Peripheral Problems on Recapped Board
  • bigbeark
    • Jan 2010
    • 661
    Just recapped a Soyo K7V Dragon Plus, replacing all the bulged and leaking Wendells with Ruby MBZ, Ruby ZL, and Sany WG and (less good) Sanyo NHG. All the bigger Wendells and Sacons were removed, though they had no signs of distress.
    CPU is AMD 1600 Athlon XP. Video card is 32MB Nvidia. Video performance is terrible.
    I tried to load Ubuntu as a dual boot with Mandriva. Kept getting stuck at the partitioning process. Tried playing a music CD, plays OK, but I note the CDROM motor gets hot. I tried three different drives, all known good.
    Also this board popped one of the 100uf caps on my Soundblaster card.
    North and South Bridge cips are cool. Whatever is causing this seems connected to the PCI circuits. Seems like it'c slow to detect PCI components.
    PSU is a DELTA with 24 pin to 20 pin adapter. It is newish. Seems to blow warmer air than I would like.
    Checked the BIOS - all voltages fine, but 5 volt is actual 4.67. CPU Temp is 43C.
    Ther's still a few of the crappy Wendells on the board, they all look good though.
    Any hints on where to start?? I rechecked my works and all the solder joints look good.
    There are no burned or damaged traces that I can see. I was very careful about the case - there are no grounded stand-offs
  • kaniki
    • 514
    Re: Peripheral Problems on Recapped Board
    ii looked it up a while back, the working rating of power supplies are supposed to be within about 5% of that actual voltage on the plus side and within 10% on the minus side.. so if your +5 volt is 4.67, then it is a little low to be within standards, it should be at least 4.75 to about 5.25, but do not see that to be causing your problems.
    Sensors are not always accurate, so if you can get a tester to check the actual output voltage on the lines, i would try that or a different power supply. IF the supply is good, then you still have a spare, but if it is bad and not reading right, then it just might fix your problems.. I have a board here that the sensor was reading over 15v on the 12v rail by internal sensors, but when checked with an actual tester, found it to be 12.1 which is almost right on, so i can say first hand that those sensors are not always accurate..
    • i4004
      • Oct 2006
      • 2029
      that doesn't mean they are good.
      check with esr meter.
      smaller caps can go bad without showing it.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        ATX tolerances for
        +12 is + or - 5% (11.4-12.6)
        +5v is + or - 5% (4.75-5.25)
        +3.3v is + or - 5% (3.135-3.465)
        -12v is + or - 10% (10.8-13.2)
        -5v (if used) is + or - 10% (4.5-5.5)
        Sometimes motherboards sensors can be pretty good, sometimes they can be ridiculously off. Check with a multimeter. As long as that delta is an actual delta electronics, and not just those knock-off sunpro deltas it should be fine.
        • bigbeark
          • Jan 2010
          • 661
          So I measured the cluster of 4 caps marked SPK5 - speaker - 3.85 ESR each value 10uf 25v.
          I found 2 22uf 25v measuring 1.09
          2 100uf 16V at .6 to .8
          470uf 10v at .06 to .13
          220uf 10v and 16v at .13 and .18
          So I can see the sound being affexted by the SPK5 cluster, although it sounded OK.
          Is the other stuff enough to cause the noload/hot problem?
          • mockingbird
            • Dec 2008
            • 5484
            Open up the PSU and check its caps.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              run memtest 86+
              • bigbeark
                • Jan 2010
                • 661
                Memtest showed no problems. I can see how the SPK5 cluster could affect video. On playing the movie trailer again, the sound is interrupted as well as the video - could be that the 3.85 ESR is effecting the video as obviously there is both sound and video occurring simultaneously.
                Tomorrow I am going to swap out the power supply for a new one and see if it makes any difference.
                Thanks for the help, much appreciated!
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • ohren
                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                  by ohren
                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                  The models launched in 2018 and 2019 respectively....
                  09-08-2023, 05:24 PM
                  by momaka
                  03-15-2023, 10:17 PM
