DIY PSU load tester
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    #81
    Re: DIY PSU load tester
    It looks awesome... like something out of Half-Life 2...
    -David VanHorn
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #82
      Oh my god! It's huge!!!
      You really did a very good job. Please test as many power supplies as possible.
      Congratulations from Greece!
      • c_hegge
        • Sep 2009
        • 5219
        Originally posted by goodpsusearch
        ...Please test as many power supplies as possible...
        Will do. I've already tested 3 (1 of which survived) and one of these is next in line.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          #84
          Mmm switches. My meters have arrived, but only six of them, waiting on another four. I also have to decide upon the size of switch that i'll be using for the short circuit test. Only when all of them are here will i be able to start cutting the front panel.
          In the meantime i'll be designing the ripple meter circuit. Coz IMO the point of my load tester isn't as much testing the power output (although it will be VERY able to do so), but rather testing voltage quality. Just like Hardware Secrets does.
          A working TV? How boring!
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            #85
            I thought ripple was best measured with an oscilloscope for a good visual representation?
            -David VanHorn
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              It is.
              Mann-Made Global Warming.
              - Dr Seuss
                master hoarder
                • May 2008
                • 12175
                #87
                Originally posted by c_hegge
                Here. It looks horrible, I know, but it works.
                Exactly. As long as it works, that all that matters.
                Welcome to the Black Mesa Research Facility. The time is 8:47 am. Today, you will test power supplies with this new PSU tester of doom. Please put on your hazardous suit.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #88
                  Yes. I will be using my 'scope as reference to calibrate the meters, but i want something self-contained and that displays all rails simultaneously. As long as the peak value is read correctly, it doesn't matter what you use to read it.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Not certain but I think the meter response time will be too slow all you will see is the average DC.
                    - Dr Seuss
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #90
                      Not if i separate the ripple (AC component) from the DC, amplify it, rectify and filter, THEN apply it to the meter.
                      • Ken256
                        • Oct 2009
                        • 25
                        #91
                        Interesting reading, I enjoy seeing other people's projects. I just started prototyping an active load tester. Right now I am using 2N3055 bipolar transistors mounted to old cpu heat sinks. The cpu heat sinks give really good performance when provided with ventilation. I measured a temperature rise of 15 degrees with 90 watts dissipation, so about 0.17 C/W. They just get warm to the touch. I should still have some margin at 90 watts.
                        I think with my next setup I will try some AOT430 mosfets. They are supposedly rated for 268 watts in a TO-220 package. I'm a bit skeptical that a TO-220 package can dissipate near that much power. But they're cheap, only $1.30.
                        Here's a question for people using mosfets in their load tester. Can the mosfets be connected in parallel, drain to source directly? Mosfets should share the load equally because channel resistance has a positive temp coefficient? Right now I am using 0.33 ohm emitter resistors in my active load tester to ensure load sharing.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #92
                          Yes. The only time i blew some of mine was when i didn't screw them to the heatsink tight enough, and they wiggled loose. With bipolars you need emitter resistors, with MOSFETs you don't.
                          I'm waiting on the last batch of meters and will decide on the type of switches today. I already have bought a 50 watt 12-0-12 transformer, should be enough for powering the 8 fans and all associated control circuitry. You'll be soon seeing a nice front panel. I'm also going to be prototyping the first ripple meter in the next few days.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I made a few modifications to mine. I added a slightly molded and bent PSU case to the end to use as a duct for hot testing and I found some of those 250CFM Delta fans on Fleabay for only $80 for 3 of them. I'm going to replace the two 120mm fans with them as the bottom gets a bit hot when I set it for drawing 350W or more. It should run cooler that way. I just hope the neighbours don't complain about the noise.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #94
                              Good one.
                              The ripple meter design is good to go on mine - it's just that i've caught a nasty cold and what doesn't run thru my nose, runs thru my eyes. As you would imagine, constantly teary eyes are rather impairing.
                              • c_hegge
                                • Sep 2009
                                • 5219
                                Sorry to hear. Hope you get better soon.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Oh dear! I think I'm going to go deaf soon. I replaced the two 120mm fans with the deltas and the airflow is lovely but it sounds like a jet engine
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #97
                                    Time for a fan speed controller methinks.
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #98
                                      <<----performs New York CPR....
                                      *kick*
                                      *KICK*
                                      Get UP!! You're blocking the sidewalk!
                                      veritas odium parit
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #99
                                        If this is supposed to be a reminder, well, i have all parts AND found a case for it too. Now it's just gonna need a little more time. I have lots of stuff to do not mentioning that second semester at uni is starting next week...
                                        I'm going to start making the main controller board since everything else patches into it.
                                        • Toasty
                                          • Jul 2007
                                          • 4171
                                          #100
                                          Okay. Good.
                                          It covered a lot of ground in 2-1/2 months then dropped dead.
                                          Thought maybe you got stunned or something...
                                          veritas odium parit
