Server equipment... slow boot?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Is it normal for servers to take an eon to boot?
    I have two "server class" machines/boards now, with ECC RAM. Both take an eon and a half to boot.
    The specific one I have is a Supermicro board with an atom c2550 chip in it. It takes forever, almost a minute before it initializes vga if at all (for some reason it doesn't even init the onboard VGA port, I have to stick in a PCIe card). Machine almost seems dead before then.
    The other machine is an Itanium machine, likewise does not init VGA until at least a few minutes after power up.
    Yes perhaps it's because I'm used to consumer quality equipment that initialize vga pretty much right away or at least a few seconds you can see BIOS startup, but is this normal for server class machines?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Server equipment... slow boot?
    Good question.
    Well, I do remember some old P4 Xeon servers used to take a while, but haven't done much with servers since then.
    That said, my Dell Precision T-7500 workstation with ECC RAM also takes forever to boot... though not as long anymore, ever since I removed the 2nd CPU riser board (with extra RAM). It takes maybe 5-10 seconds or so before I get video output. Before that, it'd take around 20-ish seconds. Certainly not a minute or longer, though.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      just wanted to mention it's not because of the ECC ram, just a coincidence (as in coincidence is not causation). Still odd. As far as I know it's not testing ram during the dead time, or perhaps it is. I thought the Atom was dead at first because it didn't respond for so long.
      I decided to let it wait and it finally sprung to live -- after i pulled all the RAM and got the expected beeping behavior when the first 64K RAM is dead, ever since the first PCs.
      BTW this atom is slow...been over 2 hours and it still hasn't finished one pass of testing its mere 16GB of RAM.
        • 31092
        Atom is not a server cpu, it's a cutdown chip designed for tablets, school laptops and raspberry-pie type stuff
        go into the bios and disable onboard video if your using a card - see what that does.
        or check the vga settings related to stuff like shared ram
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Yes, perfectly normal for real server & workstation stuff. POST is slow. SAS & RAID controllers are slow....but once past all that, ready to rock.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Atom is actually quite often used for microservers. Again this is a Supermicro board (mATX), and it has standard full sized SATA and PCIe ports.
            TBH there is no reason why a server should be so slow to initialize VGA and simply display POST status while booting, they have the same type of hardware as a client machine - the only exception theoretically is just RAM.
            Should add that both the Itanium and this Atom board have IPMI, SOL, and console redirect... so it indeed is a server type board... I haven't decided yet whether to just completely run this atom headless if I can't get the vGa to work.
            Damn my capitalization. I need to fix my keyboard.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Perfectly normal for a SM.
              FWIW, I've found the atom to be fine for light duty servers. Once upon a time, this site ran on a Pentium 3.
              Team : 49813
              Join in!!
              Team Stats
              • diif
                • Feb 2014
                • 6978
                • England
                No ammount of puff can make that a real server.
                It's to make a networking device or a NAS.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  That would be a light duty server.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    That's not enterprise then is it, it's a toy.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Now I wonder if I will notice anything if I swap this in for my old c2q "server" (it's a desktop machine used as a home server). The c2q is a faster machine for general purpose use, but this thing has more RAM (so I can run more VMs) and has AES-NI, so I don't need to worry about tossing my hard drives anymore when they fail...
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Is your motherboard on this list ? https://www.auvik.com/franklyit/blog...el-atom-c2000/
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I guess if it's an intel c2000 chip it would be on that list, but would that not cause no POST at all? it does boot, just takes a while.
                          it also notices right away when there's no ram installed...
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            What motherboard do you have ?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Heh, I think I found out how to implement that avr54 board level fix on my board, i think I'll go do it tomorrow as a proactive fix. Alas i don't think this is causing the slow boot as it would be a completely dead system versus slow boot, alas it shows that intel still fscks up designs.
                              • dmill89
                                • Dec 2011
                                • 2534
                                There's been plenty of low-spec "enterprise" server gear over the years for specific use cases (such as a NAS/print server in a small branch office), case in point this HP Proliant Microserver I posted on the cheep/free awhile back, which HP specifically marketed as for offices with 10 clients or less.
                                Specs:
                                CPU: AMD Turion II Neo N40L
                                GPU: integrated
                                RAM: 4GB DDR3-1600
                                HDD: none/removed, 4 3.5" bays
                                ODD: none
                                OS: none
                                I'm not sure how useful a server with an old laptop CPU is, but it is impressive how much HP managed to cram in that little box, 4 3.5" drive bays and a 5.25" bay, as well as 2 pic-e slots.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  This.
                                  Plenty of lower powered enterprise servers around.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • charleslam
                                    • Feb 2023
                                    • 7
                                    Supermicro boards tend to be slower at boot up. This extends to some HEDT and workstation boards as well. It also depends if you have memory testing enabled at boot, that can drastically extend boot times.
                                    now that i think about it, i dont think i have ever owned a server board that would boot up right away like a consumer grade board would.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Yeah, there's a lot of small specific purpose applications these slow server cpus will nicely fit. One thing they do not do is being part of compute farms for HPC, but if all they're doing is shuffling bits around (and even for this specific atom, encryption) it works very well.
                                      I do wonder whether that proliant takes an eon and a half to at least initialize its video? i don't think hp uses supermicro or do they?
                                      Currently building gcc (Gentoo) on this board to stress test. It's been chugging away at 100% CPU utilization, system is using about 42 watts right now though idles at around 39W (non 80+ PSU) - seems a bit high but it might be the old PSU. I think my single core atom cpu took around 12-16 hours to finish gcc, I suspect this should take less than a quarter of the time, will be interesting to see if it finishes it in an hour or so - 3 to 4 hours total.
                                      • charleslam
                                        • Feb 2023
                                        • 7
                                        I dont think HP uses supermicro. HP does alot of other stuff though. IPMI comes to mind with HP (aka their ILO remote management stuff). really depends on the configuration, but yeah taking long at boot is par for the course in server world from what i can see.
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • mamado mosa
                                          Slow boot dell latitude 5410 laptop issues
                                          by mamado mosa
                                          So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                                          The problem is it takes more than a minute to boot ..
                                          The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                                          Can someone suggest something to fix
                                          06-19-2025, 06:55 AM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Stephen
                                          A1990 MacBook Pro 15" Turning on, loads then boot loops, fan spin slow and then fast
                                          by Stephen
                                          Got a MacBook Pro 15" A1990 with a board issue, The board turns on, I did a DFU revive to see if it needed a firmware patch, that was successful, however the board just keeps boot looping and turning off and on very quickly. Obviously the DATA Is there, but it wont even launch into recovery, it will just die and turn back on with Apple logo, once it gets really hot it dies, if the laptop sits for the day and is cool, it will turn on then get hot within 1 min then die and turn itself on and repeat. Once it does that it turns itself on and off repeatedly in seconds. I put a thermal camera...
                                          10-04-2024, 02:50 PM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
