Need help identifying Ceramic Capacitor
  • paceuser
    • Apr 2020
    • 14
    I have the following ceramic capacitor that I would like to identify. I need to purchase another one like it or an equivalent. Here is the text on the capacitor:
    Capacitor is Yellow in color. It has three lines of writing:
    VF05
    0221
    TK RU (RU = Underwriter's Laboratories Logo)
    If anyone knows an equivalent on fleabay please let me know. Thank you I appreciate your help.
    • 31170
    Re: Need help identifying Ceramic Capacitor
    something looks wrong, it may be a MOV not a cap
    post a photo
    • paceuser
      • Apr 2020
      • 14
      Thank you for your response. I have attached the picture.
        It is MOV/Varistor (Designated as VAR1). 5D = 5 mm Dia., 221 = 220V
        http://www.xiaheonline.com/MOV-5D-Series.html
        Why do you think it is bad? It is not blown.
        What kind of device are you working on and what is it not doing?
        • paceuser
          • Apr 2020
          • 14
          Thank you! It has no resistance and no capacitance. How do I test if it is working? Which would be the correct replacement on that link? It is on a light motion sensor.
            There is nothing wrong with it, it will conduct when Voltage exceed the rating then it conducts into low resistance, the capacitance is really low in pF range. It is a protection device, it is not needed for the circuit to operate. Look some where else for problem as to why your device not working.
            If you want help troubleshooting, you need to up load good clear pictures of the whole top side and bottom side of the boards. What kind of testing have you done so far?
            • paceuser
              • Apr 2020
              • 14
              Thank you budm for the explanation! So far I have tested the capacitors and they all seem to be good. I am attaching some pictures of the board. Thank you I appreciate your help.
                • 31170
                you never said what the symptoms are.
                if this is mains powered - check that redish polypropylene cap
                • R_J
                  • 9583
                  Looks like a motion detector board from a outdoor light. (Heath/Zenith SH-5597 or similar) If I'm wrong I know "someone" will say I'm wrong.
                  • paceuser
                    • Apr 2020
                    • 14
                    Sorry, the symptoms are that at night, the lights no longer come on. Yes, its a Heath/Zenith security/motion light.
                    • paceuser
                      • Apr 2020
                      • 14
                      The red polypropylene capacitor has .73 microfarad. Not sure if that is what it should have.
                      • petehall347
                        • Jan 2015
                        • 4435
                        • United Kingdom
                        whats going on next to the red wire where it goes through a hole ?
                          • 31170
                          what does it say on the sides?
                          • paceuser
                            • Apr 2020
                            • 14
                            Close! It says "SL-5318-A" on a sticker and on the metal plate it says "SL-5316-A".
                            • paceuser
                              • Apr 2020
                              • 14
                              That red wire is going through the hole to one of the two lights.
                              • paceuser
                                • Apr 2020
                                • 14
                                It says :
                                564K
                                250V
                                  • 31170
                                  so off-board it should meter around 560nF
                                  • paceuser
                                    • Apr 2020
                                    • 14
                                    I have not removed it yet but on board it measures .73 microfarad.
                                      • 31170
                                      well combined parts are 730nF - that's why you lift one end to test them.
                                      • paceuser
                                        • Apr 2020
                                        • 14
                                        I removed it, it has .57 microfarad.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • NuclearSpartan
                                          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                                          by NuclearSpartan
                                          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                                          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                                          I don't see any other visible damage anywhere else on the board....
                                          11-14-2024, 02:32 PM
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • rictechie
                                          smd ceramic capacitor use in iphones
                                          by rictechie
                                          is there a brand of smd ceramic capacitor use in iphones? or they are generics
                                          07-26-2024, 08:28 PM
