SATA PCI Cards?
  • bgavin
    • Jan 2007
    • 1355
    Re: SATA PCI Cards?
    Has anybody come across an add-in card that will do RAID1 in hardware for ESX?
    I'd like to do my ESX 4.1 (vmware) hosts in RAID1, but don't want to pony up a grand for an "approved" card.
    • larrymoencurly
      • Oct 2004
      • 960
      Re: SATA PCI Cards?
      Don't get a VIA VT6421x card because it won't handle drives configured for 3.0 gigabits/second SATA, only 1.5gb/s. Get a Promise or Silicon Image card instead. Silicon Image provides lots of support and even schematics. Booting from these cards is no problem, and Silicon Image supposedly supports it even for optical drives (I have no SATA opticals to test that). BTW, Silicon Image cards have a RAID/non-RAID jumper, but their BIOSes don't seem to recognize it, even though their non-RAID BIOSes have code in them to set up RAIDs.
      I bought a used Promise clone PCI card from Ebay dealer Y&L Cabin for $12 and several Silicon Image SiL3512 cards from Novatech for about $3 apiece, delivered. The latter were advertised as used and sold as-is, but every one of them was brand new and worked fine. The Silicon Image cards were identical to some sold by Newegg for $10-20.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Re: SATA PCI Cards?
        One word on that - DO NOT flash a non-RAID BIOS on a RAID Silicon Image card, even if you only have a single drive on that card. You will have to reinstall Windows if you do that (or put a RAID BIOS back on it).
        A working TV? How boring!
        • bigbeark
          • Jan 2010
          • 661
          Re: SATA PCI Cards?
          Thanks for this. I found some SlL3512 cards for $15 with free shipping from HK,
          Novatech88 has them for $3 but the ship to Canada is $32!!
          • bigbeark
            • Jan 2010
            • 661
            Re: SATA PCI Cards?
            They work just fine for me.
            Are you using Linux?
            I much prefer Linux to Windows, would like a card that can do both.
            Found the following article about this: http://linuxmafia.com/faq/Hardware/sata.html
            I have deduced that only the RAID cards are bootable, and for Linux the "software raid" (fake raid) cards pose more problems that the hardware raid cards. I assume the hardware raid cards are the expensive ones. Probably too new to have hit the computer recyclers.
            Seems that the best choice for old boards is still SCSI!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #26
              Re: SATA PCI Cards?
              No, i'm using XP on that computer. There are two things keeping me on 'doze: Games and fonts. I hate Linux fonts with a passion. Did try Mandriva Linux on it tho, and it worked fine.
              Don't get me wrong, Linux is an awesome OS for servers (my PC-based router runs FREESCO), or for desktop use if you're willing to learn. However the open-source code is no good if it's managed by people with closed minds - see the Ubuntu community, they absolutely refuse outside suggestions, and screw up more and more stuff every new release. Ubuntu 8 was fine, 9 started getting messy, and in 10 they barely fixed half what they broke in 9.
              If i would migrate to Linux, i'd have to build my own distro. As much as i'd love that, i have no time for it.
              Whirrrrrrrr... churn... barely faster than a 320 gig IDE, and completely obliterated by any SATA drive on whatever controller card you choose. No thanks.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: SATA PCI Cards?
                Actually no.
                The interface speed hasn't been the bottleneck on drive performance in 8 to 10 years.
                The bottleneck is the head-disk transfer rate and that is not significantly different between SCSI, IDE or SATA.
                Mann-Made Global Warming.
                - Dr Seuss
                • bgavin
                  • Jan 2007
                  • 1355
                  #28
                  Re: SATA PCI Cards?
                  Using HD-Tach, the best IDE is low 90s, and typical 230 MB/s transfer rates for Caviar Black SATA-II.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: SATA PCI Cards?
                    That's only true for short files in burst mode.
                    Once the 32MB of buffer is full on the Caviar Black you will be back down to ~90Mb/s for the rest of the transfer.
                    Also, it's not a legit comparison if you aren't using drives with the same size buffer [and RPM].
                    - Dr Seuss
                    • yyonline
                      • Jul 2009
                      • 692
                      Re: SATA PCI Cards?
                      This isn't a problem anymore with the newer bios revisions of VT6421A. I have one in my test rig, and it detects 3.0Gbps SATAII drives just fine. They only operate at 1.5Gbps, as that's the speed of the card.
                      I've also used SIL3512 and SIL3112 cards with no major issues.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #31
                        Re: SATA PCI Cards?
