marked 12v and 20v are all measuring only 1v.
                                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                The capacitors physically look clean (no bludgesor leaks) and...
                                07-03-2025, 01:12 PM
