Post help identifying capacitors here
This is a sticky topic.
  • telimage
    replied
    Re: Post help identifying capacitors here
    Can’t seem to find this manufacturer datasheet
    Z112185936 6/F
    2U2 K 750 DD
    Stamped on top of cap.
  • Uranium-235
    replied
    Originally posted by Bushcat
    I'm starting to re-cap a Pioneer turntable, specifically the motor control board. Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't know why Pioneer would do this, unless the capacitors are special somehow. Any ideas?
    There's a second oddity: CCDCH 330J 50 means ceramic disc, disc-type radial leads, thermal compensation with a thermal coefficient of 0 and tolerance of 60 PPM, 33 pF, 5%, 50V. So that's a generic passive component naming scheme, for a capacitor I have no idea how to find a modern equivalent. Again, any ideas?
    try putting this on the audio forum
  • Bushcat
    replied
  • andrewsawesomr
    replied
    Originally posted by kiransband
    its Apple iMac Motherboard, I was upgrading the iMac and had taken off the motherboard a few items and this delicate capacitor came off... with broken pins
    Then the lower ESR should be fine.
  • andrewsawesomr
    replied
    Re: unknown solid cap
    Originally posted by kevin!
    Hi, does anyone know what brand they are? They seem very generic, I did not find anything about it.
    If someone could help me I would appreciate it.
    They seem to be from Man Yue Technology Holdings sold under the brand X-Con (Man Yue is the same manufacturer that makes Samxon capacitors).
  • kiransband
    replied
    Originally posted by andrewsawesomr
    That capacitor has a lower ESR than the one you are replacing. Most of the time this is fine, but it might be a problem in some situations. For clarity, what type of device are you replacing the capacitors on? Brand and model would be extra helpful.
  • andrewsawesomr
    replied
    I just wanted to make sure can I use this as a replacement?
  • kiransband
    replied
    It's a Panasonic 180uF 16 V capacitor from their PF series. The datasheet is available here.
    You can replace them with Panasonic FKE (here, here, or here).
    Also label says...
    738
    PF
    180
    16
    what is 738 ? and PF stands for PF series? guessing 180is uF and 16 is volts
  • kiransband
    replied
    wow, i truly appreciate your response and see the capacitors you referred are 180uF with 25v which will work fine as a replacement for 16v. I just wanted to make sure can I use this as a replacement I? Also i want to understand for knowledge's sake what is that 738 stands for.
  • andrewsawesomr
    replied
  • kiransband
    replied
    How do I identify this capacitor, can someone suggest where to buy or alternate?
  • kevin!
    replied
    unknown solid cap
    Last edited by SMDFlea; 05-01-2023, 10:06 AM. Reason: posted image on badcaps from external image host
  • Hexram
    replied
    Awesome, Thanks for the help andrewsawesomr and jiroy I really appreciate it.
  • jiroy
    replied
    Originally posted by Hexram
    Trying to locate information on this capacitor so I can workout how to test it.
    From a little research I did on google it was made by Matsushita that turned into Panasonic. Can't find the sh-sp or the T10-17 though. If it helps it is in a Cigweld welder.
    There appears to be 4 pins coming from the capacitor through the other side of the PCB. Did a little googling on that and the form factor might be called a radial box 4 pin but not sure on that.
    Thanks for the help.
    This is a Panasonic metallized polypropylene capacitor film 4 pins , EZPV series , sp is the type code , T10-17 for date manufacturing .
  • andrewsawesomr
    replied
    The pins on both sides should be connected together, so you can choose one of the leads on either side and test either using a capacitance meter or component tester. I've attached a picture so you can see how the leads are arranged.
    I'm pretty sure this is how yours is arranged, as it seems to be the standard, but it might be different.
  • Hexram
    replied
  • danro
    replied
    Hello all,
    Please help to identify this component in red circle. It is a capacitor, but not sure about the type. It is polyester (PET) film? His value seems to be 220nF (224 - hard reading), but also not know the voltage
    Thank you
  • andrewsawesomr
    replied
    Originally posted by Slimtedi23
    looking for this cant find anywhere any help will be appreciated thanks
    ic v718279
    Can you upload a photo of the IC?
  • Slimtedi23
    replied
    ic v718279
  • alcatote
    replied
    I cleared the corrosion but it's still a dead short. Thanks for your help.
  • varkatope
    Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
    by varkatope
    Hey there, retro fans.
    I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
    12-15-2024, 09:48 AM
  • dragon3x
    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
    by dragon3x
    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
    power on.
    Here are some examples :
    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
    switching supply area).
    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
    than 6.3 V.)
    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
    I replaced capacitors with aluminum-polymer.
    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
    03-21-2025, 02:46 PM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • Ady2017
    Are there any datasheets available for Elna RJG capacitors?
    by Ady2017
    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
    05-25-2025, 02:19 PM
