blown caps on 9600 gso
  • al cap blown
    • Mar 2010
    • 16
    hi all ,just came across this site ....some great info here,well done..
    now i have a problem ,i got 2 blown caps on my graphics card,its a 9600 gso
    2 different type of cap has blown,both fz's,ive seen here that these are a really bad make
    one is a fz85 1500 6.3v
    im not too sure on the other one as i cant see it properly but it looks like a fz03 1000 6.3v although that could be fz13,not too sure
    would it be worth my while to replace them considering theres other fz's on the same card possibly in danger of blowing also?
    could someone recommend me replacements for these capacitors please?
    also what tools would i need?
    thanks guys
  • al cap blown
    • Mar 2010
    • 16
    Re: blown caps on 9600 gso
    more investigation suggests that the fz03 is actually a fz83.....
    • mockingbird
      • Dec 2008
      • 5484
      Some pics would help.
      • al cap blown
        • Mar 2010
        • 16
        im sure you know what a blown capacitor looks like?
        • c_hegge
          • Sep 2009
          • 5219
          Your caps are sacon FZ (based on your description), the worst video card cap in the world. Rubycon MBZ would be OK as a replacement. You could also replace them with Sanyo SEPC polymer caps or equivalent, if you reduce the capacitance a bit. Replace all the caps, even the ones that aren't bulging yet, unless you want to have to pull the card out again when they fail.
          The reason we like pics is so that we can properly identify the failed caps and suggest an appropriate replacement.
          • al cap blown
            • Mar 2010
            • 16
            hi i took some pics today ...
            one is of the fz85 1500 6.3v,the cap next to it is identical
            the other is the fz83 1000 6.3v
            altogether on the board there is
            3 x fz85 1500 6.3v (1 blown)
            1 x fz83 1000 6.3v (1 blown)
            4 x fz86 470 16v (all ok)
            there are also 2 other caps which are not fz's but they do look like them,they have the blue strip down the left side of the top of the cap,these caps look fine
            • c_hegge
              • Sep 2009
              • 5219
              The other caps could be solid polymer caps, or a different "flavour" of sacon FZ. a pic of them would be helpful in order to identify them
              • al cap blown
                • Mar 2010
                • 16
                ive attached some more pics of the other 2 types of caps on the card
                now there are pics of all 4 caps on my card is it possible to suggest replacements for them please?
                • c_hegge
                  • Sep 2009
                  • 5219
                  The first cap is a Nippon Chemi-con solid cap, which are very reliable and can be left in place. The other is sacon FZ. Same junk electrolyte, just a different vent shape. Any cap with FZ__ on the first line is a sacon FZ, regardless of its vent shape and colours, and should be replaced. You could use the following:
                  3 x fz85 1500 6.3v - https://www.badcaps.net/store/produc...products_id=40
                  1 x fz83 1000 6.3v - https://www.badcaps.net/store/produc...products_id=47
                  4 x fz86 470 16v - https://www.badcaps.net/store/produc...products_id=51
                  • al cap blown
                    • Mar 2010
                    • 16
                    thats excellent,thanks man......
                    ive never done any soldering before but with the right tutorial i reckon i could pull it off ...ill have a look around here
                    thanks again man
                    ps...is it ok to swap a 6.3v cap with a 10v cap?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      6.3v is simply the limit that the cap can handle, not a voltage that it will be supplying to the device. So using different voltages is fine as long as the voltage in the circuit is within the limits of the new cap.
                      • al cap blown
                        • Mar 2010
                        • 16
                        ok cool ,thanks
                        ill let you know how i get on,thanks again mate
                        • al cap blown
                          • Mar 2010
                          • 16
                          hi all
                          just to let people know,i recieved the new caps today and replaced all the fz caps
                          card seems to be working fine now
                          thanks everyone for all the help with this
                          ill get y'all a pint if ya ever come to ireland
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Good to hear it works, and I'm glad I could be of assistance.
                            • al cap blown
                              • Mar 2010
                              • 16
                              oh no....i got a problem
                              today i decided to take out the card ,just to look at it to see if everything looked ok.........stupidly i decided to touch up some of the solder joints....when i put it back in the pc wouldnt even boot,have i created a cold joint somewhere or is the card doomed?
                              thanks in advance............
                                • 31043
                                obviously check your soldering with a magnifier.
                                • al cap blown
                                  • Mar 2010
                                  • 16
                                  thanks im gonna resolder the lot tomorrow
                                  • al cap blown
                                    • Mar 2010
                                    • 16
                                    resoldered all the caps again,much cleaner job this time,all working fine,thanks lads
                                    • bkasprowicz
                                      • Jan 2012
                                      • 7
                                      Hello, I am currently having the same problem with the same GPU. I was wondering if there are any caps similar to these or am I sol. I see the 1000uf is still available but the others are no longer in stock. I would like to attempt to replace these also instead of straight up buying a new gpu. I have another 9600 gso currently in my desktop that was connected together with this card via sli. If you don't have these in stock would you happen to know a similar set of caps I could install instead?
                                      • mariushm
                                        • May 2011
                                        • 3799
                                        If you say where you live, we may be able to recommend some good stores close to you.
                                        If you're in Europe (deducting from the weird username) I may be able to help you with caps from my own personal stock and save some money in the process.
                                        But first make sure you have the same capacitors - sometimes even if the manufacturer and model is the same, they change capacitor brands or values between revisions.
                                        • odtech
                                          Asus UX490U laptop blown (caps?) on power board.
                                          by odtech
                                          Greetings friends.
                                          I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                                          I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                                          Any guidance...
                                          08-06-2023, 10:29 AM
                                        • zlr8r
                                          HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                                          by zlr8r
                                          Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                                          To begin with, this laptop was dead-dead.
                                          Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                                          • am getting white power led
                                          • 5-long-flashes on CAPS Lock and NUM lock
                                          • then, fan full speed
                                          • CPU heats up some (smaller die PCH, does not)
                                          • always constant black screen no matter what's tried
                                          • no USB recognition
                                          • no HDMI output
                                          this is as far as I can get with it and not sure where to inspect next ?
                                          I tried...
                                          03-27-2024, 03:13 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • whc14765
                                          1070 - Blown SMD caps, short on 12V PCI
                                          by whc14765
                                          Hey
                                          I got a short on 3 pins of the PCI-E gold connector for 12V.
                                          I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
                                          Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
                                          Due to the large number of caps there, I think it may just be decoupling.
                                          Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
                                          11-23-2022, 06:42 PM
                                          no-name Radeon 9600 XT recap and cooler
                                          by momaka
                                          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                          This one was actually suggested to me by ChaosLegionnaire....
                                          11-06-2020, 07:54 PM
