I'm hard at work recapping some faulty ATX PSUs.
I'm rapidly depleting my stocks of PSU appropriate capacitors. I would like to use UCC KY series but can't find 2200uf in 10mm can diameter. Mostly I am replacing bulged TEAPO SE(Green) and TEAPO SEK (Brown) 2200uf 10v 10mmx20mm.
I have a few Rubycon ZL and Rubycon YXG in this size but these need reforming.
I had to use 3 UCC KMG caps, they seem to work fine, but not exactly sure. Some of the Data Sheets do not give detailed ripple current and ESR data for comparison.
Any used caps that I have I will be reforming as per momaka's excellent thread here:
https://www.badcaps.net/forum/showthread.php?t=50530
I've been measuring capacitance and ESR of my used caps. All the TEAPOs and GLuxon and SACON were garbage. Surprising to me was that every JACKCON cap I tested was extremely close to the rated cap value and the ESR values were no worse than the major brands. I removed these from old ABIT Socket 462 boards! Go figure.
Anyone have any suggestions for sources and/or substitutions for the PSU capacitors?
Half of the computer problems is caused by bad contacts
