Software for burn in?
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Hi!
    I will be replacing my bad GSC caps with Nichicon (2 PW rest HE) this weekend. What is good (read cheap/free) software to use to test and which OS does it run on? Will post bad/good pics at later date. Thanks.
  • Fatal0E
    • Jan 2004
    • 252
    Re: Software for burn in?
    www.ultimatebootcd.com
    bootable, has Prime95, Lucifer, and memtest
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Thats a buttload of stuff on one cd! Thanks!
      • cods69
        • Oct 2005
        • 92
        I have to get a new version of that - memtest was no good in UBCD 3.3
        EDIT: It's still at 3.3 ??
        • Spacedye69
          • Nov 2005
          • 698
          • US
          Stll at 3.3. Downloaded it couple days ago.
          • bobcaygeon
            • Feb 2005
            • 18
            In my overclocking endeavors I use a program called OCCT (http://www.ocbase.com/downocct.html). I've found that if I'm pushing the limits, OCCT fails faster than Prime95. Note: the page is french, but the software has english text. I would think this would be a good torture test, along with Memtest, and Prime95.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              404.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                http://www.ocbase.com/occt.html
                then click on download.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  just downloaded it.
                  always room for more tools.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    memtest86+ http://www.memtest.org/ which is supposed to be an improved version of the old one is quite good. 35mins for 1 pass of 2gb on p42.8 875 is ok with me.
                    • howardc64
                      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                      by howardc64
                      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                      • Backlight on, no image
                      • Disconnect right buffer board (view from front), left side display comes on
                      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                      • Buffer board is pretty simple
                      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                      07-11-2025, 04:04 PM
                    • irepair559
                      Ps4 1215a hdmi diode readings good everything good but no pic??
                      by irepair559
                      PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                      01-05-2023, 12:32 AM
                    • NeedsPractice
                      Backup To OneDrive Software? Everything! Best Software?
                      by NeedsPractice
                      I contacted Microsoft and they said they do not have software to where you could backup all your files to one drive. I mean you can copy some of your files to your one drive folder and back stuff up. However, it does not do this automatically.
                      I have around (10) hard drives I want to backup to the cloud with One Drive. What is the best software to do this with?
                      AOMEI Backupper
                      I Drive
                      Easeus
                      I do not want a Cloud Plan. I just need the software to take my DATA and Transfer it to the cloud in a nice, readable, viewable fashion. I wish...
                      02-04-2022, 06:04 PM
                    • Mgiffune
                      by Mgiffune
                      I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                      I ordered a supposedly β€˜new' Tcon board this time, and
                      06-09-2024, 10:28 AM
                    • the_rem
                      Unknown transformer : how to find a good replacement part ?
                      by the_rem
                      Hello guys,
                      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                      04-23-2025, 01:48 AM
