Post help identifying capacitors here
This is a sticky topic.
Re: Post help identifying capacitors here
Trying to locate information on this capacitor so I can workout how to test it.
From a little research I did on google it was made by Matsushita that turned into Panasonic. Can't find the sh-sp or the T10-17 though. If it helps it is in a Cigweld welder.
There appears to be 4 pins coming from the capacitor through the other side of the PCB. Did a little googling on that and the form factor might be called a radial box 4 pin but not sure on that.
Thanks for the help.Comment
The pins on both sides should be connected together, so you can choose one of the leads on either side and test either using a capacitance meter or component tester. I've attached a picture so you can see how the leads are arranged.
I'm pretty sure this is how yours is arranged, as it seems to be the standard, but it might be different.Last edited by andrewsawesomr; 04-23-2023, 07:00 PM.Comment
Last edited by SMDFlea; 05-01-2023, 10:06 AM. Reason: posted image on badcaps from external image hostGaming pc:
nVidia RTX 3080 TI, Corsair RM750I.
Workshop PC:
Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
Server:
738
PF
180
16
what is 738 ? and PF stands for PF series? guessing 180is uF and 16 is voltsLast edited by kiransband; 05-23-2023, 12:07 AM.Comment
I just wanted to make sure can I use this as a replacement?Comment
its Apple iMac Motherboard, I was upgrading the iMac and had taken off the motherboard a few items and this delicate capacitor came off... with broken pinsComment
Re: unknown solid cap
They seem to be from Man Yue Technology Holdings sold under the brand X-Con (Man Yue is the same manufacturer that makes Samxon capacitors).Comment
I'm starting to re-cap a Pioneer turntable, specifically the motor control board. Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't know why Pioneer would do this, unless the capacitors are special somehow. Any ideas?
There's a second oddity: CCDCH 330J 50 means ceramic disc, disc-type radial leads, thermal compensation with a thermal coefficient of 0 and tolerance of 60 PPM, 33 pF, 5%, 50V. So that's a generic passive component naming scheme, for a capacitor I have no idea how to find a modern equivalent. Again, any ideas?Comment
There's a second oddity: CCDCH 330J 50 means ceramic disc, disc-type radial leads, thermal compensation with a thermal coefficient of 0 and tolerance of 60 PPM, 33 pF, 5%, 50V. So that's a generic passive component naming scheme, for a capacitor I have no idea how to find a modern equivalent. Again, any ideas?Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
2.2uF, +/-10%, 750V?PeteS in CA
****************************Comment
I need help identifying this polymer. The text says:
LF
470
C
454
I bought these new but can't find the specs in the mail. I know it's 470 uF but what voltage?
EDIT: just figured it out.. Nichion LF series, rated at 16V
ThanksLast edited by Half-Saint; 06-07-2023, 12:37 AM.Comment
by varkatopeHey there, retro fans.
I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...1 Photo -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
(N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
switching supply area).
(N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
than 6.3 V.)
1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
I replaced capacitors with aluminum-polymer.
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