                        I know this. But on Ultra 2 Wide SCSI which is typical of the PII and PIII days, drives weren't too fast compared to modern IDE offerings. We were talking about onboard SCSI vs SATA card, weren't we?
                        • bigbeark
                          • Jan 2010
                          • 661
                          Re: SATA PCI Cards?
                          I use Adaptec SCSI 160 cards and 10k spin Fujitsu Drives. I have two Prescott 3Ghz 478 machines, one with a 40GB WD, the other with a 73GB Fujitsu, and the SCSI machine is way faster.
                          On my old PIII machines, I routinely use SCSI so I don't have to fool around with the Bios settings for IDE.
                          Of course, I bought all this stuff as recycled parts so the cost was pretty low, typically 5 to 10 dollars per card. I could pickup the SCA adapters cheaply from Ebay, Biggest expense was probably the SCSI cables.The Fujitsu drives have much quieter bearings than the others. The Seagates run too hot and the Quantum/Maxtors clank.
                          Slowest Drive I ever encountered was a 5400rpm spin Maxtor IDE. Couldn't understand why a Tualatin 1100 could be slower than a 550 Katmai!
                          I realize SATA is much faster than IDE, but of course, older machines do not have the
                          controller onboard, hence my questions and your much-appreciated answers.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: SATA PCI Cards?
                            Comparing old SCSI to new SATA are we? - SCSI hit 160Mb/s in 1999 which was still "PIII days".
                            Thread title says "PCI cards" which clearly indicates PCI add-in cards.
                            The common PCI bus is capped at ~133 Mb/s by bus limitations with is another reason interface speed just doesn't matter.
                            - Dr Seuss
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Re: SATA PCI Cards?
                              besides, most mentioned that are "raid" are really fakeraid.
                              my personal advice: if you buy fakeraid, do not use it as raid, your performance will suffer!
                              besides, 2 port hardware raid cards can be found on ebay cheap... <$20 got me a 2 port 133ATA 3ware card...
                              sigpic
                              (Insert witty quote here)
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #35
                                Re: SATA PCI Cards?
                                Which still doesn't make SCSI faster than SATA in this particular application.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: SATA PCI Cards?
                                  Yes, But SATA isn't faster that SCSI in a PCI slot either.
                                  So, your point is?
                                  - Dr Seuss
                                    • 31298
                                    Re: SATA PCI Cards?
                                    scsi handles a lot of the low-end work in hardware, ide/sata puts most of the work on the host cpu.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #38
                                      Re: SATA PCI Cards?
                                      Originally posted by stj
                                      stay away from "sil" series chips,
                                      looking through the Linux kernal source a while back to see if a specific chip was supported, i saw all kinds of comments in the code about hardware bugs/issues on those chips!
                                      What? I use Kouwell 571B, the most common ccontroller with SiL 3112 here, just fine with Ubuntu server. You can buy second-hand one for as low as 5 US bucks or so.
                                        • 31298
                                        Re: SATA PCI Cards?
                                        i didnt say they wont work, but they lack some higher features because the driver has to skip some of them.
                                        • larrymoencurly
                                          • Oct 2004
                                          • 960
                                          Re: SATA PCI Cards?
                                          It's good to know that VIA finally got it right. Even at VIA's support forum, the moderators still tell people that the VT6421A is incompatible with 3.0Gbps drives and the BIOS doesn't support anything bigger than 750GB.
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                          • clabr
                                            Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                            by clabr
                                            Need help to solve some problems with this laptop.
                                            After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                            After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                            Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                            Before this had happened I observed some other problems:
                                            When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                            12-02-2021, 08:09 AM
                                            Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                            by momaka
                                            Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                            11-28-2020, 11:08 PM
                                          • playit
                                            psu sata power wires thinner - does it make a difference ?
                                            by playit
                                            hello , i have a psu 450 zebronics (yes its bad crap) which used to work before with its own sata power cable ,but today its not able to power up harddrive efficiently with its own power sata cable , but when there is a connector which have a thick wire than the psu sata power cable wires - its powering up and working smooth , no problem yet .
                                            i the voltages with multimeter shows 12 ,3.3 v , no problem , but hardrives powers well only with this thick wire sata power cable connector from psu power molex .
                                            any explanation on this ?? thank you ,soon i am planning to buy some branded...
                                            10-12-2023, 05:25 AM
                                            HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
                                            This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-12-2024, 03:28 PM
