Post help identifying capacitors here
This is a sticky topic.
  • andrewsawesomr
    • Jun 2022
    • 100
    • United States of America
    #81
    Re: Post help identifying capacitors here
    Originally posted by Slimtedi23
    looking for this cant find anywhere any help will be appreciated thanks
    ic v718279
    Can you upload a photo of the IC?
    • danro
      • Aug 2011
      • 54
      • Serbia
      #82
      Hello all,
      Please help to identify this component in red circle. It is a capacitor, but not sure about the type. It is polyester (PET) film? His value seems to be 220nF (224 - hard reading), but also not know the voltage
      Thank you
      • Hexram
        • Apr 2023
        • 8
        Trying to locate information on this capacitor so I can workout how to test it.
        From a little research I did on google it was made by Matsushita that turned into Panasonic. Can't find the sh-sp or the T10-17 though. If it helps it is in a Cigweld welder.
        There appears to be 4 pins coming from the capacitor through the other side of the PCB. Did a little googling on that and the form factor might be called a radial box 4 pin but not sure on that.
        Thanks for the help.
        • andrewsawesomr
          • Jun 2022
          • 100
          #84
          The pins on both sides should be connected together, so you can choose one of the leads on either side and test either using a capacitance meter or component tester. I've attached a picture so you can see how the leads are arranged.
          I'm pretty sure this is how yours is arranged, as it seems to be the standard, but it might be different.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            #85
            This is a Panasonic metallized polypropylene capacitor film 4 pins , EZPV series , sp is the type code , T10-17 for date manufacturing .
            • Hexram
              • Apr 2023
              • 8
              Awesome, Thanks for the help andrewsawesomr and jiroy I really appreciate it.
              • kevin!
                recapping PCB.
                • Jul 2013
                • 195
                • España
                #87
                unknown solid cap
                Hi, does anyone know what brand they are? They seem very generic, I did not find anything about it.
                If someone could help me I would appreciate it.
                Last edited by SMDFlea; 05-01-2023, 10:06 AM. Reason: posted image on badcaps from external image host
                Gaming pc:
                nVidia RTX 3080 TI, Corsair RM750I.
                Workshop PC:
                Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                Server:
                • kiransband
                  • May 2023
                  • 8
                  How do I identify this capacitor, can someone suggest where to buy or alternate?
                  • andrewsawesomr
                    • Jun 2022
                    • 100
                    #89
                    It's a Panasonic 180uF 16 V capacitor from their PF series. The datasheet is available here.
                    You can replace them with Panasonic FKE (here, here, or here).
                    • kiransband
                      • May 2023
                      • 8
                      wow, i truly appreciate your response and see the capacitors you referred are 180uF with 25v which will work fine as a replacement for 16v. I just wanted to make sure can I use this as a replacement I? Also i want to understand for knowledge's sake what is that 738 stands for.
                      • kiransband
                        • May 2023
                        • 8
                        Also label says...
                        738
                        PF
                        180
                        16
                        what is 738 ? and PF stands for PF series? guessing 180is uF and 16 is volts
                        • andrewsawesomr
                          • Jun 2022
                          • 100
                          #92
                          Originally posted by kiransband
                          I just wanted to make sure can I use this as a replacement?
                          That capacitor has a lower ESR than the one you are replacing. Most of the time this is fine, but it might be a problem in some situations. For clarity, what type of device are you replacing the capacitors on? Brand and model would be extra helpful.
                          • kiransband
                            • May 2023
                            • 8
                            its Apple iMac Motherboard, I was upgrading the iMac and had taken off the motherboard a few items and this delicate capacitor came off... with broken pins
                            • andrewsawesomr
                              • Jun 2022
                              • 100
                              #94
                              Re: unknown solid cap
                              They seem to be from Man Yue Technology Holdings sold under the brand X-Con (Man Yue is the same manufacturer that makes Samxon capacitors).
                              • andrewsawesomr
                                • Jun 2022
                                • 100
                                #95
                                Then the lower ESR should be fine.
                                • Bushcat
                                  • May 2023
                                  • 18
                                  • Japan
                                  #96
                                  I'm starting to re-cap a Pioneer turntable, specifically the motor control board. Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                  BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't know why Pioneer would do this, unless the capacitors are special somehow. Any ideas?
                                  There's a second oddity: CCDCH 330J 50 means ceramic disc, disc-type radial leads, thermal compensation with a thermal coefficient of 0 and tolerance of 60 PPM, 33 pF, 5%, 50V. So that's a generic passive component naming scheme, for a capacitor I have no idea how to find a modern equivalent. Again, any ideas?
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    #97
                                    try putting this on the audio forum
                                    • telimage
                                      • Jun 2014
                                      Can’t seem to find this manufacturer datasheet
                                      Z112185936 6/F
                                      2U2 K 750 DD
                                      Stamped on top of cap.
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3581
                                        • USA, Unsure of Planet
                                        #99
                                        2.2uF, +/-10%, 750V?
                                        PeteS in CA
                                        • Half-Saint
                                          • Jan 2010
                                          • 213
                                          • Slovenia
                                          #100
                                          I need help identifying this polymer. The text says:
                                          LF
                                          470
                                          C
                                          454
                                          I bought these new but can't find the specs in the mail. I know it's 470 uF but what voltage?
                                          EDIT: just figured it out.. Nichion LF series, rated at 16V
                                          • varkatope
                                            Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                                            by varkatope
                                            Hey there, retro fans.
                                            I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                                            12-15-2024, 09:48 AM
                                          • dragon3x
                                            by dragon3x
                                            power on.
                                            Here are some examples :
                                            switching supply area).
                                            than 6.3 V.)
                                            03-21-2025, 02:46 PM
                                          • slybunda
                                            AA and AAA battery charger capacitors?
                                            by slybunda
                                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                            it has inside:
                                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                            2 x 470uf 16v LZ105c branded as G.Luxon
                                            not heard of these brands are they any good?
                                            iv attached photos of the charger and the board inside for an idea on the type of...
                                            12-24-2023, 04:41 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • Ady2017
                                            Are there any datasheets available for Elna RJG capacitors?
                                            by Ady2017
                                            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                            05-25-2025, 02:19 PM
