USB Linux & successful recap!
  • bigbeark
    • Jan 2010
    • 661
    My PCI USB card arrived today from HK. It uses the NEC chip. Installed it and it worked!
    Unlike the VIA device I was attempting to use.
    This is for my Dual-370 Asus CUR-DLS board, that I totally recapped, but the onboard USB ports were dead.
    I can't believe how responsive this board is after a recap - like night and day! I used Rubycons throughout.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: USB Linux & successful recap!
    am i understanding that youre getting a performance increase from a recap. didnt know it was possbile...ok well glad it works well
    • yyonline
      • Jul 2009
      • 692
      It's possible if the board was malfunctioning due to bad caps. Replacing the caps restores the board to its original performance level.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        if overclocking, new caps have been known in some cases to stabilize core voltages, resulting in a better overclock... so yes, recapping can boost a board's performance past when it was new (not all the time)
        sigpic
        (Insert witty quote here)
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Via sh!t suckw
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Thought you had more useful things to say after your 3-day vacation.
            Sure VIA might not be the best thing since sliced bread but for some types of systems they are the only choice. Intel clobbered the i815 to only take 512MB SDRAM maximum so that the POS Pentium 4 can sell. Otherwise it had all the goodies, USB 2.0, ATA133, AGP 4x. Well, at that time, VIA made chipsets with all that AND support for 4GB.
            A working TV? How boring!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              It would be a rare i815 board that had USB 2.0 on-board.
              I'm not even aware of any.
              Mann-Made Global Warming.
              - Dr Seuss
              • Agent24
                I see dead caps
                • Oct 2007
                • 4981
                • New Zealand
                Only VIA thing I have ever had issues with was Ethernet controllers.
                -David VanHorn
                • Wizard
                  • Mar 2008
                  • 2296
                  There are many problems when there's high bandwidth devices in use and VIA cannot cope with it due to internal design not designed properly.
                  That what happens very often with creative audio cards.
                  Cheers, Wizard
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    My first lga775 system was a core2 e6600, which is nice (better thsn usually what i have), but it was bottlenecked by VIA SHITSET(oops i meant chipset),...
                    I have used via stuff sccessfully. But i still prfer not to
                      • 31094
                      i'v never had a problem, maybe it's drivers.
                      what i DONT like is Intel chipsets.
                      and most dead boards i see are intel chipset p4 junk.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Height of the bad caps era.
                        Imagine that...
                        I've never had -significant- problems with Intel or VIA chipsets.
                        Maybe a minor annoyance here or there I had to work around, but nothing major.
                        I don't trust SIS or nVidia at all. I don't consider them keepers.
                        If one shows up that works I flip it on to someone else. [Sell it.]
                        - Dr Seuss
                        • mockingbird
                          • Dec 2008
                          • 5484
                          CUR-DLS...
                          I saw a guy running 2 x Tualatins on that with some modified slotkets. He used thin but highly dense copper heatsinks so that the first slot would fit. I wonder if his page is still on the net. 2 x 1.7ghz Tualatins.... Drool. I bet it would show my Prescott a thing or two.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            A Pentium M is basically a Tualatin reworked for laptops.
                            Plenty of MODT boards take them and you get up to 2.16GHz, native USB 2.0, 400 or 533 FSB, DDR or DDR2, and low power use.
                            [And it will show your Prescott a thing or two.]
                            Most of them [Pentium-M MODT boards] use i855GM, i855GME or variants of the i915 chipset.
                            - Dr Seuss
                              • 31094
                              yep, SiS is bin material, i just desolder the battery holder, fets & any other interesting stuff like sata sockets & bin them.
                              same with PC-Chips crap.
                              i dont mind Nvidia as long as they arent cooked, i just put a big copper sink & fan on them and they seem o.k.
                              although i noticed within seconds the first time i got one that you burn your damned fingers on the original laughable sink.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4981
                                • New Zealand
                                SiS are lame\slow chipsets, but they do work. I mean, forget overclocking etc I guess but for the most part they are just fine.
                                I reckon most people hate them because they are cheap, and thus go on cheap boards with cheap capacitors etc which is not the fault of SiS.
                                -David VanHorn
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  it was the i845 with the ICH4 southbridge that started off with USB 2.0. an i845 with say an ICH2 southbridge did not have USB 2.0 support.
                                  Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    my hp thin client 1ghz "geode" amd cpu, fanless pc has a sis chipset. the chipset runs far hotter than the cpu. wierd huh?
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      that has more to do with heatsinks... chipset heatsinks tend to run hot... i have fan modded them before...
                                      ps- YAY! post #4500
                                      sigpic
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        yay! post 932
                                        edit: notice something odd about my post count numbers in the following screen shot?
                                        edit2: its a jpeg btw
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                          no-name Radeon 9600 XT recap and cooler
                                          by momaka
                                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                          This one was actually suggested to me by ChaosLegionnaire....
                                          11-06-2020, 07:54 PM
                                        • tsavpyn
                                          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                          by tsavpyn
                                          Dear all,
                                          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                          Now I have a problem that I am unable to dump my BIOS into bin file.
                                          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                          I searched for FPT but there is no Linux version and none of them work.
                                          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                          I would really appreciate it if anyone...
                                          05-28-2024, 11:18 PM
                                        • mr.malcom
                                          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                          by mr.malcom
                                          this is a very strange Problem:
                                          Notebook hang instantly on Boot. BIOS is accesable.
                                          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                          i have tried:
                                          - only one RAM Stick, another working RAM, both RAM channel
                                          - BIOS Flash to newest Version F.50, BIOS Reset
                                          - Memtest86 hang instant at Test 2
                                          - HP UEFI Diagnostic wont find...
                                          02-26-2022, 05:19 AM
                                        • varunviolin007
                                          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                          by varunviolin007
                                          Hi guys,
                                          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                          Looking for someone experienced with older PC boards who uses...
                                          07-29-2025, 11:53 PM
