Slow SATA performance in Windows
  • yyonline
    • Jul 2009
    • 692
    So I was copying some files on my test rig, and I noticed it was taking a long time. I don't usually do file copying in Windows, so this may not be a new problem.
    Here's the setup:
    Abit IP35-E motherboard
    Silicon Image Sil3512 PCI SATA card (for hot swap capabilities/linux compatibility)
    Any drive hooked up to the Silicon Image card will not go any faster than 28 MB/s under Windows. I've tested with multiple drives. Drivers are the latest for both the Silicon Image card and motherboard chipset.
    The same drive on the same controller on the same computer in Linux will benchmark at 90 MB/s. So, I know the hardware is capable of faster speeds.
    The same drive on the same controller in Windows on another PC will benchmark at 90 MB/s.
    I swapped out the Silicon Image card for a VIA card, same problem. I tried a Promise SATA card, same problem. Again, only in Windows. All these controllers worked at full speed under Linux.
    I figured some Windows file must be corrupt, so I did a clean install of XP Pro, but no difference.
    I think my options are the following "failure points," but each one seems to be ruled out by something else.
    1 - Sil3512 controller failure. I ruled this out because it works full speed with Linux on the same PC. Also, other cards exhibit the same behavior.
    2 - Motherboard failure. I ruled this out because as with above, it works full speed with Linux on the same PC.
    3 - Bad Silicon Image Windows drivers. I ruled this out because the same controller and the same drivers work full speed on another PC in Windows.
    4 - Windows installation hosed. I ruled this out after a reinstall did not fix the issue.
    Anybody have any thoughts on how I can make my drive go full speed in Windows? I'm thinking it's some weird combination of incompatibilities I may never figure out, but I figure it can't hurt to see if anybody has any ideas. It definitely seems to be a software issue of some sort, as the drives have no issues in Linux.
    Any input greatly appreciated!
  • Wizard
    • Mar 2008
    • 2296
    Re: Slow SATA performance in Windows
    Benchmark is dubious unless it has proper methods of measuring performance.
    PCI is 33MB/s
    Cheers, Wizard
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      No, PCI is 33MHz and 133MB/s.
      Windows or your BIOS is probably putting you in PIO mode instead of UDMA.
      Mann-Made Global Warming.
      - Dr Seuss
      • yyonline
        • Jul 2009
        • 692
        Good suggestion about PIO mode. I don't know that it's the case, however. Drivers report UDMA mode, and CPU usage is low.
        The straight line graph suggests that something is limiting the drive speed in Windows. Even the min read speed in Linux is faster than Windows. It hasn't caused any other issues aside from slowness, however.
        • larrymoencurly
          • Oct 2004
          • 960
          I tested with XP Home SP3, HDtune, Hitachi 7K1000.C HDs (firmware 39C), SiL3512 (latest non-RAID firmware and driver), Promise 20378, and motherboards equipped with either VIA KT400, Nvidia MCP-61, or Intel G41/ICH7 chipsets. Performance was slow only with the Promise card and Nvidia chipset and on the boot HD, when it was <50MB/s average and varied widely. Otherwise the average was 84-90 MB/s.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            There should be an option for disk cache in device manager, I notice it says enabled in the SIL control panel but make sure it's enabled in device manager for the disk too
            I don't expect the issue is this, because I assume you are not using Win2K3/XP x64, but that can have it's own issues as I found out;
            http://www.techspot.com/blog/224/slo...rver-2003-x64/
            • Wizard
              • Mar 2008
              • 2296
              My apologies on that figure. I remembered day after that I erred. 133MB/s is correct now I remember. Brain fart.
              Try different card with good chipset and known good windows driver support.
              Cheers, Wizard
              • yyonline
                • Jul 2009
                • 692
                I've tried Silicon Image, VIA, and Promise. All have different, but similarly bad performance. VIA is a flat line at about 38 MB/s, and the Promise controller is a flat line at about 14 MB/s.
                All of these work full-speed in Linux on the same PC.
                Does anybody have a suggestion for a PCI SATA card that has good Windows driver support, but will still work with Linux-based disk wiping software and Norton Ghost?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I don't think it's drivers per se.
                  http://winhlp.com/node/10
                  - Dr Seuss
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    The only other PCI SATA controller chips I've heard of are HighPoint, Initio (INIC-1620, 1622, 1623xx?), and maybe ITE.
                    Is it possible the SATA cards are slow because they're sharing an interrupt with something else?
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      maybe the hard drive itself?
                      sigpic
                      (Insert witty quote here)
                      • yyonline
                        • Jul 2009
                        • 692
                        It does it with multiple drives, Western Digital, Seagate, Hitachi... So I think this rules out a bad hard drive.
                        I don't think it's in PIO mode. The speed might suggest that, but the CPU usage does not. I usually see 90+% CPU usage during heavy disk activity if a drive is in PIO mode. I don't see that here, just slowness. Additionally, there are no options to set the PIO/DMA mode in Windows. That's all handled by the card's bios as it's running in AHCI mode.
