1070 - Blown SMD caps, short on 12V PCI
  • whc14765
    • Mar 2022
    • 28
    Hey
    I got a short on 3 pins of the PCI-E gold connector for 12V.
    I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
    Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
    Due to the large number of caps there, I think it may just be decoupling.
    Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3634
    • slovakia
    Re: 1070 - Blown SMD caps, short on 12V PCI
    it will work even without it.
    • Babbar
      by Babbar
      04-12-2024, 01:12 AM
    • odtech
      Asus UX490U laptop blown (caps?) on power board.
      by odtech
      Greetings friends.
      I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
      I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
      Any guidance...
      08-06-2023, 10:29 AM
    • Hw31
      gigabyte gtx 1070 caps, inductors and mosfets short
      by Hw31
      hey there,
      specific questions:
      so i have gtx 1070 which isnt detected where the caps, inductors and mosfets are short. Circled red. can i just inject voltage in the red circled pads? if yes, how much volt and amps are safe?
      general question:
      is there a tutorial on how to proceed with an defective graphics card? like check this first, then this, then this.if this component is falty it means that, or also something else could be bad etc.?
      i know there are differnt rails and so on but these are on different places depneding on the board layout....
      08-04-2021, 02:52 AM
    • jesterace
      Samsung UE46ES8000 Blown fuse but no other signs of short
      by jesterace
      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
      09-11-2024, 03:14 PM
    • Aziz aj
      caps lock 5 long 3 short black screen
      by Aziz aj
      rev-1.0
      input short remove then caps lock 5 long 3 short no output how to solve this problem
      06-08-2024, 07:47 AM
