Dell 4700 circuit breaker
  • styxbound
    • Aug 2010
    • 91
    Anybody know anything about a little black plastic and metal can rig on a Dell 4700 and some other dell boards called a circuit breaker? Trying to find some way of replacing one but don't know just how it works.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dell 4700 circuit breaker
    Called a circuit breaker by who?
    Photo Please.
    Maybe some numbers...
    Mann-Made Global Warming.
    - Dr Seuss
    • styxbound
      • Aug 2010
      • 91
      Some time back there was a review I read on the 4700 which mentioned this thing they called a circuit breaker; now I can't find it again nor another reference to it. Can't take a picture because I don't own a camera, first, and second, totally destroyed the thing trying to figure out how it works. From the three pieces which fell out of the little can it's probably just mechanical but can't be sure.
      • Quasar
        • Sep 2010
        • 132
        Where on board?
        How about finding a picture of your board? Maybe on ebay?
        What markings on the board next to it?
        Found a ebay pic for M3918 mobo. This yours?
        • styxbound
          • Aug 2010
          • 91
          The board is an E210882. I'll see if I can find a photo somewhere. Thanks for the comebacks, guys.
          Excuse my idiocy. I just realized your photo does show the thing. It's the T-shaped black plastic near the sata ports.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            E210882 is not a model number.
            It's kind of like the Aussie version of a UL number.
            Many models of boards will have the same number.
            Model number is in the string on the bar code sticker and would be something like M3918 or DH682.
            I can't see the part well enough to tell what it is.
            Dell docs don't mention a circuit breaker at all.
            - Dr Seuss
            • Quasar
              • Sep 2010
              • 132
              Is this it? Search on ebay finds 22 hits on that number.
              Far back corner in between the SATA connectors?
              • styxbound
                • Aug 2010
                • 91
                There are two sets of numbers by bar codes: aa c58993-206 and ds/n cn-om3918-70821-52n-01wd:c/0 cn.
                There's also a small barcode tag with Dell rev.a01.
                The dell service tag and express code is on the machine too, but I've had no luck with that.
                • seanc
                  • Nov 2008
                  • 1319
                  Think I may have a dead one of these boards at work. Will check Tuesday.
                  • styxbound
                    • Aug 2010
                    • 91
                    That would be nothing short of fantastic!-this thing is bugging me silly.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      It's OM3918
                      - Dr Seuss
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        maybe an intruder switch... those were common finds on optilex units... dimension, not so much, but it comes to mind.
                        sigpic
                        (Insert witty quote here)
                        • seanc
                          • Nov 2008
                          • 1319
                          Optiplex tended to have switches near case openings though.
                          Not sure there is one on the 4700, or whatever it is I have in the office. I rebuilt it as a test unit a couple of weeks ago.
                          • styxbound
                            • Aug 2010
                            • 91
                            This machine doesn't have a case switch. I don't think there's any way it could have anything to do with intrusion.
                            • yyonline
                              • Jul 2009
                              • 692
                              The black plastic thing between the SATA ports is a crystal oscillator in a cylindrical package. The black plastic is around it merely to hold it in place against the board.
                              • styxbound
                                • Aug 2010
                                • 91
                                Now I'm really freaked out! I'm sure the review was calling it a circuit breaker; they even commented on turning it off and on. Need to find the damn thing again. But what you say certainly seems reasonable by what I saw of the thing.
                                  • 31265
                                  that's no crystal.
                                  maybe it is a circuit-breaker.
                                  maybe it's a thermal breaker to limit current to something.
                                  let's face it, the surface-mount polyfuses dont work too well - they burn up sometimes.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Most certainly could be a crystal.
                                    Crystals come in many different packages.
                                    If it were a circuit breaker that means users might have to operate it and it would be in the manual.
                                    Not only does the manual not mention a circuit breaker, the component isn't shown on the mobo drawing at all.
                                    - Dr Seuss
                                    • Quasar
                                      • Sep 2010
                                      • 132
                                      2 similar boards with the same device next to the SATA connectors. If it was a circuit breaker or a crystal, how would it relate to the SATA ports?
                                      • styxbound
                                        • Aug 2010
                                        • 91
                                        Guys, I don't recall the article saying it had anything to do with the sata ports. STILL can't find the damn thing.
                                        When I took the can apart three tiny pieces fell out. Two were maybe a bit longer than 1/8" and perhaps less than 1/64 wide, flat and shiny. The third was a rectangle maybe 1/32 by 1/16. The color was different from the strips. I can say it wasn't a quartz crystal, but it may well have had a coating of some kind.
                                        According to the article the thing was supposed to be able to swing up, though when I found it, it was already loose and my efforts to swing it up completed the job of tearing it off.
                                        • Geeker007
                                          9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                          by Geeker007
                                          Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                          I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                          So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                          01-28-2025, 03:31 PM
                                        • Thomas Dunlap
                                          Request Dell G16 7630 LA-m536p circuit diagram and board view
                                          by Thomas Dunlap
                                          Hello looking for a circuit diagram and board view for la-m536p. Thanks in advance
                                          Included the specific model detail below:
                                          Reg model: p122f
                                          Model: Dell G16 7630
                                          ST: h2tm044
                                          08-25-2025, 03:04 PM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • Powderfanupnorf
                                          Dell AL440LX power on switch circuit help required
                                          by Powderfanupnorf
                                          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                          06-24-2024, 01:24 PM
