4700uF 6.3v and 3300uF 16v in a 10mm Diameter
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • jayjr1105
    • 281
    Re: 4700uF 6.3v and 3300uF 16v in a 10mm Diameter
    I like ZLQ's for a lot of things.
    https://www.digikey.com/en/products/...C10X25/6049993
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
      master hoarder
      • May 2008
      • 12175
      Looking through my datasheets... yeah, it seems Ruby ZLQ is pretty much the only option at this size and capacitance (at least for the 6.3V, 4700 uF caps), unless you know someone who has custom-ordered caps (Behemoth, perhaps?)
      Panasonic FS seems to be a 2nd runner up, if you don't mind bumping down the capacitance for the 4700 uF caps to 3900 uF (instead of 3300 uF.)
      As for 3300 uF, 16V caps in 10 mm dia... I couldn't find anything to fit from my datasheets. Will definitely need a custom size for that one, I think. Or maybe you can somehow find a way to wedge a 12.5 mm cap in there. I'm guessing you're all out of Samxon RS by now. :\
      Also, the other thing I wonder about is how the ESR of ZLQ and FS will play with the circuits in that PSU. More than likely it will work fine. Though it is worth noting that both Panny FS and Ruby ZLQ caps have ESR/impedance close to that of United Chemicon KZE - a series that is often used in a lot of modern PSUs, but rarely seen in any old units that generally favor more entry-level low-ESR caps (if not outright GP caps.)
      • jayjr1105
        • 281
        3300uf 16v 10mm if you can find them EKMG160ELL332MJ40S
        https://www.mouser.com/ProductDetail...X9wDF2QA%3D%3D
        Ryzen 3600x
        FX-8802 Iron
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          digikey is annoying me in that the 4700uf zlq didn't show up when I searched. I also never knew there was a KMG 3300uF 16v 10mm X 40mm that wasn't a special order. I love learning things!!
          Team : 49813
          Join in!!
          Team Stats
          • jayjr1105
            • 281
            Check the datasheet, I'm not seeing 10x40mm
            Ryzen 3600x
            FX-8802 Iron
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              From your own link:
              Team : 49813
              Join in!!
              Team Stats
              • jayjr1105
                • 281
                I mean I don't see 10x40 anywhere on the data sheet. Maybe Mouser has their data messed up? I can't tell you how many times I see 10x25 on the datasheet then the cap comes and it's 27mm tall.
                Ryzen 3600x
                FX-8802 Iron
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  The height doesn't really matter, plenty of clearance....the diameter is what mattered, they're packed in there crazy tight.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Has it ever been established that the fudgies were in fact their stated values when new? Remember, we're only seeing these antecs after failure or when in for recapping.
                    Would've been interesting when these were new to pull 'em and confirm value; alas, too late now.
                    But I'm not putting it below them to "fuhjj" the values- obviously custom size of questionable antec-spec pedigree. Remember the major antec trolling years ago?
                    Wouldn't surprise me if the stupidpowers' "4700uf" on the sleeve were one or two standard values lower.
                    Regardless of the fact that legit caps in those size/value combos exist(ed) is moot; the stupidpowers had a particular love affair with em.
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      I'll measure them when I pull them. Some haven't bloated.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • lti
                        • May 2011
                        • 2557
                        Most of the unusually small caps I've seen measured low, but still (barely) within tolerance. I did see a few that measured extremely close to the rated capacitance, like a 2200uF 25V 13x20mm that measured almost exactly 2200uF.
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          Keep in mind oxide thickness reduction will increase capacitance.
                          Charge say, a 16v cap from 16-20v thru a 1k-10k resistor til cap voltage equals supply voltage. Then measure the capacitance- oxide may be closer to original thickness.
                          Yes, there's other factors involved here, not the least of which is the fact they're "f-yoos," but it's an attempt to go back to at least one "known". Such craps and their oxide thickness reduction will give a false-high capacitance when tested.
                          Which you know already...
                          EOL it...
                            master hoarder
                            • May 2008
                            • 12175
                            Interesting, I also didn't know that KMG series have a 16V, 3300 uF in 10 mm dia. cap. Then again, I also tend to ignore them quite often on Digikey and Mouser, simply because they are GP series (hence, technically not good enough for PSU.) On the other hand, since you'll be replacing Fuhjyyus that aren't really that much better rated than GP caps, this probably might not matter much.
                            It's possible.
                            But I find Fuhjyyu caps tend to be accurate about the capacitance on their label... when they are not failed, of course.
                            And in that regard, it seems that Fuhjyyu just uses crap quality materials, which makes their caps very unreliable (unable to withstand heat stress and also breaking down in use over time.) However, of the many many F-u caps that failed, a select few do seem to survive... and IME, or at least from what I have in my salvage bin, those have been OK, surprisingly - even after using them for many years in various temp recap projects. Unlike Teapo SEK and SC series, at least these don't bloat by themselves when sitting on the shelf. With Teapo, I always have to reform them and check them on the cap meter... and even then that guarantees nothing. Then there's CapXon and Ltec I don't trust those even for a temp recap. Non-stressful breadboard projects is as far as I take them.
                            By the way, anyone remember the 1650 uF -rated Fuhjyyu?
                            https://www.badcaps.net/forum/showth...highlight=1650
                            Maybe I should list it on eBay as "vintage rare special cap with warm musical sound"
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Yea I would also not use KMG in a modern PSU, General Purpose caps do not belong there.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                This PSU has to be a good 15yrs old....I don't think it would qualify as 'modern'...
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  Anything with a high switching frequency I mean, it was designed for low ESR capacitors.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16959
                                    I just dissected a Zippy / emacs (model R2W-6500) for another project I'm working on, there's quite a few KMG's in it. It's probably circa 2010 (it was running a 5400 series Xeon system). It's a high-time PSU, its a redundant server supply, working fine. Most the ones in the secondary are KZE and KY. The reason for the dissection was I'm repuropsing it for something less demanding and wanted to quiet the fans down. They're 8500RPM feeding off the +12v rail. Much quieter feeding from the +5v instead!
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      Our forum member Behemot sells custom made UCC KZN 16V 3300uF capacitors which are 10mm and quite tall and I highy recommend them.
                                      He sells them through his Bonanaza store, or through his website.
                                      He also carries Samxon RS in 16V 3300uF, but their spec is not as impressive as KZN. You're already familiar with those.
                                      Yes, they were in fact 4700uF. Don't bother trying to find 10mm 6.3V 4700uF caps. Just use 3300uF caps there.
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16959
                                        I thought RS's were discontinued....I haven't been able to get them since Joe Lo (bigpope) went MIA. I do like the specs of the KZN better for sure though.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • ssl6
                                          MSI K7T266 Pro (Ver. 1.0)
                                          by ssl6
                                          Hey Everyone,
                                          Long time lurker, but I think this is my first time posting.
                                          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                          11-09-2023, 01:00 PM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • Oldschool297
                                          RELAND SUN 6.3v 3300uf Low or High ESR?
                                          by Oldschool297
                                          I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
                                          https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
                                          08-14-2023, 04:32 AM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • Perry Babin
                                          Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                                          by Perry Babin
                                          I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                                          This is for the primary side of a switching power supply in a car audio amplifier.
                                          Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                                          10-16-2025, 05:20 AM