                        Hmm, all the Highpoint controllers are a bit pricey. I can't find any of the others on newegg. So, I just ordered a Initio controller from eBay. I probably don't want to spend too much money on this.
                        It works fine as it is now, just slower than ideal. All I use that PC for is backing up customer's PCs and wiping disks before trashing them. It would be nice to have the extra speed, but it's not holding me back much.
                          • 30978
                          i was thinking that, 4k sectors?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            How are you connecting the customers drives?
                            ... Sure it's not a slow USB adapter problem?
                            - Dr Seuss
                            • bgavin
                              • Jan 2007
                              • 1355
                              I use the IP35 board, not the "-E" suffix, so not sure of what that means.
                              Q: does this board not have onboard SATA for some reason?
                              Mine has 6 connectors, and runs full tilt.
                              Sad, but no more BIOS from ABit. They have died.
                                • 30978
                                try a new cable - sata is single-strand and they break easy.
                                • yyonline
                                  • Jul 2009
                                  • 692
                                  I plug the drives straight in with a SATA cable to the PCI card. No USB involved.
                                  The motherboard does have onboard SATA, 4 ports, but they only run in IDE mode, ACHI is not available with the IP35-E. So, no hot swap capability. Older linux (which is used by a lot of bootable disk utilities) and Norton Ghost haven't a clue what to make of it. Also, I have 3 of 4 ports used by various drives. Thus, the PCI controller.
                                  It does this with multiple SATA cables.
                                  • severach
                                    • Aug 2007
                                    • 1055
                                    I like my Rosewill RC-216 with the JMicron JMB363. The only fault I've found is that the JMicron BIOS adds too many retries so it can't be used to recover drives with bad sectors in places that drive the OS crazy. Performance is good and the bootable disk images are compatible with Intel controllers.
                                    sig files are for morons
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Like it's 2001. lol
                                      ASRock B550 PG Velocita
                                      Ryzen 9 "Vermeer" 5900X
                                      Arc A770 16 GB
                                      eVGA Supernova G3 750W
                                      Alienware AW3423DWF OLED
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        It don't look like it's in PIO mode, because PIO mode is 4 MB/s or 5 MB/s.
                                        PIO mode makes even 28 MB/s look like a speed king!
                                        Arc A770 16 GB
                                        • nissimezra
                                          HP Notebook 15-dy1731ms VERY SLOW
                                          by nissimezra
                                          Hi to everyone.
                                          I never seen something like this. I have HP Notebook 15-dy1731ms motherboard: DA0P5DMB8CO REV C that is very very slow. I tried all the basic, updating the bios, replacing ssd, replacing ram, soldering all coils, reflow CPU power supply but the laptop is still very very slow. Never seen a motherboard that is slow. CPU power suppliers 1.8 volts, the cpu barely getting hot.
                                          What left for me to do is reflow the CPU and try manually programing the bios chip with programer.
                                          Anyone have any idea what it can be?
                                          04-13-2023, 02:45 PM
                                        • EthanMai
                                          DELL PRECISION 3440 SFF X4N41 10th ST-3L0GZB3 25Q256 Slow startup, needs cleaning.
                                          by EthanMai
                                          DELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
                                          ST-3L0GZB3
                                          needs cleaning.
                                          Please help me clean up the slow startup dump if you have time. Thank you....
                                          07-05-2024, 11:43 AM
                                        • mo000
                                          ACER CONECPT D VERY SLOW
                                          by mo000
                                          Hi
                                          acer concept d intel i7 11th GH67G LA-L211P REV 1A 17-03-2021
                                          the laptop dead by water on keyboard
                                          i open the laptop i don't find any water on the motherboard or any damage
                                          the laptop turn on without battery
                                          i found shorted mosfet on smbus battery i remove it the laptop turn on with a battery but not charging
                                          the big problem is the laptop is very slow
                                          cpu works with low speed almost 0.7ghz
                                          i do clean me bios but samething
                                          what make laptop works with low profile and very slow the display takes long time.
                                          06-10-2024, 04:27 AM
                                        • mr.malcom
                                          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                          by mr.malcom
                                          this is a very strange Problem:
                                          Notebook hang instantly on Boot. BIOS is accesable.
                                          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                          i have tried:
                                          - only one RAM Stick, another working RAM, both RAM channel
                                          - BIOS Flash to newest Version F.50, BIOS Reset
                                          - Memtest86 hang instant at Test 2
                                          - HP UEFI Diagnostic wont find...
                                          02-26-2022, 05:19 AM
                                        • tsavpyn
                                          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                          by tsavpyn
                                          Dear all,
                                          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                          Now I have a problem that I am unable to dump my BIOS into bin file.
                                          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                          I searched for FPT but there is no Linux version and none of them work.
                                          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                          I would really appreciate it if anyone...
                                          05-28-2024, 11:18 PM
