Unknown System Failure
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Got problems!
    This morning I tried to fire up the Dell 5540 tower this morning and it was a no go. It started its boot then hung. It did this evey time I tried to start the system. I got no video start and the HD LED went into a soft green glow. It also made a few sick sounding beeps. The trouble lights on the back light up in a quick series of different combinations then settle on YYYG. This combination isn't even in my little DEll book. I tried booting with a different monitor and HD got the same results. I also reseated all plugs and cards.
    I got my backup PC out which is a PIII Dell GX 150 and it did the same thing! I put all this junk to the side and set up a Gateway P4 and it starts and runs just fine. The Gateway is using all the same stuff that my Dells were hooked up to. What the hell is going on here? Oh I also checked the line voltage and its 115.4vac.
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
    Mark Twain
    "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
    John Paul Jones
    There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
    Rod Serling
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Unknown System Failure
    Possibly a power surge during the night killed PSU's.
    Mann-Made Global Warming.
    - Dr Seuss
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      I like that answer but my backup PC wasn't plugged up to anything and its dead now too. I may have a keyboard issue. Going to change it out and see what happens.
      Mark Twain
      John Paul Jones
      Rod Serling
      • digge
        • Apr 2006
        • 296
        Think ive seen similar symptoms before on a dell gx280 (think that was the model). A recap of the mobo fixed it that time. Doesnt mean that you have that prob though but the machine was bahaving very erratic and give different codes all the time.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          The Dell in question has been rock solid up until this morning. The caps look good and the unit doesn't have a shit pile of hours on it. The keyboard is bad but I have not got around to trying to boot it with this known good keyboard. I got side tracked looking for updates in places other than MS for the Gateway because it has hot Xp on it. Will update you all as soon as I get done doing a few updates to this Gateway.
          Mark Twain
          John Paul Jones
          Rod Serling
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Still DOA. I'm going to use this old AMD unit to test the Dell parts in.
            Mark Twain
            John Paul Jones
            Rod Serling
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              I guess I'll mess around with the sick Dell some more and see if I can fix it. If I can't then I'll look for another junker just like it to refurb. This sucks! This Gateway I'm using can do streaming vids on Netflix but not very well.
              Mark Twain
              John Paul Jones
              Rod Serling
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                are you still using the generator? your voltage could be doing funny things...
                sigpic
                (Insert witty quote here)
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Are the small caps 85C ?
                  - Dr Seuss
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Going to visit all the caps today and see what is up. Yes I'm still on the generator. This Gateway and my home built AMD fire up and run just fine on it. The two Dells are the ones that went sick. I just may load up a complete Dell system and take it over to Dads house and plug it up to "real AC" today and see if it starts up.
                    Here is what the Dell Demension 4550 is doing now: On powerup the power button glows sort of a solid yellow/amber color. Back when it worked it was green. I think the PC does do some of the post. The floppy, DVD drives, and keyboard all do their blinks. The system then shows a solid weak green HD LED and the same solid yellow/amber power button. The four diag lights on the back of the unit don't light up at all There is no start of the video. So far I have test started the box with different RAM, Hard Drive, video cards, PSU, and DVD drives as well as no DVD drives. The boot always turns out the same way as listed above. I have test all these parts except for the Dell PSU and Hard drives in these other two PC's and they work fine. The HD in the Dell with Win7 on it wasn't even plugged in at the time of the failure. AS A side note the bright metal of the Dell case will give you a shock. Its not line voltage but a shock none the less.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                      • 30983
                      no earthing - get a big copper spike and hammer it into the ground outside - then link it to your house earthing with thick cable.
                      it sounds like when they cut you off the system the fuckers may have disconnected the earth too!!!
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        Well my grounding post is still intact.
                        Just tore the Dell apart some what. I stopped at the cpu. the white paste was burnt black and hard as a rock around the edges of the cpu face. I think the cpu fan failed and things turned to toast after that. I had just cleaned this thing up a few months ago so its not like the paste had years to burn up. Its time to put this one on the pile and find another one to play with.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Just need a CPU and fan.
                          Is the neutral on the generator at ground potential?
                          - Dr Seuss
                            • 30983
                            silicone grease is no good for pc's
                            it cant run that hot without drying up into a powder.
                            use silver or ceramic paste.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Virtually ALL thermal compounds use silicone grease as the medium.
                              That includes the silver and ceramic pastes.
