Capxon In WRT54GL
  • delaware74b
    • Apr 2009
    • 628
    Capxon In WRT54GL
    Although my Linksys WRT54GL router is operating solid as for the entire year I've owned it, I popped it open and found (3) 220uf/16v 8mm x 8mm Capxon ST series caps. As a preventive measure, what would be a good poly-mod for this router. I'll post pix when I have the opportunity.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Capxon In WRT54GL
    Spec sheet, if it will help...
    • delaware74b
      • Apr 2009
      • 628
      The spec sheet doesn't show the specs for the 220uf/16v. It's the same sheet I found before posting this thread.
      Any suggestions?
      • mockingbird
        • Dec 2008
        • 5484
        My suggestion is to cap it with electrolytic caps to be safe. I recommend UCC LXY or LXZ series. You can find them at digikey. They will last you for years inside a router.
          master hoarder
          • May 2008
          • 12170
          Any suggestions?
          ESR only depends on the can size so just measure the size of the CapXon caps in your router and compare them to any caps with the same can size in the CapXon data sheet.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Let me reword that a little to avoid confusing people.
            WITHIN A SERIES.. All the caps with the same dimensions will have the same ESR and Ripple regardless of their uF and Volts.
            There are some exceptions with crap brands but the ESR/Ripple will still be close enough to figure out what it should be by the other caps in the data sheet that have the same dimensions.
            Mann-Made Global Warming.
            - Dr Seuss
            • yyonline
              • Jul 2009
              • 692
              I usually recap the WRT54GL routers with 25V 220uF Panasonic FM. I have a WRT54G-TM (WRT54GL with more memory) and the FM were a pretty close match/slight upgrade spec-wise to the Su'scon that were in it. Given the other caps with inferior specs that are used in these routers, FM is likely overkill. I've done 4 or 5 that I can recall with FM and all are still working, including 2 of my own.
              A tip - don't use much heat when soldering the router board. The PCB is pretty thin and it's very easy to damage the coating or lift traced on it.
              • Toasty
                • Jul 2007
                • 4171
                If size is limited to 8mm, then the best poly you can get is a 270uF@16v. There are 8mm 330uF@16v ones out there, but finding stock is a problem. Height is also a concern. Can you exceed the 8mm height?
                Try: PS in UCC
                LG or LF in Nichicon
                veritas odium parit
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  It might be of interest to know that atleast the older WRT54GS units could be upgraded to handle up to 50vdc I think it was
                  All that was needed was a capacitor change, the DC/DC converters where rated for it, their name escapes me but I think it was some AIC chip...
                  If it interests you look up the spec
                  I used this trick to run mine at 24 or 48v, on batteries, it slightly increased the power efficiency...
                  Good to know when you install them 20m high up in trees as I did
                  http://www.techspot.com/blog/44/fina...n-the-forrest/
                  I should also note that I have over a dozen WRT54GS/GL units in usage, over atleast an 8 year period I'd guess
                  None of them have failed their capacitors
                  They sit in really hostile environments too
                  Edit: Friend of mine had a WRT54GL die due to Capxon's: https://www.badcaps.net/forum/showthread.php?t=37945
                    master hoarder
                    • May 2008
                    • 12170
                    Thanks for correcting that for me. I think that's what I had in mind when I was writing the post, just didn't word it properly. Hope I didn't confuse anyone.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      No worries. I knew what you meant.
                      Just saw how the wording might confuse someone new to ESR.
                      - Dr Seuss
                      • double_DD
                        Why does my ISP router hate my "homemade" power supply??
                        by double_DD
                        It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                        So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                        For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                        07-12-2025, 03:09 AM
                      • shadow666
                        Router Xiaomi M4A Gigabit
                        by shadow666
                        hello
                        i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                        Mi Router 4A Gigabit Edition
                        ROM CHIP is 16 MB
                        i attached picture of motherboard​...
                        11-30-2024, 03:49 PM
                      • EasyGoing1
                        UPNP, "Standards" and hardware that implements it
                        by EasyGoing1
                        I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                        One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                        So I decided to implement UPNP...
                        07-16-2022, 07:12 PM
                        by momaka
                        03-15-2023, 10:17 PM
                      • hinisa
                        Xiaomi router freezes at boot after re-capping
                        by hinisa
                        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                        07-08-2023, 05:58 AM
