Slow SATA performance in Windows
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Slow SATA performance in Windows
    OMG! The burst rate looks like it's from 1999!
    (even though not as bad as PIO!)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Wizard
      • Mar 2008
      • 2296
      What are everybody *talking about*?! IP35 board is P35 chipset and I also this in P5K and it is in DMA mode fully supporting SATA.
      Download intel chipset INIT drivers for that chipset you have in yours. This will take care of your IDE mode issues. This is done FIRST thing after XP install then graphic drivers.
      PS: SATA is still not hot swap, at least in consumer stuff. *Even* the ESATA.
      Cheers, Wizard
      • yyonline
        • Jul 2009
        • 692
        I wasn't having issues with the onboard controller, but an add-in controller. I've since given up. No add-in controller works full speed in Windows on that board, even though they have no speed issues in Windows on other boards. I don't do any disk wiping/cloning in Windows...and it works full speed in Linux...so I just called it good enough for now.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          sounds like a chipset issue... your PCI bus is slow. chipset driver must be a flop. thats my guess.
          sigpic
          (Insert witty quote here)
          • bigbeark
            • Jan 2010
            • 661
            Originally posted by yyonline
            I've tried Silicon Image, VIA, and Promise. All have different, but similarly bad performance. VIA is a flat line at about 38 MB/s, and the Promise controller is a flat line at about 14 MB/s.
            All of these work full-speed in Linux on the same PC.
            Does anybody have a suggestion for a PCI SATA card that has good Windows driver support, but will still work with Linux-based disk wiping software and Norton Ghost?
            Which VIA PCI Sata card is working under Linux? I see no support on their site for Linux in add-on SATA cards.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Linix works with most stuff with its built-in unversal drivers.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                not fully. VISA and linux do not mix. the only VIA linux drivers were reverswd engineerd spound drivers. VIA onboard graphics and drive controllers are genaric crap only... poor, barebones performance.
                think windows before you install graphics drivers...
                sigpic
                • nissimezra
                  HP Notebook 15-dy1731ms VERY SLOW
                  by nissimezra
                  Hi to everyone.
                  I never seen something like this. I have HP Notebook 15-dy1731ms motherboard: DA0P5DMB8CO REV C that is very very slow. I tried all the basic, updating the bios, replacing ssd, replacing ram, soldering all coils, reflow CPU power supply but the laptop is still very very slow. Never seen a motherboard that is slow. CPU power suppliers 1.8 volts, the cpu barely getting hot.
                  What left for me to do is reflow the CPU and try manually programing the bios chip with programer.
                  Anyone have any idea what it can be?
                  04-13-2023, 02:45 PM
                • EthanMai
                  DELL PRECISION 3440 SFF X4N41 10th ST-3L0GZB3 25Q256 Slow startup, needs cleaning.
                  by EthanMai
                  DELL PRECISION 3440 SFF X4N41 10th 25Q256 Slow startup
                  ST-3L0GZB3
                  needs cleaning.
                  Please help me clean up the slow startup dump if you have time. Thank you....
                  07-05-2024, 11:43 AM
                • mo000
                  ACER CONECPT D VERY SLOW
                  by mo000
                  Hi
                  acer concept d intel i7 11th GH67G LA-L211P REV 1A 17-03-2021
                  the laptop dead by water on keyboard
                  i open the laptop i don't find any water on the motherboard or any damage
                  the laptop turn on without battery
                  i found shorted mosfet on smbus battery i remove it the laptop turn on with a battery but not charging
                  the big problem is the laptop is very slow
                  cpu works with low speed almost 0.7ghz
                  i do clean me bios but samething
                  what make laptop works with low profile and very slow the display takes long time.
                  06-10-2024, 04:27 AM
                • mr.malcom
                  HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                  by mr.malcom
                  this is a very strange Problem:
                  Notebook hang instantly on Boot. BIOS is accesable.
                  Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                  Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                  i have tried:
                  - only one RAM Stick, another working RAM, both RAM channel
                  - BIOS Flash to newest Version F.50, BIOS Reset
                  - Memtest86 hang instant at Test 2
                  - HP UEFI Diagnostic wont find...
                  02-26-2022, 05:19 AM
                • tsavpyn
                  Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                  by tsavpyn
                  Dear all,
                  I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                  Now I have a problem that I am unable to dump my BIOS into bin file.
                  My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                  I searched for FPT but there is no Linux version and none of them work.
                  I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                  I would really appreciate it if anyone...
                  05-28-2024, 11:18 PM