                              - Dr Seuss
                              • Junk Parts
                                Court Jester
                                • Jun 2006
                                • 8953
                                PC I don't know what the above statment means. If you are asking if I am using a three wire grounded cord to connect to the gen-set, yes I am. The gen-set isn't grounded to the earth pin outside. What am I missing here. The only PC that bites me is the 4550 Dell and it only does this when it wants to. The other four PC's are fine in this respect. I did get the Dell PIII to boot up yesterday but it still has issues. Can't get both IDE channels working. I ether have DVD drives with the HD undetected or I have the HD and the DVD drives go undetected. This system always worked fine with all the drive jumped as "CS" in the past. Just a side note question here: Other than the longer length of the Dell tower IDE ribbon wires are their pin outs the same as a regular 80 wire IDE ribbon wire?
                                Mark Twain
                                John Paul Jones
                                Rod Serling
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  The neutral aka 'return' [white wire on 115 VAC] is generally connected to the ground bar in the breaker box putting the neutral at ground potential.
                                  If the 'white wire' coming from your generator isn't gounded then your nuetral may not be at zero volts like it should be.
                                  [Maybe a dumb question but I can't -SEE- what you have going on there...]
                                  Yes, 80 wire IDE and 40 wire IDE have the same pin-out. [There is a 'but' in a minute.]
                                  80 wire just has 40 extra ground wires to minimize cross-talk. Less cross-talk = faster without the signals deteriorating.
                                  The but:
                                  Some specs for IDE cable require one pin to be missing as a key and some [older I think] specs don't.
                                  The pin-out is still the same because the missing pin isn't used for anything anyway.
                                  The only time it causes problems is when you have a drive or mobo connector with all 40 pins but the cable has the one pin plugged for a key.
                                  [40 pins on the male side, 39 holes on the female side.]
                                  - Dr Seuss
                                  • Junk Parts
                                    Court Jester
                                    • Jun 2006
                                    • 8953
                                    From The Desk Of JP.
                                    The Dell 4550 is back! Here are few things "hints" as to what went wrong. WD-600, Primary Hard Disk Failure. Kingston Value RAM, one stick failed. CPU Fan stuck. It now has a new fan. Video card fan DOA. I'm am using a little ATI All In Wonder card for now. Yes I can laugh at it now but I was ready to smash this POS. The old PIII still has issues but I'll save that for another day. Side note: I was thinking that my Xp install which was on the drive that failed was on one of my newer drives. It wasn't. It was on and old POS WD-600 my brother pulled out of a junker. Also getting shocked on the bright metal of the case is a thing of the past too. I think I may have screwed up and fixed something today.
                                    Mark Twain
                                    John Paul Jones
                                    Rod Serling
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Congrats!
                                      Glad your fixed.
                                      At least someone is having a good day.. I'm NOT!
                                      !@#$@#%@!# FSP PSU @#%@!@##$ POS CapXon #$*#% 2200uF 6.3v @#%!@# 8mm & no way 10mm will fit.
                                      - WTF!
                                      Then %%#$~#% Mouser is the ONLY place @#$*@#% Lead Time @#~@!!% 22 weeks!
                                      I probably won't even %#$~# LIVE HERE in 22 weeks!
                                      - Dr Seuss
                                      • Junk Parts
                                        Court Jester
                                        • Jun 2006
                                        • 8953
                                        Thanks for all the feedback on fixing this pig. Makes it kind of suck when the HD dies right along with a cheap stick of RAM. Now to find a fan for this video card. Maybe I should do a voltage reading at the fan header first. The card just may be dying. It nolonger shocks me on the bright metal of the case. Its now running a different HD, RAM, and video card. I don't know which one was causing the shocks but its all better now. That old hard drive also made my electric fan make a funny buzzing noise when ever it kicked in. That noise is gone now too. This is so good that I feel like a Pimp now! PC 22 weeks lead time for a cap or two? Thats nuts!
                                        Mark Twain
                                        John Paul Jones
                                        Rod Serling
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • Stachujones
                                          Dell XPS 13 9370 unknown USB devices in device manager
                                          by Stachujones
                                          Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
                                          Device manager says "unknown device, failed to request device descriptor"
                                          Can somebody point me in right direction what to check?
                                          I updated bios to the newest version and thunderbolt controller firmware still no luck
                                          04-05-2025, 07:35 AM
                                        • ctroxtell
                                          Carrier HK50AA063 display controller common failure help
                                          by ctroxtell
                                          I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                                          02-05-2025, 05:31 PM
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • survivalbloke
                                          Lenovo Yoga C940-14 - will not power up each morning until resetting BIOS
                                          by survivalbloke
                                          I've got this laptop here which is presenting very odd behavior. It works perfectly fine except every morning, it won't power up. Power button does nothing. Reset button on bottom also doesn't seem to have any effect, but if I disconnect the battery, hold the power button for a few seconds to drain capacitance, when I connect the battery back, I can power on. It will go through RAM training as normal, and eventually boot into Windows. The laptop will work fine all day long, but the next morning - the problem is there again.
                                          Any thoughts?
                                          06-23-2024, 09:51 AM
