imac g5 dvd hell
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    imac g5 dvd hell
    calling all mac experts!
    i recently came into one of the first polymodded g5's. it is a gen 1 17" imac g5
    i have a major issue
    the superdisc drive seems to be dying. first, it would not burn dvd's. now it spits out anything i throw at it.
    it does it both in OS x 10.4 and in ubuntu ppc.
    it is a pioneer drive
    my guess is i need a new drive... any advice otherwise?
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: imac g5 dvd hell
    i take back the reads nothing part-
    it will read:
    os tiger cd's
    ubuntu ppc cd
    blank-cd-r's
    will not read:
    cleaning cd
    any dvd
    still think it is dying... but i want a second opinion.
    sigpic
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I'd render a guess that its dying. Use an external USB for anything except booting (they won't boot from a USB). I am told they will boot from a firewire external.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • 31296
        dont use a "cleaning cd" open the drive.
        blow out the dust & clean the laser.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          you think that could be it? it uses some funky torx screws...
          i will likely find a used drive to replace it. thats what my google-ing has poited to,
          sigpic
          • daemon123
            • Jun 2010
            • 50
            u might open the drive and clean the lens with isopropyl alcohol, i use Acetone instead of it.
            Also i have gotten 2 dvd-rw to life by adjusting those POT's which are on lens for CD/DVD Lazer power. measure the resistance on it, and turn it like 2 to 3 degrees at the time.
            now a tip to test it while its open. u can pray apart the top sticker and get the round plastic thingie which has the metal, now u can put any cd in tray and on the top put that thingie, and close the tray.
            usually if the cd is picked the drive will have steady RPM, if it can pick the cd then it will just spin up/down.
            Good Luck
            • Toasty
              • Jul 2007
              • 4171
              Acetone will eat/damage -many- plastics. Be very careful. It also can leave a film on the lens which will just exacerbate the problem.
              The alcohol is usually safe. Just a mild, dilute detergent (Dawn, Simple Green) will usually be sufficient, even from a smokers computer. Use a Q-tip -dampened- with plain water to rinse, then the other end to dry and polish.
              veritas odium parit
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                you think it is a dirty sensor?
                sigpic
                  • 31296
                  maybe, you do get a film of dirt on them.
                  if it's 100% good with CD and 100% fucked with DVD then it could also be laser failure.
                  that is/was very common on the ps2 consoles.
                  • Wizard
                    • Mar 2008
                    • 2296
                    Time for another optical drive. problems with reading and failing to burn is laser diodes going bad (one for CD and one for DVD).
                    Acetone melts most plastics, the optical lens that you can see is plastic, hence 99% alcohol needed.
                    Cheers, Wizard
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      some cd's were a no go as well.
                      as soon as i am done w/ dinner, i have some 91% alcohol and a q-tip... i will try cleaning it...
                      sigpic
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        cleaning was no help.
                        http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622
                        is that the correct drive/ is that a good deal?
                        sigpic
                        • Toasty
                          • Jul 2007
                          • 4171
                          What is Apple p/n for yours or make/model?
                          veritas odium parit
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            it is a PIONEER DVD-RW DVR-K04 if that helps.
                            don't feel like taking it apart again tonight (posting this from it in ubuntu)
                            sigpic
                            • Toasty
                              • Jul 2007
                              • 4171
                              Not a pretty scene. Both this drive and the one you eBay linked (Matshita/Panasonic) are very prone to failures. Loads of "had it 3 weeks and died stories" and "this is my 3rd drive in 2 years". For some reason the failure seems to occur when writing CD-RW's.
                              Somewhere someone recommended going to an external. Then you could use a more rugged (and probably cheaper) drive.
                              K06 info -
                              http://www.xlr8yourmac.com/feedback/..._failures.html
                              veritas odium parit
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                yes, but needs to needs to be firewire to boot. mine is usb (useless for installing leopard).
                                would the dvd-r/cd-rw option be any better? i could use the external usb to burn and the built in to read a dvd.
                                like this:
                                sigpic
                                  • 31296
                                  is it a slotloader?
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    I thought all the iMac G5's Firewire ??
                                    veritas odium parit
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      it is a slotloader
                                      it has firewire... i
                                      i meant that my burner was usb.
                                      anyway, i found this:
                                      http://pcdirect.com/chaliefi3had.html
                                      would that work? i have a dvd combo drive i could plug in it... or is downgrading the drive to the combo drive (as opposed to a superdrive) a better idea?
                                      sigpic
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Peruse some of the Mac forums with mentions of the Pioneer and Panasonic drives that fail. I saw someone, somewhere talking about what Firewire setup to use. I know $$ are tight, but you're now a Mac owner!! Buck up, son!!
                                        veritas odium parit
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
                                        • tommy97
                                          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                          by tommy97
                                          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                          Any ideas what might've...
                                          04-20-2024, 04:48 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
